Case Mod - In Progress So Say We All - BitFenix Prodigy, UPDATED 11-1-13
Discussion in 'Project Logs' started by JitsuSparty, 25 Aug 2012.
  1. JitsuSparty
    JitsuSparty Minimodder
    25 Apr 2011
    Ok so Project Log, right here goes...
    Introduction:
    Basically I have all my media on a NAS drive and one day I got fed up of having to move my main PC every time I wanted to watch media on my TV. So I started looking around the net to see what was out there, cutting a long story short I came across the BitFenix Prodigy and it seemed ideal for what I wanted to do.
    So I ordered one online without thinking about modding it - then I came across a few mods online (watercooling, powdercoating etc) and thought to myself - hey I could do that :) First case arrived damaged :( but was replaced very quickly so :D but this gave me time to think about a theme for the case Mod.
    The Grand Design
    I started thinking how could I design the mod around my LAN/Uni Nick - but all the ideas were basically a bit s**te. Then I had a bit of inspiration (possibly after a drink or two or more) - a Battlestar Galactica (BSG) themed mod.
    For those of you who dont know what BSG is it's a sci fi show that was remade recently (I watched the original growing up) - and my mod is basically themed around this bit of imagery
    http://hbowatch.com/wp-content/uploads/2012/03/battlestar_galactica_logo-HBO.jpg
    any way I made a few sketches (I will look to post a few perhaps - Im not a great artist)... so heres my progress so far (word of warning my weekend shall be the time when I can work on this so expect weekly updates)
    Project Log
    25/8/12
    So the case arrived - first thing I did was to take it apart slowly - but not slowly enough, managed to snap one of the plastic tabs clean off (job for araldite later in the project). I then drilled out all the rivets on the case (some with the application of hammer and screwdriver).
    The case mod revolves around creating a window in one side and a motif cut/etched into the other side. This involved swapping the sides over, as I removed the pcb board with the power supply rest button etc.
    As I am sure you know sqaures don't exsist in BSG - everything remotly rectangular seems to have the corners cut off - so I started by sketching up the area to be cut out to make the window. I also printed out a stencil to get an idea of fonts to use later on, the initial idea was to put the acrylic on the inside of the case - so I could just glue it on and not worry about it having to look too neat.
    Anyway the acryllic arrived and I realised that the clearance inside the case between the side panel and internals isn't enough to put the window on the inside :( so I had the idea - why not put it on the outside and 'carefully' rivet it on.
    So as you can see from above I have cut out a very rough template for the window... all I can say is safety specs are a must, acrylic seems to like breaking, and my Dremel wannabe (from Maplins) kept throwing little pieces of acrylic into my face.
    anyway plan for tomorrow is to try and start cutting out the metal for the window. As well as try to get my sketch pics onto here.
    adidan likes this.
  2. JitsuSparty
    25 Apr 2011
    Reserved for update
  3. JitsuSparty
    25 Apr 2011
    reserved for another update
  4. JitsuSparty
    25 Apr 2011
    Update 29/8/12
    So this is my initial concept design - the aim is to focus on the two side panels, firstly putting in a side window (mentioned above) and then secondly getting the phoenix from this cut into the side
    Seeing as I work at an engineering company I had a chat with the guys and had my expectations scaled back a bit - as the clearance between the lines is too tight to laser cut or get made. So back to the drawing board there.
    anyway I plan to make some more progress over the weekend.
  5. Tangster
    23 May 2009
    Instead of getting it cut straight out of the side panel, what about getting the pieces cut separately then mounting it to a clear plexi window?
    Apophis54 likes this.
  6. JitsuSparty
    25 Apr 2011
    Now you just thought of the solution I did, currently in the middle of sketching it out on some paper :)
  7. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Just on the second season of BSG now! have to say it's awesome and your mod looks to be the same :D
    Good luck :D
  8. JitsuSparty
    25 Apr 2011
    Thanks - and I do plan this mod to be spolier free.
  9. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Especially the episode when....... :D
    In case you have not seen this :Colonial Warbook, it has lots of artwork etc might inspire something. :dremel:
  10. Editor22
    3 Jan 2009
    Glad to hear it :) I can come back now lol
  11. Carrie
    Carrie Multimodder
    18 Nov 2010
    There's a guy Teelzebub knows who does very detailed work on case panels etc. which he has some pic examples of. He's very good, does exhibition work etc. Why not contact Tel to see if you can realise what you actually want.
    chrismarkham1982 and Apophis54 like this.
  12. JitsuSparty
    25 Apr 2011
    To be honest - right now I am not sure what I actually want, Unlike the ubiquitous cylons I don't really have a plan and am winging it a bit.
    One thing I do know is I want to get my hands dirty as much as I can - so will be borrowing my mates mill and power tools in the near future.
  13. Teelzebub
    27 Nov 2009
    Just seen this, Yea the guy I know could do that in his sleep, tbh he's pretty busy doing big projects really.
  14. adidan
    25 Mar 2009
    BSG mods need rep, have some mate. :)
    Think I just gave you 4 lights :)
  15. Teelzebub
    27 Nov 2009
    Yea it was only 4 Dan I would have expected better of you :p
  16. JitsuSparty
    25 Apr 2011
    Thanks for the rep :)
    anyway a quick update preview before I hit the sack.
    Update 29/8/12 part B
    So having done a few sketches this evening and looked at the case I decided I need to get a bit more color into the project, so the plan is to cut a ~ 10 cm diameter hole in the side of the case. I plan to put a circular piece of acryllic in the hole (possibly colored) with a decal/symbol on it that will be back lit from within the case.
    as for the main window - I am torn between a centurion etch for the window or Gaius Baltar (My favorite BSG character - mainly from series 1 tho)
  17. jamesriley94
    jamesriley94 What's a Dremel?
    22 Jul 2012
    One of the first proper prodigy mods I've seen - Interested to see where this heads
  18. jon
    jon Chief Phrenologist
    26 Aug 2009
    You had me at "So say we all ...." :)
  19. whatsthatnoise
    whatsthatnoise What's a Dremel?
    21 Mar 2012
    Woaah, I hate that egocentric maniac! :wallbash: I'd go with the Centurion, ofc.
    Love the series though, should make an awesome theme for a mod. :thumb:
  20. jon
    26 Aug 2009
    ah, but ... where goes Gaius Baltar, so goes Caprica Six ...:clap:
