Graphics Which 670 would you get?
Discussion in 'Hardware' started by j4mi3, 12 May 2012.
  1. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    It's landed!
    To be installed after work tonight.
  2. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
  3. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
  4. Somer_Himpson
    22 Jan 2010
  5. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
  6. NetSphere
    NetSphere What's a Dremel?
    15 Jul 2011
  7. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    haha yeah, just noticed that £450 price. Pre-ordered from scan, cheers :thumb:
  8. j4mi3
    28 Jun 2011
    wait if i order it at this pre order price, that is the amount i will pay? it seems weirdly low
    if so omgggg wat do i kind of want 4gb but that price is too good to turn down
  9. Nomaipaker
    Nomaipaker What's a Dremel?
    19 Jan 2012
    I would go for the EVGA superclocked version. The performance is so much better with overclocked but also hotter. Probably need to buy an aftermarket cooler to keep it cool during gaming.lol
  10. j4mi3
    28 Jun 2011
    DCUII TOP
    -great cooler
    -higher stock and boost clocks than sc
    -can be overclocked further than the sc because the cooler is better
    -doesn't have 4gb
    -very cheap on scan atm
    sc
    -has 4gb
    But the thing is, 2 or 3 fps is all well and good but in 3 years time, 4gb will be important not those 3 fps. am i right?
  11. teppic
    teppic What's a Dremel?
    18 Jul 2011
    The price isn't that good, it's just that the standard one is vastly overpriced at scan. The standard model is £324 on ebuyer.
  12. j4mi3
    28 Jun 2011
    ah yes so it is. are they a good site? never bought from them before
  13. davefelcher
    davefelcher What's a Dremel?
    14 Aug 2009
    Yes. Last couple of times I've used the free delivery option I ordered in the evening and it arrived the next morning.
  14. mkb
    mkb Minimodder
    2 May 2010
    So what is the general consensus then? Is the ASUS GTX670 DIRECT CUII TOP @ £360 worth the £60 premium over say the cheapest 670 Ref Card, Palit, @ £300?
  15. j4mi3
    28 Jun 2011
    i think it is. you get a great cooler, and the oc is higher than any other pre overclocked 670 afaik
    moreover, you can actually crank even more juice out of it, it will oc even further.
    My concern still lies with the 2gb or 4gb. because unfortunately there isnt a 4gb direct CUII
    which means i will have to settle with an evga, which i dont think looks as good as the asus, and the cooler is crap compared to it, and it isn't as fast - even the superclocked version. more like mediocre clocked
    I can just sense than in 3yrs time, at my res games will be using way more than 2gb. and i will wish i had gone for the 4gb
    ideally i want 4gb AND a great cooler. but there is no such thing with the 670.
    I was originally looking at the 680 phantom 4gb but at £520 (ex vat) its so expensive
  16. mkb
    mkb Minimodder
    2 May 2010
    I'm looking at getting a new IPS monitor at 2560x1440 and I'm also somewhat concerned about whole 2GB vs 4GB mem but, as I see it, I'll prob upgrade again in around 2 years and with BF3 being more or less the only game pushing current cards I've come to the conclusion that a 2GB card will most likely suffice. The price difference too between the 2GB and 4GB is also pretty substantial which is dissuading me too.
  17. j4mi3
    28 Jun 2011
    Yeah you are probs right
  18. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Asus Direct CU II although I am "slightly" biased:
    Nommy Nommy card sandwich.
    :D
    I will have a big GTX670SLI vs 680 (vs HD7970 in certain games) review coming soon.
  19. j4mi3
    28 Jun 2011
    very nice indeed.
    yep i have decided to go with the 2gb asus, but i am waiting it out for the TOP version.
  20. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    My Gigabyte GTX 670 is waiting for me in a depot North of Bristol on lock down at the moment. Tentative delivery for Monday! If I like what I see then SLI will be on the table for sure. If it wasn't for the water cooling options that the Gigabyte 670 PCB opens up (because it is basically a 680 PCB!) then I would go for the Asus GTX670 Direct CU II. Although I see prices have already shot up!
