Memory 12 GB for Gaming
Discussion in 'Hardware' started by Bugste81, 27 Dec 2011.
  1. Bugste81
    Bugste81 Stephen
    16 Mar 2010
    Hi I'v got:
    CPU: Intel Core i7-930 clocked 4 GHz
    GPU: GTX 480 SLI
    Hard disks: 1X 64GB Crucilal M4, 3x 1TB Samsung F3, 1x 2TB Samsung F4
    Memory: 6GB Corsair 1600GHz
    Motherboard: Asus P6X58D-E
    Sound card: Creative X-FI Titanium Pro Fatal1ty
    Power Supply: Antec Quattro 1000W
    Cooling: 2x Silver stone 180mm Air Penetrator, 2x 120mm Sharkoon Silent Eagle
    Would it be worth adding an extra 6GB of Ram to my system? I use it mainly for games. Would it have any effect on overclocking? Thanks.
  2. longweight
    7 May 2011
    No for games, might have to up the voltage to keep it stable.
  3. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Nope. Check that your memory is running under the XMP profile though, I have a similar rig to you and the memory defaulted to something much slower.
  4. Kaze3
    Kaze3 What's a Dremel?
    28 Apr 2010
    I'd say don't worry about the extra RAM if it's only for gaming. A single game process is going to be limited to something like 4GB anyway (somebody correct me if I'm wrong). You're only really going to need more than 6GB for very heavy multitasking or audio/video editing.
    Just make sure you put the three RAM sticks in the correct slots so that they run in triple-channel mode. Remember, you can always pick up another 6GB as an upgrade later.
  5. Deders
    Deders Modder
    14 Nov 2010
    when you consider that 32bit windows limits 2gb for the OS and 2GB for applications by default, I expect that most games will be developed with this in mind.
    3lusive likes this.
  6. Bugste81
    Bugste81 Stephen
    16 Mar 2010
    Cheers for the replys. I will be saving my £35 in that case.
  7. bulldogjeff
    2 Mar 2010
    I found that on my P6 I didn't have to up the voltage but I couldnt overclock as easily, But on my UD3 I had to raise the QPI slightly to get it to run solidly with a big overclock.
  8. GoodBytes
    20 Jan 2007
    Games are in 32-bit.. so they are limited by Windows to 2GB.
    Assuming a gaming system, 4GB is enough. 6GB is playing it extra safe (game, Windows, background programs, and room for large programs left on the back while playing, and/or for the future potential 64-bit games that actually consumes more than 2GB of RAM).
  9. lp rob1
    lp rob1 Modder
    14 Jun 2010
    If you are using a better OS than Windows, like a Linux variant, then the extra 6GB of RAM will let the OS cache frequently used stuff into memory and increase responsiveness. I upgraded to 12GB for this reason. Just for gaming - you won't see any difference. Even so, memory is so cheap nowadays that unless the extra £35 makes a significant difference, there is no reason not to go for the extra RAM. If RAM was this cheap when I was building my PC 2 years ago then I would have put 24GB into it straight away.
