Will this cooler physically fit
Discussion in 'Watercooling' started by kuroidoragon, 13 Jul 2022.
  1. kuroidoragon
    kuroidoragon Minimodder
    14 Oct 2012
    I currerntly have a Kraken X52 cooler mounted on a TUF GAMING Z690-PLUS WIFI D4
    motherboard which only just fits when all 4 ram slots are filled but the coolers logo is at not the right angle
    I am looking at the
    ROG RYUJIN II 360 can anyone confirm with absolute certainty if it will physically fit my motherboard or not with all 4 ram slots filled ?
  2. kuroidoragon
    14 Oct 2012
    anyone ? are these forums used by anyone anymore ?
  3. adidan
    25 Mar 2009
    Yes they are but I' not sure how many would have that setup so I'm not sure how anyone could 'confirm with absolute certainty'.
    All I'd be able to do is trawl the web, check reviews and Asus support docs which I'm sure you've done.
    As they're both Asus products I'd be contacting them myself.
    keef247 likes this.
  4. wolfticket
    19 Apr 2008
    You're relying on people having a very niche piece of knowledge/experience in order to answer that without doing a load of research to work it out on your behalf. While you might get lucky it's not exactly surprising no one has the answer you want.
  5. kuroidoragon
    14 Oct 2012
    I have sent a email to Asus via there webform wonder if I will actually get a response
  6. kenco_uk
    28 Nov 2003
    Can't see why it shouldn't. If only bindibadgi was here.. are there any forums where Asus staff frequent?
    The_Crapman and adidan like this.
  7. kuroidoragon
    14 Oct 2012
    well I have a kraken X52 & because of the 4 ram slots being filled it is a tight fit because of the pipes that come out the only way the cooler fits is with the logo at a silly angle which can't be turned around & the unit that goes on the CPU on the ROG RYUJIN II 360 looks a little big & bulky
  8. kuroidoragon
    14 Oct 2012
    still not found a answer to this after all this time so if someone can answer the original question with absolute certainty that is great
    or can someone suggest another AIO cooler that fits with all 4 of those ram slots fiiled without having to have the logo at a stupid angle
  9. adidan
    25 Mar 2009
  10. kuroidoragon
    14 Oct 2012
    Thanks for trying to help a lot of sites & some people just go by the socket type like that site & don't take into account the physical features of the board I am just a bit nervous about buying a cooler & then finding that it doesn't fit
  11. adidan
    25 Mar 2009
    It's a bit odd Asus haven't responded to you.
    I mean they're not cheap bits of kit.
  12. The_Crapman
    5 Dec 2011
    I would say with 99.9% certainty that it will not fit. Looks like your problem is more the tubes clashing with things around the socket, which would still happen with the ryujin, which also comes with the caveat that is HAS to be placed at 12, 3, 6 or 9 o'clock.
    Can you not rotate the Kraken's top? Very surprised if not.
  13. kuroidoragon
    14 Oct 2012
    is the Ryujin nolt one of those where you can twist/move the thing around ?
    if not can someone suggest me one
  14. The_Crapman
    5 Dec 2011
    Like seriously, have you not bothered doing any research of your own!? Have you even seen it in bits?
    No, it can't be rotated.
    If the logo on your current one bothers you that much, cover it in tape. If you need further help, I can recommend Google.
    keef247 and adidan like this.
  15. adidan
    25 Mar 2009
    Yeah, as @The_Crapman says, time to do a bit more research yourself dude.
    We're only finding stuff easily available on the internet and unless you find somebody in the exact same scenario or get a response from Asus that's what you can be doing yourself.
    I mean cmon, you started this thread in July.
    keef247 and Mr_Mistoffelees like this.
  16. Mr_Mistoffelees
    26 Aug 2014
    Seriously, how big a problem is a squify logo?
    keef247 likes this.
  17. Krikkit
    21 Jan 2003
