Widescreen Projector, update: DEC 12 - 2006
Discussion in 'Project Logs' started by The_Gnu, 26 Apr 2006.
  1. microcf
    microcf What's a Dremel?
    3 Jul 2006
    The_Gnu.. kom igen nu.. visa lite nya bilder!! :)
    for all those who really think they dont understand Swedish..;
    The_Gnu.. come on.. show some progress!! :)
  2. taliban_raider
    taliban_raider Just some guy; you know
    28 Feb 2003
    Looks incredible, keep up the good work :dremel:
  3. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Yes I have looked at both those sites and have had many ideas. This is currently the zoom mechanism I'm working on.
    The triplet lense is attached to the see through white parts that will be fabricated out of 2x13=26 mm plexi.There is 4 7mm holes in the plexi that will allow it to slide back and forth on the four 7mm steel rods. In the pics you can only see 1 thin spacer for the triplet, but I will also ad a larger one to increase the space .
    I thought this zoom mechanism would be an easy task but it was really hard. The holes can't be of the exakt same dimension as the rods because then it will be a verry tight fit. And the holes can't be to large either because then the whole plexi part can twist a little bit and jam because of that. And the four steel rods need to be in a perfect vertical angle or the whole thing will jam.. ..
    Any sugestions on any easy zoom mechanisms would really be helpfull.
    (it needs to be able to slide ~5 cm)
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    Here is the 13mm plexi I got for free. It's from when we rebuilt at the supermarket I was working in. Its a cashregister "booth".
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    cut a piece and drilled a hole in the middle that is threaded and inserted a cut of bolt.
    (CLICK TO ZOOM)
    This is How I started to create the round shape for the triplet lense spacer.I attached the plexi to my drillpress and used a normal saw. The larger ones that you normaly cut wood with. Make shure not to press the sawblade to hard against the spinning plexi, as it will "cut" and you can hurt yourself or damage the plexi.
    (CLICK TO ZOOM)
    after a while i could move down to the file and at last the sandpaper.
    (CLICK TO ZOOM)
    I used a razorblade to pres against the top while spinning to mark where i was going to create a hole. The 3 smaller holes are for the triplet to attach to.
    (CLICK TO ZOOM)
    I drilled holes in a cirkle and removed the middle section. Trimed down the edges with this dremel ad on. Its a sandpaper brushing weel.
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    I have also made a second smaller spacer for the triplet lense in the same way.
    (CLICK TO ZOOM)
    triplet lense with small spacer.
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    Cut a hole in the front plexi plate for the triplet.
    (CLICK TO ZOOM)
    The fit was perfect... those ugly bolts will not be visible in the end.
    (CLICK TO ZOOM)
    Here I cut a fan hole in the bottom plate to blow air in to the lamp from below.
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    I am doing my best to get this projector finnished in 2 days. Because I have a "movienight" coming up;). But i doubt I will make it as there is always some problems popping up.There is also a lot more pictures to upload.
    /GNU
  4. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    This is a great project. Everytime I see it it gets better. Awsome work.
    Keep at it.
  5. Al_Cap0wnage
    Al_Cap0wnage What's a Dremel?
    16 Jun 2006
    YAAAY! An update... Looks like its coming along really well, good luck in getting it done in 2 days though :D
  6. OldY
    OldY What's a Dremel?
    10 Mar 2006
    That looks absolutely fantastic!!! Hope you get it up and running okay!!!
  7. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    Great work with the precise cutting of the plastic...
    Because all that hard work will be for nothing if its off by a few millimetres and does'nt work... but you've got it handled and your work is very meticulous...
  8. The_Gnu
    12 Sep 2005
    Typical...as I thought, problems seem to like me :) Both the drill and the threading tool broke :waah: So ready in 2 days didnt happen...no good to hurry. I'm of for a trip now but will give it a try next week again.
    /GNU
  9. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    Wow, that is amazing worksmanship for those spacers.
  10. alexdcd
    alexdcd Laptop Specialist
    24 Feb 2006
    Gods Speed m8, hope you get it running in time and it doesnt kill any bulbs. I am a little worried about the number of inlet/outlet fans on the case, are they fairly quiet? , that would be a nightmare having such a slick case and all that noise.
