A/V Xonar DGX driver not detecting card
Discussion in 'Hardware' started by Deewon, 10 Dec 2012.
  1. Deewon
    Deewon New Member
    29 Dec 2010
    Hi All,
    Recently installed my new sound card into my machine but after trying to install the drivers from the xonar website (dated 2012.05.08), it isn't detecting the card.
    Windows has picked up the card and installed it with what looks like the standard Win7 drivers. I'm running 64bit.
    Any ideas what could be the problem and how to fix?
    Thanks
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    The currently installed driver is provided by Asus as your screenshot shows.
    Doesn't it work?
    Have you checked the default sound device? (Right click the sound tray icon and choose "Playback devices".)
    Is there an extra power connector on the card and is it plugged in?
  3. Deewon
    Deewon New Member
    29 Dec 2010
    It works fine but I would like to update the drivers to the newest ones and I'm missing the Xonar DGX Audio Center, only have the default windows sound properties to play with at the moment.
  4. lava
    lava Member
    18 Sep 2010
    Have you disabled your on-board sound in the bios? Might be a conflict
  5. Deewon
    Deewon New Member
    29 Dec 2010
    I disabled my ATI and Realtek sound devices via device manager and restarted. After trying the software again it detected the card and installed fine.
    Still running the same device driver version but now have the audio center so just going to leave it at that for now.
    Thanks
  6. GoodBytes
    20 Jan 2007
  7. CrapBag
    CrapBag Well-Known Member
    17 Jul 2008
    I had the same issue with my daughters DGX, I moved it to another pci-e slot and the problem went away.
  8. Kovoet
    Kovoet New Member
    26 Aug 2009
    Had the same problem then downloaded from their site and been brilliant since then
