Distributed Bit-Tech Folding@Home Team (CLOSED: now superseded by joint CPC/bit-tech team)
Discussion in 'Software' started by Byron C, 2 Aug 2003.
Thread Status:
Not open for further replies.
  1. wyx087
    15 Aug 2007
    same, the electric bill is through the roof because of the cold.
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Well if your cold, that is an excuse for folding, that energy gets turned into heat to make your house warmer.
  3. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    Man these new graphics cards can certainly fold well! I've managed to chew through 50 WU in 5 days, and only 4 on my cpu :S
  4. kenco_uk
    28 Nov 2003
    I ran a couple of wu through on my gtx260 and with it being overclocked, I was wondering why my pooter kept restarting. It turns out that if the gpu hits 75c, it locks up and reboots the pooter. So I set the fan to 92% and it keeps it at 67-68c. Bit noisy though. It's strange that the same overclock runs for hours whilst gaming, with the fan set lower.
    The folds must make it work like crazy!
  5. tank_rider
    3 Feb 2005
    I guess gaming is variable load and doesn't max out all parts of the gpu, whereas folding goes all out. Seems strange that yours locks up at 75 degrees as mine's hit 75 on several occasions and hasn't shown any signs of crashing, mine is at standard clocks though.
  6. kenco_uk
    28 Nov 2003
    Aye, it's strange. It seems to have a pretty drastic overheat protection mechanism. Previous NVidia cards have gone higher, temp-wise.
  7. wyx087
    15 Aug 2007
    i have a few lockups using the recent 181.20 driver, when the card is overclocked of course. not sure whether it's temperature issue as i log my temperatures on RAMdisk, which are lost when restart :-/
    i just moved a fan down to help cool the GPU, so i'll up the clock again and see if it hard-locks
  8. tank_rider
    3 Feb 2005
    i can confirm it's not purely due to exceeding some sort of 75 degree limit as my gpu has been at 78 degrees for a while today when folding and hasn't crashed, however that is at stock speed.
  9. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Ha, I have my GPU regularly idling at 80 degrees. Goes up to 90 something under load. Is there a folding client that will work on Laptop GPUs?
  10. tank_rider
    3 Feb 2005
    The folding client will run on any 8 or 9 series gpu that can run cuda, so i'd have thought it would run on your laptop gpu too.
  11. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Ah excellent, I have just recently installed the new nVidia drivers, will have to try this out some time.
  12. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Add a 4850e+ and a 8100(onboard) to that list.
    /psuedo bump
  13. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I can't fold, I'm behind a goddamn web cache here at uni. Doesn't work :(
  14. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    folding away now :)
    3 computers
    3.2ghz p4
    2x dual-core opertron
    dualcore 1.6ghz
    1 gpu (8800gts)
  15. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    tried running it through a proxy?
    RwD
  16. SkyLord77
    SkyLord77 Use your teeth not a Dremel
    21 Dec 2008
    I'm sure this is a lame question, but I don't know how to join the bittech folding team. I don't know if the links from the first page are the correct ones to use as those were posted quite some time ago.
    Right now I fold anonymously and I'd like to help the team if possible.
    Thanks,
    Keith
  17. wyx087
    15 Aug 2007
    just set team number to: 33346. that's all there is to it!
    will be back folding this summer :) going to get back on top. goal: go over 1mil milestone and catch up with BlackPuss.
    he's Folding all the time, but i think if i fold 24/7 with my new GTX260, i can do 50 points every 7 days
  18. 500mph
    22 Jun 2007
    My gts 250 is now folding along.
  19. dark_avenger
    9 Jul 2008
    no. 56 in the team now, go me :)
  20. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    Is it cheating if I set up 20 or so of these that aren't being used at work?:lol:
    It is an option...
Thread Status:
