Hardware Wolfking Warrior XXtreme
Discussion in 'Article Discussion' started by Tim S, 24 Jan 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. p3n
    p3n What's a Dremel?
    31 Jan 2002
    The RHS reminds me of these keyboards we have at work for the special needs kids, the keys are all perfectly lined up - although still a QWERTY layout its incredibly confusing to use.
  3. naokaji
    naokaji whatever
    8 Dec 2006
    while such special layouts might work for fps games that use a very low number of keys i dont think it will be any good for rts or rpg's (and even less my fav mmorpg eq2).
    why?
    because condesing the low number of keys used in fps games does make sense, but if you have some function you use on pretty much every key of a normal keyboard then i dont think theres a need for a special layout.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    I play MUDs,a lot, which are in essence MMORPGs, but text based, so no use for the mouse. And even if it seems like this keyboard is catered for that kind of game, I doubt it will work. The key layout is FPS based (WASD), while most MUDs use NWSE to move around. So it seems like it's a badly manufactured, useless gimmick.
  5. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    I'd disagree with the manafacture - it feels very sturdy and well made.
  6. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    Who's hands are those in the pictures?
    Their nails look wonderful darling, just wonderful.
    Now, as for the product itself....I'd just go for the single one tbh.
  7. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    QFT. How many games require you to have both hands on the keyboard nowadays?
  8. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    maybe they could get a single larger unit with macro buttons around it....
  9. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    That would be me. And I find your comment slightly unnerving...
  10. Mother-Goose
    22 Jul 2004
    You should be proud of your unusally large nail bed on your pinkies Archangel, you must give me the number of your manacurist.
    Come now, don't be shy!
  11. Hugo
    25 Dec 2006
    It's called "cut nails only when actually long enough to cause physical pain".
    On a more related topic: this keyboard is really uncomfortable to use.
  12. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    Actually if the right hand side had macro buttons I'd be happy to cut one of these up and use only that side - being a lefty it's the only way I'd ever use WASD (I currently remap as much as I can to the number pad and I find the lined up keys much easier to locate by feel than those on the Fang gamepad I no longer use).
  13. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    and i would rather just go for a normal keyboard tbh
  14. BloodyIron
    BloodyIron What's a Dremel?
    17 May 2008
    I am a gamer who competes at TF2 and I am serious considering this keyboard.
    Why?
    Because I see this potentially replacing my entire keyboard.
    But wait, what is my entire keyboard? Check this out: http://www.dansdata.com/edkb.htm
    I picked up the beige one on ebay about 1.5 years ago for about $20. It had a very steep learning curve, but i do not regret it. The reason I want to replace it is that it is wearing out.
    I am in love with small keyboards, I am glad that I do not have to deal with numeric keypads any more at all. It also affords me the ability to use the massive steelpad mousepad I won at lanageddon last year.
    I would seriously consider this (XXtreme) keyboard as a replacement, as it affords me the ability to type sentences, while minimizing the footprint on my desk. This was one of the shortcomings of the original Warrior, because I could not type full sentences back.
  15. BloodyIron
    17 May 2008
    Oh, also a note. Considering this is a "Gamer" keyboard, I am appauled that bit-tech did not do any testing to show the number of simultaneous keys pressed, or any sort of actual physical limitations of the keyboard itself. Or testing if the USB ports are powered (or not), etc. This seems more like a summary of the device and brief usage of such with commentary on how "comfortable" it was.
    While this can be useful, it only goes so far to serve the public.
    Please bit-tech, consider more thorough reviews for "Gamer" keyboards.
  16. BloodyIron
    17 May 2008
    correction, "seriously" instead of "serious" in the first post. (Why can't we edit recently posted comments?)
Tags: Add Tags
