Hardware Be Quiet Dark Rock Advanced
Discussion in 'Article Discussion' started by Claave, 18 Mar 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. guvnar
    guvnar What's a Dremel?
    19 Aug 2010
    I've got this cooling my 4.5GHz overclocked 2500K and it is whisper quiet!
    I can't fault it at all and it fits inside my Antec 300 case easily.
    The only problem I did have was gettign hold of one as it was out of stock everywhere for a long time but Scan came good in the end.
    Bag yourself a great cooler - if you can find one.
  3. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    I just spoke to Be Quiet! about this, and they underestimate demand, so have put another batch into production ASAP.
  4. Xir
    Xir Modder
    26 Apr 2006
    they sell the fan alone as well, i suppose they would make for good, silent casefans
  5. Combatus
    16 Feb 2009
    Click and see!
  6. wbdog206
    wbdog206 not me
    15 Jan 2007
    Was the US price unavailable or is the cooler unavailable in the US.
    I can't find one around where I live.
  7. yogev_ezra
    yogev_ezra Green Gadgets Ltd
    26 Feb 2011
    Why something with a score of 8 gets an Excellence Award (that means "10")? :jawdrop:
    Please, either give it a score of at least 9, or change the award to "Recommended" :idea:
  8. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Sorry for the confusion, we talked about this internally this morning as we're planning on updating the scoring and awards on bit-tech and bit-gamer shortly. A side effect of this is that this particular product only gets an eight in the current score system, but is so good its worth an Excellence Award.
  9. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    To the best of our knowledge you cant get any Be Quiet! products in the US at the moment. Sorry.
  10. Legendmir
    Legendmir What's a Dremel?
    6 Dec 2007
    No testing for LGA775? :(
  11. law99
    law99 Custom User Title
    24 Sep 2009
    When I get more money, it's going to between this and a H50... but I'll certainly be buyring some of the fans!
  12. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    i'm impressed. asus g73jh arrived today, WOOHOOO, but i'll be torn weather to go with Be Quiet Dark Rock Advanced or corsair h50 when intel releases x68 chipset and cpu's
  13. jon
    jon Chief Phrenologist
    26 Aug 2009
    Would love an additional noise and cost level against these fans as well. Always good to know how well it cools, of course, but when you tell us "it's really quiet" without comparing it in a similar chart to its cooling capability, it leaves us hanging. Then take a combined cooling / noise ratio, and compare cost against other fans on the list. That gives us a true measure of its value.
  14. Zaim
    Zaim Minimodder
    18 May 2010
    Not bad, this is the cooler i was very interested in as its priced the same as a Frio but is quieter. Little disappointed with the AMD results but i'd rather it be a few deg's hotter compared to a frio than have a super loud cooler.
    Edit: just noticed the review says the voltage was 1.6V on the 1090t, thats very high for a small overclock.
  15. hardski
    hardski What's a Dremel?
    22 Aug 2006
    How easy is installing the cooler as ive seen in other reviews its a right pain and needs 2 people to get it in?
    Also what ram would be be compatible as you never seem to to take into account the ram heatsinks getting in the way of these huge cpu coolers.
    Thanks
  16. guvnar
    19 Aug 2010
    I will say the cooler was a bit fiddly to fit - would have been helpful if I had three arms - but I got there in the end but I did have the motherboard out of my case (no motherboard cut out on my old antec 300)
    I definitely felt it was worth the 10 minutes effort it took.
    Also I only have standard corsair ram with no extra heatsink but there appears to be some considerable clearance so I'm not worried about adding more ram in future if I want to.
    All in all it's been a great purchase - oh! and it looks the business after I cut a window in the side panel!!!
    :thumb:
  17. Kris
    Kris Lord Lolwut
    6 Jun 2008
    how can there be a difference of almost 20C in the delta between socket 1155 and am3?
    does it mean that either:
    - 1155 socket cpu-s are making really bad contact with all coolers
    - am3 cpu-s require much higher cooling power and lower efficiency coolers show their shortcomings?
    - testing results are skewed (don't believe this at all, just trying to come up with all explanations).
    just seems that cannot trust any results.
    for comparison: http://www.bit-tech.net/hardware/cooling/2009/02/19/ga-1366-cpu-cooler-group-test/7
    here all the results seem quite close to each other.
    for comparison: http://www.bit-tech.net/hardware/cooling/2010/03/22/akasa-nero-s-cpu-cooler-review/2
    again, here most seem very close on am3, but very different results for 1156.
    can anyone explain? i'd like to know for example, where my cooler stands, but from all these results, i have no idea what's going on :)
  18. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    There are two main factors at work here:
    1. The Socket AM3 CPU we use has a significantly higher TDP than the LGA1155 CPU we use.
    2. Socket AM3 CPU also need to be overvolted more than LGA1155 CPUs (despite being less overclockable).
  19. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    I would agree and cpus more so phenoms are very good for space heaters using the stock heatsink at stock speeds can result in tosty heatsink and noise (the athlon ii are ok thought, as long its an real one not an phenom with L3 turned off and 2 cores)
  20. Kris
    Kris Lord Lolwut
    6 Jun 2008
    Hmm, so maybe the am3 socket shows the real max performance of a cooler? So would it not make sense to choose the cooler that performs best on am3 and use it on a socket like 1155(if compatible), while overclocking the s**t out of your 2600k? :)
Tags: Add Tags
