Photos Your Room and Computer
Discussion in 'General' started by RTT, 19 Oct 2007.
  1. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Totally not my photos and stolen from the RMC discord server (link: https://discord.com/channels/431348664489738251/628458346365845524/774973597793779732 EDIT: Scroll down a bit for these actual photos) - this is from a Multiscan 200ES, and I have a Multiscan 210ES:
    It probably won't be easy though...
  2. adidan
    25 Mar 2009
    That looks like it's as easy as peeling off a plaster!
    I hope it is but I feel it won't be quite that easy.
    Byron C likes this.
  3. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    There is only 'one' corner desk, but you'll need to hit up ebay as Ikea stopped making them, you need a Galant or 2
    adidan likes this.
  4. adidan
    25 Mar 2009
    Ah ha. Yeah i had a brief scoot around old forum posts and that seemed to get mentioned but assigned to history now.
    I may check out some ex office stock as well - there may be something there. Although, come to think of it, one that needs assembling maybe the only way it gets into the loft.
    I mean I could make one I guess.
    I just need time. Materials. Talent. Oh and ability. :happy:
  5. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I ended up placing a big order for some "kee klamps" piping and fittings in oder to make a custom desk. Wanted something in a very specific size (120cm wide) and with a top shelf, and shlf above monitor, so I figured just DIYing it was the best way to go.
    Now I just need to source the actual desk-top (and also the shelves). Any good options other than Ikea/lumber yard?
  6. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Messed this post up
  7. BennieboyUK
    24 Nov 2010
    So long story short, I built a second Ryzen Rig and moved my other parts onwards. I also decided to pull the plug on watercooling and I am just waiting for the EKWB FTW3 Block to arrive in March to complete the loop.
    I am not a RGB fan, so chose a classic (if over done these days) black on red. I spent a good number of hours on the WC loop design, with the goal to keep the loop as simple and small as possible. I used Xflow Rads to help with this along with some tight (but not too tight) connections in the loop. I hope from the images you can see when the GFX block arrives how it will fit into the loop. I ran the loop for 48 hours prior to building.
    Kit List:
    Part Model
    CPU AMD 5900x
    Motherboard X570 AORUS XTREME (rev. 1.1)
    Memory Trident Z Neo DDR4-3600MHz CL16-19-19-39 1.35V 32GB (2x16GB)
    SSD Inland Premium 2TB SSD 3D NAND M.2 2280
    Graphics EVGA GeForce RTX 3090 FTW3 ULTRA GAMING
    PSU Antec TPQ-1200 1200W Continuous Power
    RAID Controller RS25DB080
    RAID ARRAY Raid 6 x5 3.5 Drive WD Black 4TB 7200 RPM SATA 6Gb/s 128MB Cache 3.5 Inch - WD4004FZWX
    Case Thermaltake View 71
    Riser Cable TT Premium PCI-E 3.0 Extender – 300mm
    Fan Six Noctua NF-F12 PWM chromax 120mm
    Fan One Thermaltake 140mm Ring RGB
    Braided Cables EZDIY-FAB PSU Cable Extension Sleeved x2
    CPU Block EK-Quantum Velocity RGB - AMD Nickel + Plexi
    Res and Pump EK-Quantum Kinetic FLT 120 DDC PWM D-RGB - Plexi
    Tubing EK-Tube ZMT Matte Black 15,9/9,5mm
    Fittings - Various EK- Quantum Torque STC-10/16 - Black Nickel
    Front Rad Alphacool 14230 NexXxoS ST30 Full Copper X-Flow 360mm
    Top Rad Alphacool 14235 NexXxoS XT45 Full Copper X-Flow 360mm
    Coolant EK-CryoFuel Clear (Premix 1000mL)
  8. Auxilliary
    Auxilliary Crashes into space stations
    27 Jan 2011
    Decided to finally get round to tidying it all up after neglecting it for far too long!
    trigger and Almightyrastus like this.
  9. spolsh
    spolsh Multimodder
    4 Feb 2012
    Looks good, but itty-bitty pictures ...
  10. Auxilliary
    27 Jan 2011
    Probably far too big now :wallbash:
  11. spolsh
    spolsh Multimodder
    4 Feb 2012
    nah, just right. (and .. I have the same speakers)
  12. Auxilliary
    27 Jan 2011
    for the price they were, they are cracking little speakers, although I have an urge for something much more powerful soon :grin:
  13. el2k
    el2k Modder
    18 Jan 2010
    Here's my current setup... It's not very clean or tidy, but I know where everything is...
    Fizzban, DeadP1xels and Auxilliary like this.
  14. Auxilliary
    27 Jan 2011
    hey thats the same desk as mine above! the IKEA Galant, plus a white fractal, although mines the R6 not a Meshify and im jealous of the KRK's i'd love a pair of them one day
    el2k likes this.
  15. el2k
    el2k Modder
    18 Jan 2010
    Dunno if you can see but I'm also running an EVGA 1080 FTW2, whats the chances aye!
    Auxilliary likes this.
  16. Auxilliary
    27 Jan 2011
    far too many similarities here.... :hehe: although i have removed my 1080 for a 3090FE i finally managed to get a couple of days ago
  17. GeorgeStorm
    16 Dec 2008
    Nice setup, and yours is far cleaner and tidier than mine hah! Just reminds me that I really need to get some kind of drawers or something so everything isn't on the desk....
    el2k likes this.
  18. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    So you're saying it's possible, but you might need to update your Tetanus injection. :grin::p:
  19. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Moved back to an ATX build so I could actually fit in a more powerful GPU (that was available). Ended up getting a pre built with the right spec, at the right price, that I could tweak with already owned parts.
    Also for reference, this is the new GPU with a NZXT H1 for scale:
    :eeek::hehe:
    Byron C likes this.
  20. Byron C
    12 Apr 2002
    Still not happy buy damned sick of re-arranging and re-wiring my desk now! :hehe:
    I think I'm going to move the mixing console over to the right, as that'll give me room to have my work latop docking station over on the left...
