Other Any 'vapers' out there?
Discussion in 'General' started by Sentinel-R1, 13 May 2013.
  1. bringmeto77
    bringmeto77 What's a Dremel?
    16 Apr 2015
    I love my vaping, especially some blueberry mmmm :)
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    Had a brainwave & modded my Russian 91 with being sick of the frustration of trying to clamp the coil wire under the head of the screw (so fiddly), filed tiny channels for the coil wire to fit in to make clamping the coils down far better & easier, it works awesome, my biggest gripe with the russian solved. :)
    Perfect builds every time now.
  3. Ljs
    Ljs Modder
    4 Sep 2009
    I run out of my online orders so popped into my local shop... So expensive (£6 for 10ml)!
    Can anyone recommend a place to order ingredients online so I can start mixing my own? I'd only really be looking to mix up mint/menthol, and would prefer going by a recommendation rather than throwing my cash at a cowboy outfit.
    Apologies, I know this info is in the thread somewhere but I had a quick scan jumping pages and couldn't find it for the life of me. :/
    Also while I'm on the subject, has anyone used an app called Liquix E-Liquid Calculator? I've heard pretty good things about it and was thinking about giving it a whirl.
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Ljs likes this.
  5. Fishlock
    Fishlock .o0o.
    22 Nov 2004
    Anyone tried Space Jam juice yet? Managed to get Omega and Pluto in a shop in Southampton whilst on holiday. Omega is peaches and cream, it's pretty beautiful. Pluto is watermelon, no idea why I got it as I don't like watermelons...
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    I use eJuice Me Up for getting the exact amounts to mix.
    http://ejuice.breaktru.com/
    Bought from all these places & great service from all.
    https://www.chefsvapour.co.uk/25-concentrates
    or
    http://vapable.com/product-category/diy/
    or
    http://www.thealchemistscupboard.co.uk/DIY,_Mixing,_Flavours,_Nic,_Etc/cat1708885_1667536.aspx
    Bottles & caps
    http://www.naturallythinking.com/categories/Bottles-&-Jars/Plastic-Bottles/
    VG or PG can be bought on ebay at £8 a litre.
    Nicotine is cheapest at chefsvapour or is the cheapest I've come across.
    Ljs likes this.
  7. Ljs
    Ljs Modder
    4 Sep 2009
    Thank you both, I'll do a little research and place an order later.
  8. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    I've never been one for fruity vapes - tending to stick with the "Tobacco" flavoured ones.
    I was exposed to some SpaceJam Pluto last week, and I Hnnggggh'd my pants off.
    Is this a good way to dive into the better liquids?
  9. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    considering stopping vaping as its costing to much :(
    £9 for 15ml which can go in 2 days in my subtank is proving to be very expensive....
  10. shindead
    shindead What's a Dremel?
    14 Aug 2014
    I stopped purely for that reason..... it gets as expensive if not more so than smoking
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    DIY is where the savings are at Otis.
    The mothers milk clone I made recently I cut 50/50 with PG so doubled my amount to 1.6 litres & it's really nice, that cost me less than £60.
    I just see the ready made juices as good inspiration to make clones of. :D
  12. Tichinde
    Tichinde Minimodder
    1 Sep 2010
    Unionvape is the way forward.
    3 x 100ml bottles for £19 ish.
    I bought them ages ago and I'm just getting to the end of the first two now....
  13. shindead
    14 Aug 2014
    Wow thats very cheap :eek: is it actually good quality though?
  14. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    :eeek::eeek:
    100 ml Propylene Glycol / Vegetable Glycerine =£3
    72 Mg/ml Nicotine = £12
    Flavour £3 x 2 or 3
    So about £20 quid give or take every couple of months
  15. Tichinde
    Tichinde Minimodder
    1 Sep 2010
    I like them (went apple, cherry and lime), as does my mate who put me onto them.
    Not had any problems, but between that and the shite they sell in my local vape shop I'll take the Union stuff.....
  16. jrs77
    jrs77 Modder
    17 Feb 2006
  17. Otis1337
    28 Nov 2007
    Unionvape is mad cheap, surly is going to be nasty for that price?
    is thealchemistscupboard's pre made stuff ok?
    there not getting very good independent reviews.
    Last time i had VG that low if was really rough. is the way i understand it right, that VG gives you a smoother vape but does not carry the flavors as well? so with higher PG you will get better flavors but it wont be as nice to use?
    Looking around triphammer.co.uk seem to looks pretty good. positive independent feedback
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    I expect it would be fine, not tried it.
    VG produces bigger clouds, PG lets you use less flavour concentrate, I did all my juices as high VG so put extra flavour in to have best of both, 1 of my juices was too thick so was prone to not soaking the wick enough, added PG & it was fine.
    You could always buy high strength juice 24mg nicotine & dilute it 4x with 50/50 PG/VG, quadrupling the original bottle.
    Was mentioned earlier in this thread, I've tried it & it works fine. :)
  19. jrs77
    jrs77 Modder
    17 Feb 2006
  20. mrlongbeard
    31 Jan 2010
    Never tried the alchemist cupboards pre made stuff so can't comment.
    I use them for all my diy liquids, nicotine, VG and flavours, always been good for me.
    I vape 100% VG, less a little for the flavour concentrate @ 0.5 ohms @ 12ish mg.
    But I'm not precious about my atties, use em for a week and bin em, hell they're only 2 quid a pop, or if I'm using kanger pre made coils in the RDA deck pennies each.
