News XP to remain on shelves until June 2008
Discussion in 'Article Discussion' started by Tim S, 28 Sep 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Hells_Bliss
    Hells_Bliss What's a Dremel?
    6 Apr 2007
    smart move on microsofts part. smarter move would be to port dx10 to xp though :p maybe i'm just biased 'cause i don't like vista
  3. AcidJiles
    AcidJiles Minimodder
    19 Jun 2006
    not going to vista till after sp1 and not a moment sooner
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Why would they want to keep XP alive? It's time to let it die now, honestly.
    There will still be support for XP anyway.
  5. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    dx10 on xp would be a good idea. since its the only thing that i sort of want that vista has. and im not upgrading my os just for dx10 (especially since my video card isn't even dx10)
  6. koola
    koola Minimodder
    11 Jul 2004
    XP > Vista anyday. Just need dx10 for XP and I'll have the perfect gaming PC until dx10.1 :(
  7. rito
    rito What's a Dremel?
    19 Sep 2007
  8. GoodBytes
    20 Jan 2007
    yea I can't wait to see how sluggish it will be, and how my games will freeze, and beside all that half of the feature will work. And that's me being optimistic about it.
    XP is too old and need to die. I REALLY want change, I'm a type of person that LOVE change. If things don't change, it gets boring, tiering and makes my days more bland.
    The second I switch to Vista Beta 2 with forced XP drivers for all my stuff (X-fi, Nforce 4, Geforce 6600), I simply hate XP.
    I start to see ALL XP problems that I got used to. Liiiiike:
    - Roll-over your mouse on your clock and wait for the tool-tip to appear and disappear. Congratulation!!! now a full Windows startup is needed to make the tool-tip on the clock work.
    - Tool-tip appears behind start menu on task bar and quick-launch bar (this doesn't do it all the time)
    - Networking issues on a simple network system with XP Pro SP2
    - Start-menu "freezes" when you edit too much the Start menu on the start-menu (rename, delete items)
    - Remote Desktop can change the classic start menu side XP label.
    - If you open a folder with files and folder WITHOUT scroll bars and use the "selector" (you know, click on nothing and keep your mouse button pressed, and drag your mouse. The blue semi transparent selector), and move that selector to the bottom edge of your window, your content will jump up an down stupidly. If you open My computer then go to a folder, or use control Panel it will NOT work. Also items need to set as "tile" or "icons" (see attachment)
    - SOMETIMES Windows appear above task bar of 1 px, even thus you set your task bar to not do that (only shows in Classic skin)
    - Applications can easily steal focus from you.
    - Taskbar flash blue items like if something changed or something to tell you to check it out, but nothing happened on it, same applies for windows.
    - Internet Explorer is part of explorer.
    - If you make appear the window "tip-of-the-day" [View>"Explorer Bar">"tip-of-the-day"] (yea it has that), and you click on "New tip" again and again and again (like 20-30 fast clicks), and you will see that the tip don't repeat, they will simply not show.
    And I can go just on... the List is SOOOO VERY LONG.
  9. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    agree. XP should just die already. and its not just about Dx10. nowhere near. but Vista is the way to go forward. period. ;)
  10. capnPedro
    11 Apr 2007
    There are a few things wrong with Vista, but I'm not going back to XP. Overall, I think Vista is better than XP.
    I won't put Vista on older machines, though. Those will either get XP or Linux, depending on their job. I need XP (MCE) for my HTPC and Vista for my main (gaming) rig, but other machines can get Linux.
  11. GuitarBizarre
    GuitarBizarre <b>banned</b>
    2 Jul 2007
    Hardware limitations are forcing the changes. While for this exact instant XP is better, soon enough even average consumer systems will be reaching XP's RAM limit, and other assorted limitations.
  12. Hells_Bliss
    6 Apr 2007
    normal vista is a 32bit OS...meaning you can have your 2.5gb but until you go to 64bit, you're not getting your 4gb. why upgrade to vista when it's 1) a RAM hog 2)requires a minimum of 256mb vid card 3) is still 32bit?
    I can use my fancy dancy XP 64bit and have a stable, tested OS that runs that much faster then vista.:duh:
    press the start button. your tooltip is now back :D no need to restart.
    you actually think all those problems are fixed in vista? or that others aren't created with Aero? This is Microsoft we're talking about here. :idea:
  13. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    For a fresh install on a recent board Vista worked way better than XP for me - though still not as smooth as some Linux distros.
  14. completemadness
    completemadness What's a Dremel?
    11 May 2007
    QFT
    in my limited experience using vista (installing it for a customer that demanded it) i hated it, it was complete rubbish
    Networking in windows is still slow, buggy and generally doesn't really work
    Vista is a waste of money, XP does what i want - it runs my software and its easy to get going, why do i care about an extra bell or whistle on vista, when you have to deal with all the driver issues, and all the rest
    If i wanted to put up with that, i would start using ubuntu
  15. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Like others have already said, Vista does NOTHING to change this. 32bit vista still has the exact same limitations as 32bit XP, and 64bit versions of either OS don't have these problems.
    in my personal opinion:
    64 bit OS > 32 bit OS
    64bit XP > 64bit vista*
    *I have actually tried vista for 2 weeks, the overall impression i got was XP + prettyness + bloat + things moved and things dumbed-down for no apparent reason + incompatibilities**.
