Motherboards Will only power on after removing and reinserting 24 pin plug
Discussion in 'Tech Support' started by GaryP, 13 Oct 2018.
  1. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I have a Gigabyte H61MA-D3V I bought a couple of months back for these Fortnite builds. Been working fine when built on test bench. Transferred it all to its case and now it will only boot up once I have taken the 24 pin power plug out and back in again. Then it resets BIOS back to 2012 !
    If I leave the kettle power cable out of the psu but leave the 24 pin plug in for just a few minutes, and then put it back in, it won't boot.
    If I leave the kettle plug in all the time even with pc switched off it will boot up normally every time.
    I can't send this over for my mates kid to use like this. The other build is working fine. It does it on 2 different PSUs, one brand new one and the one on my bench.
    The light appears on the GPU even when pc is off so power is getting through to the board. It just won't power up without dicking about with the 24 pin plug.
    Bit desperate now as I will have to find another board and a copy of windows 10 as this had one with it.
    Any ideas ?
  2. TheMadDutchDude
    23 Aug 2013
    It’s resetting the clock which can only mean one thing... dead CMOS battery.
  3. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Tried that. Made no difference. It will only boot when I remove the 24 pin plug.
  4. GaryP
    GaryP RIP Tel
    31 Aug 2009
    New problem now. Even if I leave the board plugged in switched on at PSU, If I leave it more than a few minutes then it boots up but straight to bios saying reset again.
  5. TheMadDutchDude
    23 Aug 2013
    Hmm... something isn't holding its power correctly. That's bizarre. I've run into this before, but I cannot for the life of me remember what it is.
    GaryP likes this.
  6. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Yep. Just dont understand why unplugging 24 pin and plugging it back in works to power up, but then only to go to bios.
  7. Vault-Tec
    30 Aug 2015
    Does it need a bios update for the CPU you are using?
    GaryP likes this.
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Just spit balling here but maybe the PSU is holding some charge (like they do) and that in turn is causing an effect on the board, only when you completely remove the 24pin does it allow for the board to boot.
    GaryP likes this.
  9. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Well it worked perfectly before witht this cpu. i5 3330. That's why I am scratching my head.
  10. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Two different PSUs. One brand new EVGA and my bench runing a 430M corsair.
  11. Big Elf
    23 Apr 2009
    I also think I've had something similar before but can't remember what fixed it. I think the battery is either shorting out and draining or something on the board is shorting and draining it so maybe have a look in the battery area or the retaining clip.
    I assume you're reloaded the BIOS just in case it's that?
    GaryP likes this.
  12. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I haven't reloaded the bios but I will try that anyway.
  13. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Did nothing. Worth a try just to rule it out.
  14. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Not shorting on the back of the board?
    GaryP likes this.
  15. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Nope, looked at that !
    I cleaned the back off with alcohol too when I cleaned off round the battery area. Just using an Coolermaster cooler with push pins so not cooler mounting either.
    I have tried seven batteries, five of which are new and one from a board I bought this week which works fine. Am going to but some new batteries tomorrow decent brand and see wha ahppens. Clutching at straws now.
  16. tsutton
    tsutton Minimodder
    29 Aug 2003
    Earth issue.
    Remove the board & test it outside the case. If it works fine then it's an earth issue.
    silk186 and GaryP like this.
  17. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Same issue in case and on testbench.
  18. tsutton
    tsutton Minimodder
    29 Aug 2003
    Very odd. As you already tried two different PSUs, I wonder if the board is faulty? Might be worth RMA'ing it?
  19. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Its a 100 years old no RMA there !
  20. Ice Tea
    Ice Tea Modder
    26 Jul 2009
    Did you try forcing the board to use the backup bios like the H81M?
    If that doesn't help i would remove the GPU completely and try the onboard intel graphics via the DVI socket at the back of the board to see if it's a GPU card problem.
