Blogs Why everyone should own dummy RGB memory modules
Discussion in 'Article Discussion' started by bit-tech, 19 Dec 2018.
  1. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    RGB RAM? Pass.
    RGB dummy RAM? Hard pass.
  2. RedFlames
    23 Apr 2009
    Solution... reduce most/more boards to 2 DIMM slots.
    Realistically how many people have 4x DIMMs?... Sure you've got 2 spare and 'oh I can always add more RAM later' sloshing around your mind, but the majority seldom do.
    Or go ITX... no PCI-E slots you ain't gonna use, no empty DIMM slots you have to fill with ******** DIMMs.
    edzieba and Arboreal like this.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    They do aid cooling don't they? on two of my systems, one DDR4 , one DDR3 once fully populated and with volts cranked through them they needed airflow for stability I would have thought the heat spreaders on DIMMs are helping to dissipate this heat.
  4. adidan
    25 Mar 2009
    Just waiting for the next article '3 reasons why I love gold and why everyone needs to coat their mouse in it'.
    TheMadDutchDude and The_Crapman like this.
  5. RedFlames
    23 Apr 2009
    Why you need to give the iMac another chance.
    adidan likes this.
  6. The_Crapman
    5 Dec 2011
    If you have the argeebees they're a fantastic idea. I would like to see a return of aftermarket ram heatsinks, something more meaty and metallic.
    Pete J, MLyons and adidan like this.
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    RGB is fun and if you can't get stuff without it easily (gfx cards, AIO coolers, mice, ...) then you might as well use them. I wouldn't go out of my way to do so, though.
  8. silk186
    silk186 Derp
    1 Dec 2014
    They look a little better and make them safer to handle.
    That said, I hate huge heat sinks as they obstruct cooler clearance.
  9. The_Crapman
    5 Dec 2011
    You wouldn't fancy some thermalright heatsinks then?
  10. silk186
    silk186 Derp
    1 Dec 2014
    Go big or go home!
    or at least go copper.
    If that fails, water!
    [​IMG][​IMG]
  11. jb0
    jb0 Minimodder
    8 Apr 2012
    Man, if you ain't immersed the whole board in a tank of mineral oil, you ain't even tryin'!
    The_Crapman likes this.
  12. Alecto
    Alecto Minimodder
    20 Apr 2012
    Only little kids and **nope** need shiny LEDs in their computer. Normal people use their computer; they don't look at its innards.
  13. The_Crapman
    5 Dec 2011
    FTFY :thumb:
    Get rig of the blue and that is full on splooshness :naughty:
    Omnislip, Dogbert666 and Corky42 like this.
  14. adidan
    25 Mar 2009
    I'm no fan of RGB but that's going too far dude.
    Edit: removed word, it is Christmas afterall.
    Guest-56605 likes this.
  15. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Found the normie! Also, no, just no.
    TheMadDutchDude likes this.
  16. Gareth Halfacree
    4 Dec 2007
    I might not be a fan of LEDALLTHETHINGS, but I am absolutely here for attaching ridiculously massive heatsinks to things that don't actually need a heatsink at all.
    jb0, perplekks45, Arboreal and 2 others like this.
  17. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Go noctua. You won't regret it.
    On the actual article matter. It would allow me to make my build more christmasy
    Such as dogbert's head using an Intel stock cooler when he's busy benchmarking during the summer... for example.
    Guest-56605 and The_Crapman like this.
  18. Mister_Tad
    27 Dec 2002
    silk186 likes this.
  19. Guest-56605
    Guest-56605 Guest
    I'm one of the least PC people on the planet in terms of humour, THAT particular word however is decidedly cringe worthy.
    adidan and TheMadDutchDude like this.
  20. Vault-Tec
    30 Aug 2015
    To be fair to Corsair this wasn't really their idea. It was suggested to them over and over again on the Corsair forum, they just listened is all.
    *joke from other forum* it's no different to the GTX 970 really..... (not my joke but god it made me laugh).
    I'm a fan of RGB because it has an off button. It really is as simple as that.
    silk186 likes this.
Tags: Add Tags
