Hardware Zotac ZBox HD-ID34 mini-PC Review
Discussion in 'Article Discussion' started by Claave, 27 Oct 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. its
    its What's a Dremel?
    7 Feb 2007
    Laptop without a screen... Alrighty :D
  3. devilxc
    devilxc Biding my time...
    23 Mar 2010
    It is a sexy laptop without a screen though.
    If they had a remote and had sotware installed so it was 'plug and play' it could have been a popular device.
    As it is, most people who have the know how will settle for a laptop / old PC instead.
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    Another comment on the lack of remote. It looks like a BD player, why no remote! This thing is obviously designed to live under the TV.
  5. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    I agree with you all, no remote??? Does it come with an OS either?
  6. Guest-16
    Guest-16 Guest
    Yea I would have given it 10 for features if it just had a remote. It's everything a HTPC should be... almost! That doesn't stop you going out and buying your own though, or using VNC with your iPhone/Android touchscreen phone.
    Tatty - no, because it's a barebone box and not everyone wants a HTPC with Windows, which would add to the cost. Linux/XBMC is free ;) plus offers GPU acceleration because Nvidia actually supports Linux (however an install package would be nice!).
  7. Krikkit
    21 Jan 2003
    Zotac seem to be on a bit of a roll really - that mITX board looked pretty epic too.
  8. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Hmmm given that my PS3 looks and sounds like it is on its last legs (half an hour last night trying to get it to boot) this looked perfect, right up until the point I read it came with no remote and no OS yet costs over £400.
    At this price I would rather build my own HTPC. In fact given the PS3's problems I will probably have to.
  9. Guest-16
    Guest-16 Guest
    Well, you can, but a slot loading, slimline Blu-ray drive alone will cost you a pretty penny. ;) Zotac's advantage over a home build is that you cannot get this curvaceous form factor elsewhere.
  10. xaser04
    27 Jun 2008
    I wouldn't be using a slot loading drive if I could help it. Having two house Rabbits (that love to chew or mark anything they can sink their teeth into) means I like having everything behind covers. The amount of times they have turned off the PS3 / ejecting a disc by leaning on it is not funny.
  11. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Looks really good apart from the mentioned remote and "No BDR or DVDRW function."
    BTW this sentence on page 2 needs sorting!:
    Also under the score it says: rec.jpg[/img
    As well as a few others not as bad such as: [QUOTE]What is missing is aremote[/QUOTE]
  12. XSAN
    XSAN What's a Dremel?
    21 Sep 2009
    I would like to see a AMD Fusion version of this with 4DB DDR3. Why are we still using DDR2? Like the first comment a laptop without screen. :)
  13. David
    7 Apr 2009
    So, no remote, no OS, it can't burn DVD or Bluray discs and it's plastic.
    Aluminium-like... seriously?
    I don't even think it's all that good looking, and I think the styling will get dated really quickly.
    Other than that, nice! LOL
  14. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    What a terrible review (very short next to no details or stats) and a terrible product, its pointless might as well buy a Sony Blu-Ray player have similar features...
  15. FelixTech
    FelixTech Robot
    12 Jun 2009
    You forgot to close your image tag!!
    rec.jpg[/img <==
    This thing looks sexy! I don't get what the people saying you should get a laptop instead are on about. Why would you want to stick a laptop under your telly, and would it be as quiet?
  16. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    also:
    aremote?
  17. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    Just a quick stupid question, the price difference between the two version is it higher ofr lower than a Hdd and sodim ram (what is missing I mean of course).
  18. DST
    DST What's a Dremel?
    9 Feb 2010
    No word on Crysis in the review :)
Tags: Add Tags
