News Wolfdale versus Core 2 Duo
Discussion in 'Article Discussion' started by The_Pope, 19 Apr 2007.
  1. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
  2. Guest-23315
    Guest-23315 Guest
    Wolfdale is looking very nice.
    Its Socket 775 I guess, with DDR2 or what?
  3. chrisuk
    chrisuk What's a Dremel?
    23 Jun 2005
    From what I remember they are pin compatible with Core 2 Duo, so all that should be needed is a BIOS update.....I could be totally off mind you!
    There looking pretty good though, will def have to consider when I finally decide to part with my hard earned cash for a new rig.
  4. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Yes, socket 775 with DDR2. They should be compatible with current chipsets, subject to BIOS updates.
    Were the processors in this demo identically clocked, or was the Wolfdale clocked higer and/or on a 1333 FSB with the Conroe on 1066?
  5. Tim S
    Tim S OG
    8 Nov 2001
    They'll also be supported by Bearlake, too.
  6. Dr. Strangelove
    Dr. Strangelove What's a Dremel?
    13 Mar 2005
    How can you even ask such a silly question?? Naturally we want you to get a few into your hardware testing dungeon, and test it till it sweats :D
  7. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    after you guys test it i will see if i buy it or not.
  8. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    After the new AMD's come out to compete with the new intel, at that point I will decide which processor to buy... :)
  9. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Here's useful thought.
    Lets start actually writing software that actually takes use of multiple cores!
    Sheesh, almost nothing, is multi threaded yet.
  10. Dr. Strangelove
    13 Mar 2005
    careful that's a big nono, Intel and AMD sure don't want us to figure that one out cause then why would we buy the 16 cores slapped in one package deal CPU?
    You are naturally completely correct, I would say dual core (or dual CPU) is great (yeah you can alt-tab out of games without having to wait 5min), 4+ cores who needs them? (apart from specific server programs made to use multiple cores)
  11. mclean007
    22 May 2003
    Agreed, quad core has very little application on a consumer desktop at this stage. Yeah you may be able to encode Xvid, run a virus scan, run a Photoshop batch conversion and play SupCom all at the same time, but who really does that? Until games like Alan Wake, that really take advantage of multicore, come out, dual core is ample for 99% of home users and quads should stay where they belong - workstation and server rigs.
Tags: Add Tags
