Photos Your Room and Computer
Discussion in 'General' started by RTT, 19 Oct 2007.
  1. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    @Byron C , what size/brand/model of screen is that at the top there, please?
    Edit: ignore me - I can see it's a Dell, and based on your post in the Life-ruining thread I am assuming it's a fairly standard size (presuming that the one underneath is your defective 30").
    I was only asking because I am thinking about getting some sort of temporary secondary screen, probably 12" to 15" and I assumed that your main screen was a 24" :)
    Byron C likes this.
  2. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    It's a wee baba!
    20" I think. I asked for a second monitor from work and they gave me one of the naff 1600x900 ones instead of the slightly larger 1080p screens. Boo! But any second screen is better than no second screen...
    The main one is a Dell 3008WFP which I think is on the way out...
  3. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Ah, your post has crossed in the ether with my edit :) Cheers. Hopefully your old Dell can be persuaded to live to fight another day.
    Byron C likes this.
  4. Mister_Tad
    27 Dec 2002
    I have reached peak camgirl, and I think my office setup is finally finished.
  5. David
    7 Apr 2009
    What do you think of that keyboard? I've heard conflicting opinions.
  6. Mister_Tad
    27 Dec 2002
    I like it, in that it's fine. I don't have any strong feelings about it either way tbh.
    I don't twiddle the knob (ooh err) nearly as much as I'd like to as there isn't much in the way app-specific functionality outside of a handful of apps that I mostly don't use. A bit disappointing as there's heaps of potential in a bunch of apps that I do use, but I can't get it to do what I want it to. So the MX Keys is undoubtedly a better buy over this 99% of the time.
    As a keyboard, I find it pleasant typing and it's quiet enough to not get picked up by the mic.
  7. Byron C
    12 Apr 2002
    Well I'm not far behind you it seems
    Although no Arr Gee Bee lighting (besides what's in my case) or fancy gigantic curved monitor here... And that camera is almost certainly better than mine!
  8. Mister_Tad
    27 Dec 2002
    Would the cam not be better in between the monitors? Unless your onlyfans caters to a top of your head fetish, which is almost certainly a thing.
  9. Byron C
    12 Apr 2002
    Yeah probably, I haven't faffed about with it that much yet.
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Both your monitors are so low! I feel for your necks and backs!
  11. Mister_Tad
    27 Dec 2002
    Top of mine is at an ergonomically correct eye level if I’m sitting properly.
  12. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Don't forget that when you're 8 inches tall that's basically an Imax theatre.
    keef247 likes this.
  13. Byron C
    12 Apr 2002
    Mine is slightly lower than it should be, but it's not far off tbh.
    It's a heavy beast though, so can't have it mounted too high on the stand.
  14. wyx087
    wyx087 Multimodder
    15 Aug 2007
    May I ask what monitor and how did you do the colour matching ambient light?
  15. adidan
    25 Mar 2009
    Squirrel ahegao is even more niche.
  16. Byron C
    12 Apr 2002
    But I'm afraid that furries are definitely not my kinda thing...
  17. Mister_Tad
    27 Dec 2002
    It’s a Dell U4021QW with a couple of hue play bars stuck to the back with purple and blue because it’s purdy. Matching the on screen colour is merely a coincidence I noticed after the fact here, nothing fancy.
    A hue sync box would do the job afaik generally, but not with the 5120x2160 res here.
    I almost clicked “like” on your post, but then didn’t want anyone to get the wrong idea.
    wyx087 likes this.
  18. adidan
    25 Mar 2009
    The first rule....
  19. David
    7 Apr 2009
    Yeah... I think I'd probably end up using the knob as an expensive volume control.
    I'm keeping an eye out for deals on the MX Keys.
  20. Mr_Mistoffelees
    26 Aug 2014
    What you do with your knob is something you should keep to yourself.:nono:
    keef247 likes this.