    Great progress so far, it might take a while but at least you are creating custom parts and you must be learning a hell of a lot in each aspect like bulbs and lenses.
    Great work so far :thumb: :thumb:
  11. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    Your worksmanship :jawdrop: ...great job.....subscribe
  12. The_Gnu
    12 Sep 2005
    The fans I will be using are 2x silent zalman 80mm slimline. They will be at 5-7V each. The larger 120mm fan is a silent ADDA. It is very quiet so i don't think the sound will be any problem. I am more worried about the fans not cooling enough. If thats the case I will switch the 120mm ADDA with a more powerfull 120mm. Yes you learn alot with a project like this, especially about materials like alu and plastic. But What I have learned the most is that making a detailed blueprint would have saved me a lot of time and work.
    /GNU
  13. The_Gnu
    12 Sep 2005
    I have been on vacation for some time, but now I'm back and I have purchased new sandpaper and drillbits so it's time to get this thing done.
    Marking out where im going to mount all the connectors and the power switch.
    [​IMG](CLICK TO ZOOM)
    Here it is all mounted. You can see the VGA connector is attached with regular screws. These will be changed for normal connector screws so that you can secure the connector. The reead and black connectors are NOT for sound, they are for AV1 and AV2 video IN. There will be no speakers in it at all. Don't think that will be needed because all audio will bee connected to the sorround system.
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    Time to mount the ballast for the 250w lamp. It is very very heavy. Around 5 kilo I would guess. So I relly want it to stay in place and this is how I mounted it.
    (CLICK TO ZOOM)
    Fabricated 2 pieces of plexi that will act as a stand for the ballast. They will be secured to the ballast and then too the bottom plate from underneath.
    (CLICK TO ZOOM)
    This white thing is the ballast.
    (CLICK TO ZOOM)
    (CLICK TO ZOOM)
    Don't know if you could understand it, but the ballast is mounted to the bottomplate with 6 screws. 2 vissible on that aluplate on the side and 4 non vissible underneath that is secured into the 2 pieces of plexi. Now that big heavy thing won't move at all.
    (CLICK TO ZOOM)
    That's it for today. Will be back soon with more.
    /GNU
  14. nightmare03
    nightmare03 What's a Dremel?
    5 Jun 2006
    I think this is my first post?
    Kick ass work, looking forward to more updates! :D
  15. smartdude24
    smartdude24 What's a Dremel?
    27 Feb 2006
    I agree :) wicked PJ Gnu!
    You actually inspired me to get into building one of my own... which I am currently working on. It's a 15" Haas design.
    Can't wait for more updates!
  16. omicron
    omicron Baud.
    8 May 2004
    Finished to the highest quality - I was impressed by the fan hole, for god's sake!
    Very nice mate. Look forward to seeing this grow.
  17. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    At the least this thing will come out with a perfect case.
  18. The_Gnu
    12 Sep 2005
    Thank you for giving me your first post :thumb:
    Thx to you too, it's always nice too hear you have inspired someone to do something similar. Please, send me a link if you post your pics on the net, would really like to see it :)
    Thx to all you other to for your encouraging comments. :rock: Will hopefully have some pictures of the button mechanism tonight if nothing unexpected turns up.
    /GNU
  19. The_Gnu
    12 Sep 2005
    The next update is a little bit late, I was working on the buttons when I suddenly desided to try a new zoom mechanism. I didn't tink it would work any good but I had to give it a try. I didn't stop until it was done 5 hours later and It turned out much better than I could possible expect. It is totaly different from the one shown earlier and it's way easier to fabricate. Will post the pics of the buttons and the zoom mechanism by then end of this week.
    /GNU
  20. davidbacsik
    davidbacsik What's a Dremel?
    23 Apr 2006
    that vga setup? What exactly do you call it, and where can I get one?
    AMAZING project by the way. I may use the brushed metal/bending to create a stereo unit for a SliMP3 type device i'm creating.
