ZapWizard's LAN PC -Custom Ammo PC -Completed Jan 18 '04
Discussion in 'Project Logs' started by ZapWizard, 3 Jul 2003.
  1. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Without the fibers the light doesn't get refracted to the front at all.
    (really no light is visible on the actual blades)
    As for the plexi, yes it would block most of the air.
    And I want the mods on this case to me mostly stealthed.
    Where not even if you look closely, could you tell that it was even modified.
  2. ZapWizard
    19 Sep 2002
    What am I doing today?
    Duct work!
    First I made a duct for the CPU
    The PSU sits on-top of the dimms, so I needed a unique way to get air onto the dimms.
    I installed a small squirel cage fan and more plexi.
    The air will pass down the center, and back around the sides of the dimms
    Here you can see the PSU on top of the dimms
    Now with all the duct work installed, the part mounting is coming together.
    Now with the parts installed in the box.
  3. Virtblue
    Virtblue What's a Dremel?
    10 Mar 2002
    damn you have mad skillz
    ps: is there a specific name for the 10 pin conector you used for the vga cable?
  4. Astrum
    Astrum Dare to dream.
    8 Mar 2002
  5. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Zap, about that lighted fan... first off, very good work.
    have you thought of making the pieces of plexi that connect the fan hub to the fan's frame thinner though? Or are they weak if they're any thinner?
    And that CPU duct idea is great. I'm doing the same for my case... I just ran outta plexi unexpectedly. Heh:miffed: :duh:
  6. ZapWizard
    19 Sep 2002
    Part number's HR206-ND, and HR108-ND from www.digikey.com
    The specs are here:
    http://www.hirose.com/PDF masters/RM Master.pdf
    I did at first make them only around 1/4" thin, but like you guessed they are too weak.
    The fan would vibrate too much, and it started to push its' way towards the LEDs.
  7. ZapWizard
    19 Sep 2002
    Glowey hardware time
    Following another of Japala's excelent guides, I decided to make the motherboard and GFX card glow under UV light.
    http://www.metku.net/
    I used a set of highlighters to create the effect.
    (I used yellow and orange, which comes out to Green, and orange under UV light)
    I have 6 UV LED's with which I can create the effect.
    This effect though will only be visible though the fan holes, as I don't plan on putting a window in the case.
    During the day, the yellow is praticaly invisible, and the orange is pretty dark.
    In all reality this was just more of an experiment, as no-one will really ever see the motherboard anyways.
  8. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Y'know Zap, here in VA it's only been the third for a couple of hours...
    Over there in texas it's been the third for an hour, or maybe just 14 minutes... :lol:
    Just goes to show your dedication. :rock:
    And the UV looks friggin' cool, it could be a hidden trick in the LAN PC. :D
  9. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Back to work on yr lan pc now:)
    I like the way you cooled your ram. Nice Idea what is that tube made out of? How loud is that aero fan?
    Good work aswell
  10. DeX
    DeX Mube Codder
    22 Jul 2002
    So Zap is there enough room below the Radiation sticker to be able to implement my idea?
  11. ZapWizard
    19 Sep 2002
    The duct work is all plexi and hotglue. All very simple.
    That fan is fairly quiet, but it does push a lot of air.
    I think you were talking about actualy venting air from behind the sticker? (Around it's edges?)
    If I need any extra venting I will use the spaces behind the grill work at the bottom of the front, or more from the sides.
    But so far all the air-flow seems to be working out perfectly.
    If I do ever put windows into this case, I will still use the mesh to cover it up.
  12. DeX
    DeX Mube Codder
    22 Jul 2002
    No, I asked if there was enough room behind the little radiation sign on the front sticker to cut it out and then use the cut out to project the radiation symbol on the ceiling. That way you get another lighted effect on the front but also a seamless integration with a projected image from the top of your case. Would look great I think.
  13. ZapWizard
    19 Sep 2002
    Hmm, there is room, but I want the sticker to stay as authentic looking as possible.
    I may integrate a projector into the LCD's case when I get to that.
    I think that the hole in the side of the case would be perfect to integrate a projector into.
    (It could also simply light up as a good radiation level meter :) )
    As for the other two posts above:
    Thanks for the totaly Non-related Spamming
    And that was a duplicate post anyways.
    I am removing the two posts.
  14. ZapWizard
    19 Sep 2002
    I AM GOING TO QUAKECON!
    I registered today, and will be driving up on the morning of the 16th.
    I hope to get there by 8 a.m.
    The modding competition starts at 11am
    By then I should have the pc in a mostly ready state.
    I think I will try and order a low-profile radeon 9200 to get a little more boost out of the system.
    Wish me luck
  15. [twig]clown
    [twig]clown What's a Dremel?
    1 Jan 2003
    Good luck at QuakeCon Zap :thumb: !
    Hopefully you can win yourself something else for all your hardwork on this project ;)
    -cLoWn
  16. Frogbutt
    Frogbutt What's a Dremel?
    15 Feb 2003
    Good stuff I was hoping you'd go so i could see it in person. I noticed Nvidia is hosting a modding comp. also so you should end up leaving with some goodies.
  17. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    wow... loving that lan pc :D
  18. bushd
    bushd What's a Dremel?
    9 Nov 2002
    Zap I got friends that goto that every year. I planned on helping setup. I do live right near Dallas, Sunnyvale actually. Anyone else going to be going; we need a MEMBER get together in which I suppose Zap would be the exception.
  19. ZapWizard
    19 Sep 2002
    Well come by and check out the PC if you can find me there.
    I just ordered at Radeon 9200 128MB low-profile card, it should be the last part I need.
    Ok, list of stuff to do:
    Mount everything.
    Wire up LAN LED, and LAN Volt Meter Modification.
    Install last remaining green LED behind 2nd exhaust fan
    Build the light throber circuit
    Build battery supply for throbber
    Shorten up cables, and sleeve them.
    Customize windows to look military style
    -more will be added as I remember it
    /Edit.
    I found my Case linked from another forum:
    http://www.thinkhardware.com/forum/index.php?showtopic=1543
    Apparenly I get on K's nerves :p
    If you do see my PC linked somewhere I want to know.
  20. jcm44
    jcm44 What's a Dremel?
    4 Feb 2002
    i like the glowing. i am not sure if one can see it at all, but it would be cool to look through a fan or the mesh and see that little bit of detail on the insides. i mean that's true attention to detail. how long did you plan this thing before you really started working on it?