    ** have yet to get bioshock to work in vista, even with a clean install + brand new drivers + bioshock only
    especially annoying is the fact that MS loosened the requirements for DX10 a while back, removing the last vista-only component dx10 needed... The only thing stopping DX10 on XP now is MS trying to force people to upgrade :(
  16. boynoing
    boynoing What's a Dremel?
    29 Sep 2007
    Vista must be a new OS for most people. Just like when XP released, and win98 disappeared.
  17. GoodBytes
    20 Jan 2007
    Sorry, Vista Aero works well with my Evga Geforce FX 5900 128MB SE (NOTE: SE stands for Sucky Edition, and not Special Edition).
    And that video card was an Nforce 2 with an AMD Athlon XP 2500+ with 768 GB of RAM. The OS not is running perfectly, put you'll get the same effect with XP with 448MB of RAM. And that was Vista Beta 2, I did not try RC1 or RC2 on it, and with WinXP Drivers for both video card and mobo, and my soundstorm sound card.
    They are! Vista has it's issues like all OS's in this planet, but at least it doesn't prevent you from beeing productive, or reboot your computer because XP starts to take more and more resources for no reason after leaving your comp on for 3 days without any reboots. Also while you have your startup programs, you can DO SOMETHING with Vista, you don't need to wait like more 2min (even without any startup applications) before your system is ready, and if you use the start menu, while it loads it disappears on you, you really have to wait until everything is fully loaded. Also, under Vista, when you open a big file (project in some big fat program or big video) you still have access to the folder of where the you ran the file. In XP, the folder becomes "Not responding", and you have to wait until everything is fully loaded. And that's all with a dual core processor.
    That's because you don't know how to use or configure a network under Vista. This slowness problem was visible in RC1 but not RC2. so I think you used a wrong (crack or beta ?!) copy, or did not update windows, or it's a driver fault, contact your hardware manufacture and tell them they are complete idiotic for making vista drivers at l the last very last minute, in addition, on how their drivers sucks.
    If I understand correctly, that sounds like driver issues. Contact your hardware manufacture and tell them they are complete idiotic for making vista drivers at l the last very last minute, in addition, on how their drivers sucks.
    Try is for a month, and you will love it. Make sure you have the latest updates and drivers first.
    If you think Vista is XP with prettyness + bloat, that's because you didn't use enough.
    As for incompatibilities, go the website of every software and make sure you download the latest software version or patch or Vista edition of the software, or contact the support forum.
    Also, define "bloat", tell me what is "bloat" 'ed or, well, useless but that takes system resources like crazy. (and don't stupidly say "Vista" or "The hole OS", or something similar.) If you don't know what takes so much system ressources, tell us so we can clear up your misinformation.
  18. Daniel114
    Daniel114 What's a Dremel?
    9 Sep 2007
    When my new PC is built up I fully intend to dual boot with a 32 bit XP and a 64 bit Vista, if nothing else simply so I can play the games I have now and take full advantage of my X-Fi and other apps that run seamlessly with XP. granted it took me ages to move on from windows 98 (dropped 95 sharpish though).
    All that's going to happen is from now on everything will be built with Vista in mind, I don't think it'll be that it gets much more stable as a platform itself, its just that developers will have to embrace its problems (like I'm guessing they did with every other new OS) until its the norm
    Maybe I'm just to long in the tooth nowadays, or that I see XP as my 'game safe' dual boot to Fedora? Everyone seems to be arguing for and against the move, I think what willl happen is all those that swear by XP will only do so until something comes out just for it and they'll have to switch (as dx10 did with most). Sitting on the fence seems like the only option to me
  19. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Having used both for a while now, I must say that Vista feels a little, well, unfinished. Some simple tasks in XP take you the scenic route in Vista. To get .doc files associated with MS Word takes a registry hack, FFS. You have to turn off User Account security to stop it from asking, nay, nagging you for permission to do even the most simple tasks. And it will not let you save files in just any folder; daddy Vista knows best...
    In Word 2007 saving a document template will not automatically switch to the right directory; it dumps them in the Documents folder. Good luck with getting Word to notice them and putting them in the right location.
    Every change takes some getting used to, but this is more than just a change of habits. There are still some UI issues to iron out.
  20. GoodBytes
    20 Jan 2007
    I must agree with Nexxo, but personally I take in consideration that SP1 will take care of them (maybe not UAC and Office 2007, but those I can live), as I saw those and other problems being improved under RC1 and RC2 (yea it was worse).
Tags: Add Tags
