Hi guys,sorry if its a silly question,as i have learning difficuties,if i buy the gigabyte aorus ddr4 3733 mhz...will they work fine in the gigabyte aorus z390 motherboard ...i know it will but i always gave a dread that it wont so checking before buying...thanks
Yes, they will be absolutely fine. Remember to enable XMP in BIOS so they run at the proper speed, otherwise they'll only run at 2133/2666. It's worth noting that while you should be able to get the full 3733 from them, if you get any instability you may just need to bring them back a notch to 3600. I'm not sure every CPU/memory controller can manage the high ratings that some RAM sets are capable of
