The No.1 producer challenge
Discussion in 'bit-tech Folding Team' started by saspro, 8 Aug 2009.
  1. spunkymonkey
    spunkymonkey phoenicis wannabe
    24 Apr 2009
    cheers matey :thumb:
    spunky
  2. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Donator CustomPC
    Team Custom PC & bit-tech (35947)
    Score 433378 (certificate)
    Donator Rank 16459 of 1274460
    WU 406 (certificate)
    Date of last
    work unit 2009-08-14 12:09:16
    Active processors
    (within 50 days) 78
  3. confusis
    5 Jan 2006
    Still ranked 367 in our own team :/
  4. saspro
    saspro IT monkey
    23 Apr 2009
    That's not bad for a couple of days work & it is out of 6000+ users.
    Should only take a few days to hit top producer methinks
  5. confusis
    5 Jan 2006
    Are we aiming for top producer outright or just in the team?
    EDIT: read the op dummy >.<
  6. chin913
    chin913 忍び So say we all
    26 Apr 2009
    Now changed over 2 VMware players should be good for about another 4.5k :)
    Sod it just added 2 more Vmware clients another 4.5k Come on rest of you folders out there lets have some fun. Over 1000 hits the thread has had if only we could get all the folders who have stopped to start again
  7. chin913
    26 Apr 2009
    Both sounds good to me. I have many more to change over when I get time
  8. confusis
    5 Jan 2006
    If I could get my GPU client and my CPU client to play together nicely i could add 500ppd to the cause... maybe when my dual core arrives next monday?
    I load either client at startup, then manually add the other client and both grind to a halt
  9. confusis
    5 Jan 2006
    Do I have to use a VM to get the cpu client to work at the same time as the gpu?
  10. saspro
    saspro IT monkey
    23 Apr 2009
    No they'll both work together without using VM's
  11. confusis
    5 Jan 2006
    according to the logfile, when the gpu client is already running, i start the cpu client and a 'kill signal' is sent to the gpu client
    [07:58:43] Got kill signal -- issuing INTERRUPTED core shutdown
    [07:58:43]
    [07:58:43] Folding@home Core Shutdown: INTERRUPTED
    [07:58:47] CoreStatus = 66 (102)
    [07:58:47] + Shutdown requested by user. Exiting.
    Folding@Home Client Shutdown.
  12. saspro
    saspro IT monkey
    23 Apr 2009
    Is that the standard client or the smp one?
  13. saspro
    saspro IT monkey
    23 Apr 2009
    CustomPC currently in producer position 59 exc pande & anon.
  14. confusis
    5 Jan 2006
    standard client - single core at the moment
  15. confusis
    5 Jan 2006
    43rd in points production for the week overall
    9th for today :eek:
    62nd for the last 24 hours
    that's including anon and ps3 in the ranks
  16. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Have you set Configure -> Advanced -> Core Priority to Lowest Possible for the standard CPU client and to Slightly Higher for the GPU client, and on the same page Machine Identity should be different for the two clients (default is 1 for CPU and 2 for GPU)
  17. confusis
    5 Jan 2006
    will have a look in the morning :)
  18. spunkymonkey
    24 Apr 2009
    i do frequent these forums on a regular basis unicorn but ive only have time to read just lately.
    ive had a shedload of paperwork to do for my accountant which as tied me down for about 5 weeks now,although i have managed to find time to buy 2 new cases to house my 2 most important rigs (my gaming and browsing rigs)
    boothy (who is on these forums to) is my humble paperboy and hes been helping watercool and rebuild both the rigs,one in a coolermaster haf932 and the other in a coolermaster cosmos.
    i now have all my rigs folding for customPC and if the weather cools down a bit i may fire the other 2 up that i switched off a while ago because of the heat in my comp room.
    all the best spunky
  19. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    I can move some clients over if you like.
    Maybe my CPU ones.
    Id like to keep my GPUs on my name though as im so close to being in top 1000 in the team :p
  20. confusis
    5 Jan 2006
    CustomPC is 2nd in the team for production :D
    27th overall for weekly production
    33rd for last 24 hours
    Look:
    1 PDC Pande Lab 5,593,220 1,693,171 16,777,215 224,728,195 4,117
    2 PS3 Default 1,248,778 828,662 8,317,672 1,538,462,621 6,569,525
    3 anonymous Default 1,324,231 733,663 8,707,821 551,224,592 3,025,654
    4 CustomPC Custom PC & bit-tech 111,675 256,240 781,723 784,185 743
    4th for 'Today'
    Which means FIRST excluding the anons/ps3/stanford's own lab!!!!!!
    Part of the goal achieved?
