Planning Metaversa 2.0: Even More Messing about with concepts...
Discussion in 'Modding' started by Nexxo, 25 Apr 2011.
  1. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    It might just be cheaper to contact the manufacturer to request a special edition non-anodized radiator.
  2. Cheapskate
    13 May 2007
    Any tech schools in the area you could exploit?
  3. Nexxo
    23 Oct 2001
    Tried Birmingham University in the past but they always have a lot of their own stuff in the queue. I know a CNC guy called Enak (an old member of this forum) whohas done excellent stuff for me in the past, although nothing this big. I also talked to Eddie of MNPC Tech who may be able to help with some parts if I convert the SketchUp model to the right .IGES format.
    Meanwhile I have also been thinking about a design that is a wooden box, but with a lid that hinges open to unfold some sort of elaborate radiator array. Lifting the lid also turns it on --something like opening a magic box. It would look a bit like those antique box cameras you see. Mahogany, brass and leather would feature. It's my plan B if the other design proves too costly or complicated to build. :)
  4. Stuey
    20 Jan 2005
    I like that idea too! C'mon, please say that you'll use pneumatics to lift the lid of the plan B case!
  5. Cheapskate
    13 May 2007
    How about getting cheeky and make this a sticky with a big, "help me make this!" in the title.:naughty:
  6. bulldogjeff
    2 Mar 2010
  7. ringo
    ringo What's a Dremel?
    14 Jun 2008
    I like the second one and the fourth one. Which sketching software do you use for your models?
  8. cchr
    cchr Minimodder
    24 Nov 2010
    It's said in the first post, Google SketchUp ;)
  9. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I really like your designs Nexxo!
    For something a bit hardware oriented, you might want to look at having some back-up fans situated under the sandwich of radiators. Just in case your computer decides to go thermal in the middle of a gaming session ;) you could use an arduino to control the fans so they only turn on if the temp reaches millions of degrees.
  10. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Recently I've been looking for a new direction in design, all the PC related designs float around sleek smooth also murder mods styling.
    I've been plaining something along the lines of a tribute to the NeXT Cube
    But now i am tempted to change the rules again!
    EDIT: Cat out of the bag render
  11. Nexxo
    23 Oct 2001
    Nice design. :) Go for it.
    I'm currently designing (as back-up plan) a wooden box of which the top lifts and the radiator and reservoir unfolds while the PC is switched on... I think I have the basics of the mechanism worked out.
    @Picarro: there's no need for fans. The passive rad is overspecced as it is. I like to keep things as uncomplicated as possible... Er. :worried:
  12. cchr
    cchr Minimodder
    24 Nov 2010
    can you explain what you mean when you say that the reservoir unfolds? it sounds interesting.
  13. Cheapskate
    13 May 2007
    Sooooo... You might have someone to cut for you? Bitchin'!
  14. Nexxo
    23 Oct 2001
    OK, I've made a parts list... Excluding motherboard (still being designed) and one or two supporting bits which are not complicated so should not add to the cost or complexity.
    Now I need to start to get costings for this to see how feasible it is to make this thing...
  15. Guest-23315
    Guest-23315 Guest
    They are 'turned' not 'lathed'...
  16. jhanlon303
    7 Sep 2006
    Now u are grammar Nazi?
  17. Guest-23315
    Guest-23315 Guest
    :lol:
  18. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    ^^ 'Lathed' pisses me off too. Eventually it will evolve into lathering parts! :eeek:
  19. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I thought turned applied more to using a lathe with wood; the term "machined" is more common for metal parts.
    Javerh, does the thought of lathering your parts annoy you? Or is it the thought that Nexxo would be asking someone else to lather his parts for him? :D
    I can't see anything in that parts diagram that looks particularly hard to make, but that's just my first thought: I am not an expert machinist (or "latherer") after all!
  20. Guest-23315
    Guest-23315 Guest
    I would always say things made on a lathe are 'turned' and then CAM produced parts are 'machined' although either is better than lathed.
