Displays Which is better?
Discussion in 'Hardware' started by numanoid, 6 Jun 2009.
  1. numanoid
    numanoid Modder
    26 Apr 2009
  2. crosshair
    crosshair It's life Jim but not as we know it
    12 May 2009
    Hmm. They've both got TN panels. TBH, if you're spending that sort of money, plump for a PVA panel. Or better...
  3. numanoid
    numanoid Modder
    26 Apr 2009
    thanks for the reply matey, you got any sugestions :D
    take care m8
  4. crosshair
    12 May 2009
    My Dell UltraSharp 2408WFP was the killer with an S-PVA panel until it was superceded by the HP LP2475W with an IPS panel. Both will set you back about £430 tho'. But there are cheaper versions. Depends how much eye candy your after...
  5. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    May I redirect you here..
    Although your rough price range is right inbetween two of the panels.
    Go for a Dell, I hear good things about them. If I had to choose one at ~£275, I'd go for this one, although I'm sorely tempted by the TN panel Full HD 24inch.
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    the T260 should serve you very well. my T240 is excellent.
  7. numanoid
    numanoid Modder
    26 Apr 2009
    cheers guys for all the help, im after a 26"-27" not 22" or 24"
    thanks again
    take care
  8. bagman
    bagman Minimodder
    18 Apr 2009
