Displays Wrong Resolution
Discussion in 'Hardware' started by unknown115, 8 Jan 2010.
  1. unknown115
    unknown115 What's a Dremel?
    8 Jan 2010
    Hi
    I recently purchased a AOC f22s but im unable to run any of my games at its highest resolution with the exeption of World in Conflict. The max resolution is 1980x1080 but i am only allowed to select up to 1600x1200. I have the screen running at 1920x1080 but i had to go into Nvidia control panel select change resolution then add resolution as it was only giving me 1600x1200. I have updated the driver from the disk and sent AOC an email but they havent responded yet. All help is welcome
  2. Guest-44432
    Guest-44432 Guest
    Try going to www.nvidia.com and installing the latest drivers first.
    Simon
  3. GoodBytes
    20 Jan 2007
    Ah, the art of purchasing non-standard aspect ratios on the computers... common problem.
    What Windows are you running?
  4. unknown115
    8 Jan 2010
    Thank's for the quick replys. My graphic's card is up to date and im running windows vista 64bit.
  5. GoodBytes
    20 Jan 2007
    Warning, I don't know your GPU, so the follow may not be exact.. but the point is the same:
    In the Nvidia control panel, go to the "Change resolution" section.
    Click on "Add resolution" button, Then click on "Create Resolution", and add your screen solution by filling the form. Set the refresh rate to 60Hz. Click On test, to test it out, if it works, it will be added.
    Once added, go back to the main Nvidia panel, select your resolution
  6. unknown115
    8 Jan 2010
    I have already done all that and that is what im running the now but when ever i try to play a game i can only select a maximum resolution of 1600x1200.
  7. GoodBytes
    20 Jan 2007
    Create a screen resolution with 60.001Hz (see advance settings of the panel where yuo enter the custom resolution).
    It might actually do: 59.997Hz, which Windows rounds to 60Hz.. but your game is too stupid, and ONLY look at 60.00Hz and up resolutions.
  8. unknown115
    8 Jan 2010
    Ok iv done that but i had to up the refresh rate to 61 as 60.001 gave me an error message, but still no luck when playing games.
  9. Fazed
    Fazed Minimodder
    5 Jul 2009
    Ok, unless I'm completely blind, I saw nVidia mentioned, but no reference to what card.
    So, what card exactly are you using?
  10. unknown115
    8 Jan 2010
    Its a 8800gts 512mb
  11. PortalBen
    PortalBen Minimodder
    22 Nov 2009
    Have you tried editing the .ini file for the game's config?
    Works in most other games.
  12. unknown115
    8 Jan 2010
    How do i do that?
  13. azrael-
    azrael- I'm special...
    18 May 2008
    Adding 1920x1080 to the list of supported resolutions only makes a difference if the game (or application for that matter) uses that list, which isn't necessarily the case. What you're doing when adding a custom resolution is essentially nothing more than telling the OS that you have a monitor which can handle this resolution.
    PortalBen is on the right track in that you may have to edit the config for the game/app in question to enable higher resolutions. Sometimes it can also be worthwhile to check for updates/patches as such functionality may have been added.
  14. unknown115
    8 Jan 2010
    Ok, i have a few games running at 1920x1080 by changing the games config, the others i cant find but im workin on it.
    Thanks for all the help i was getting a bit annoyed with this problem its a bit of a hassel but at least my games are running at max resolution. Again thanks for all the help.
