News AMD launches Phenom and Spider
Discussion in 'Article Discussion' started by Tim S, 19 Nov 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DougEdey
    5 Jul 2005
    Is there an AMD chipset without IGP but just does something brilliant?
  3. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    weeeeeeee :D
  4. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    anyone seen one for sale anywhere yet?
  5. MrABC
    MrABC What's a Dremel?
    23 Mar 2002
    Nope, haven't seen any around yet. Maybe they will hit retailers tomorrow? I've read some of the reviews about and phenom doesn't look like it will be competitive against intel at the speeds AMD are releasing them. HardOCP overclocked the phenom upto 3ghz and it was just about competitive with the Q6600. I'd like to see how overclockable the final processors are because the reviews Ive read were engineering samples and overclockability were a mixed bag.
  6. GoodBytes
    20 Jan 2007
    From Anatech, The Phenom 2.6Ghz is near the same level as the Intel Core 2 Duo 2.4Ghz...
    So, let's wait for the Phenom 2.8Ghz and it should pass the Intel Core 2 Duo 2.4Ghz, and would be cheaper, as we know AMD.
  7. Guest-23315
    Guest-23315 Guest
    i think Vadim have some of these...
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    there going to be really hard to find
  9. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    if CrossfireX allows for me to start w/ 2 video cards (same family) upfront and then add 2 more (or 1 at a time depending on budget) from a newer family w/ more capabilities than the other family, then I'm going AMD because that says to me that they are looking out for our dollars. I don't want to have to be stuck w/ having to replace my older cards that I spent a pretty penny on not long ago (SLI).....I spoke to Tim about it and he said he was going to look into it...hopefully by this summer I will have this question, along with multiple others answered because I hate monopolies and I will always be shooting for the underdog, it's just whether the underdog is looking out for my interests as well.....if so then I know where my fun money is going....
  10. Anakha
    Anakha Minimodder
    6 Sep 2002
    Personally, I would rather have this with SLi compatibility. 2 8800GT's will wipe the floor with any ATI/AMD card, and come in cheaper too.
    The other thing I'd like to see is Matrox-Style "Surround Gaming", with 2 8800s, one providing the front view, and the second providing the two side views.
  11. centy
    centy DFI Nutter
    20 May 2007
    How does a single monitor provide two side views? Surround gaming doesn't work with only two monitors since your crosshair or the centre of the screen ends up at the outer edge of each of the monitors.
  12. JumpingJack
    JumpingJack What's a Dremel?
    30 Dec 2006
    Dude, these are the final processors... this is a launch event.
  13. MrABC
    23 Mar 2002
    :duh: I stand corrected. I saw the image of AMD's overdrive app on anandtech's coverage and it said "AMD Engineering Sample", so...thought that it might be engineering samples :/
  14. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    More interestingly, unlike the Intel Core 2's I think you could run two Phenoms on one board. Eight cores... hmmmm... :brrr:
  15. JumpingJack
    30 Dec 2006
    Yeah, Anand did not trek to the dog and pony show, see page 3 of his review:
    http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3153&p=3
    There are only a few sites with their own CPUs, most of the reviews generated the data from AMD's tahoe excursion, arstechnica published a commentary here:
    http://arstechnica.com/news.ars/pos...-out-of-the-gate-to-a-lukewarm-reception.html
  16. moshpit
    moshpit What's a Dremel?
    31 Oct 2005
    I'm disappointed. Pure and simple.
  17. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    The geek collective took a deep breath and uttered one single word as one:
    "Meh"
  18. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Oh AMD, why do you crush my hopes yet again? I want the heyday of Athlon 64 back.
  19. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i await for bit's review
  20. Guest-16
    Guest-16 Guest
    I still can't wait to get a hold of one though. Since we don't know when one will arrive I'll have to be reviewing 790FX boards with normal AM2 CPUs in them for now - at least now you'll see the difference between AM2 and AM2+ as a direct drop in replacement since it's socket compatible :) And we'll finally get some AMD boards done again - I can't believe I've literally done about 3 or 4 in the last year :|
    Having said that too, an Intel X9770 turned up on Friday :D So we'll be having fun with that as well this week (once I've finished certain Maximii)
Tags: Add Tags
