WhiteIce | BIG PICTURE UPDATE!
Discussion in 'Project Logs' started by illvit, 14 Dec 2004.
How should the finnish on the plexi be?
Poll closed 9 Jan 2005.
  1. Clear blank
    1 vote(s)
    16.7%
  2. Matt(icy)
    6 vote(s)
    100.0%
  3. White under the plexi(mirror)
    1 vote(s)
    16.7%
Multiple votes are allowed.
  1. illvit
    illvit What's a Dremel?
    14 Dec 2004
    Update!
    Here's some photos of what I have done, and what I am going to do.
    Here's the old At-case with some of the tools O have used :p
    Some buttons from the case that I am gonna use as Reset and start.
    The HK monted with spacers.
    Found out that the Agp-lock was very strong compared with the hk i'm use now, so I'm going to drop the AGP/PCI bracket. The dark sone will I saw off. I could borrow my uncles autosaw.
    Comments? I think I am going to saw tommorow.
  2. BlackDiamond
    BlackDiamond What's a Dremel?
    7 Sep 2004
    A hammer inside a PC case - the right tool PC tuning :rock:
  3. illvit
    14 Dec 2004
    A little update.
    I marked a little bit better where I will saw.
  4. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Looking pretty good. Keep working...
  5. illvit
    14 Dec 2004
    Thanks
    BTW: X800XT PE in the house!!
  6. illvit
    14 Dec 2004
    Update!
    A picture of the beauty X800XT PE. I have planned to watercool this.
    A picture of the aluminumsbakplate that my uncle sawed out to me
    That's how the case looks like now.(I know the case looks skewed, but that's just temorary)
    The PSS open.(I think the component in there looks very fancy)
    Yeah, plexi is good! Maybe I am going to make a frosted effect on this to
  7. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    How did you manage to afford these components...
  8. illvit
    14 Dec 2004
    I bought the graphic-card used.
  9. deadly-app
    9 Mar 2004
    still, thats what, like 400 bucks?
  10. illvit
    14 Dec 2004
    500 bucks. The PC camed up to 1610$. The Norwegians Krones worth is very high now.
  11. illvit
    14 Dec 2004
    Update: Frosted PSU
    Time for modding of the psu. I forgot to take pictures under the work, but here is the psu almost done. The white stripes is glue that is not dried yet.. The glue will be transparant when it is dried. .(HINT: Woodglue(It works))
    In the "dark"
  12. Pelihirmu
    Pelihirmu What's a Dremel?
    2 Jan 2005
    At this point I can't say almoust anything about your case, but I'm hoping that you mannage to build beautiful case :) :dremel:
    BTW. You should wait that that glue dryes until you take any pics :D
  13. deadly-app
    9 Mar 2004
    even clear its going to look badly....you have made some bad choices in this mod :(
  14. illvit
    14 Dec 2004
    Pelihirmu: Thanks.
    deadly-app: What do you mean with bad choices? BTW: Every peoples tastes is different
  15. Lost.Soul
    Lost.Soul What's a Dremel?
    26 Oct 2004
    About PSU: When you "frosting" acrilic, you must do that over whole surface. It seems that your acrilic is "frosted" much more in the middle than on the edges and this isnt look good.
    Second thing is that you must use really fine sandpaper. If you dont, there will be deep scratches instead of smooth sanded surface. It needs a bit of patience.
    :baby:
  16. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    The woodglue would be one of those such choices. Woodglue isn't made for bonding plastic, I think you will find that it will crack off of the plastic very easily. Even clear (think fishtank) silicone would have been better, if you don't have any access to "real" plastics cement. :thumb:
  17. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    or get a piece of wood
    and another piece of wood
    push the plexi between it
    clamp it
    en then heat it up with a blowdryer
    and bend it
  18. deadly-app
    9 Mar 2004
    Javadog got my point exactly. gluing rather then screwing it in or otherwise affixing it was a bad idea. Glue works on somethings, but on others it is a bad idea as it will end up looking very badly =\
    For the sanding fine = frosted, sanding too fine keeps it clear, sanding it with 400-600 will give you a good look, and the scratches in the plexi, as long as you sand it evenly there wont be any...
  19. illvit
    14 Dec 2004
    Ok. I will begin to sand it with finer sandpaper. The sides will be glued with Araldite. I don't have the silicon-mass that you're talking about. Anyway, thanks for the comments I have got.
    Edit. I found some acryl-silicon, so I am plugging the mass now.
  20. illvit
    14 Dec 2004
    Pussed of the glue, filled with silicon and sanded with finer sandpaper
    What do you think? Is it better now?
