Cooling Best 120 fan
Discussion in 'Hardware' started by morris8809, 5 Nov 2008.
  1. morris8809
    morris8809 Minimodder
    30 Dec 2006
    Im looking to replace a couple fans in my case with new quieter fans. I want something that moves plenty of air but still is quiet. I need 120mm sized fans and i will have them plugged into a fan controller. If you know of any fans that fit this bill please post them. Thanks
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Yate Loon D12SL
  3. morris8809
    30 Dec 2006
  4. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    yeah, they're just ones with LED's, same fan in principle.
  5. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    http://www.ebuyer.com/product/124810
    If you want blue LED, I love these. I have three in my case and they look great. Can't remember what the sound is like as I have them motherboard controlled and as such they're silent but fairly slow.
    The chrome blades make them look excellent. Plenty of reviews on that link too...
  6. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I know it's a bit general, but Xilence fans are wonderful. You can usually find em all over ebay. Very quiet (as the name would imply) and good displacement. The cables on them are usually annoyingly short, but you can always plier and electrical-tape your way around that :)
  7. morris8809
    30 Dec 2006
    im in the US btw, also i think im going to order two of these yate loon ones as they look pretty good and are cheap on top of that.
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If you want the bling go for that LED one; if you want the quietest, avoid hard clear plastic frames that more easily transmit vibration to the case or get rubber mounts.
    Another fan to consider is the 1600RPM Scythe Slipstream - higher flow but noisier at the full 12V but with a controller you have a wide range of performance available and it should be silent at around 6V.
  9. morris8809
    30 Dec 2006
    they dont have to be the quietest but i just dont want it to sound like a jet taking off like the 120s i have in it right now do.
  10. ricickle
    ricickle Reamer
    27 Mar 2008
    I would strongly disagree there i have 1 of these in 120mm and its louder than my cosmos s with its stock side intake fan and 3 coolermaster 120mm fans all put together.
    i thinks its due to the bearings being crap in them. both of mine rattle like nothing else on earth
  11. pizan
    pizan that's n00b-tastic
    25 Apr 2008
  12. morris8809
    30 Dec 2006
    ive already ordered the led fans that i posted earlier. Ill probably soft mount them or use rubber grommets between them and the case. Will have to wait and see how much vibration they send through the case. thanks guys.
  13. boiled_elephant
    14 Jul 2004
    :( My 90mm was quite nice, but if that's the case, don't risk it, original poster. I'm surprised, they're quite good on paper - must be wear and tear like you say, or maybe you got unlucky :) at any rate, airflow is good. I'll put some in my next build and see if they're noisy, if they are I'll try rubber padding them as suggested above. Never thought of that before, but it's common sense really.
  14. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    the best? noctuas. the one you should buy? scythe or yate-loon.
  15. ComputerKing
    8 Sep 2006
    Enermax Clusters are more than kick!!!!! they are pure awesome. That what I think and what I feel :) I fall in love with those fans :(
  16. morris8809
    30 Dec 2006
    the fans are coming in today. ill post some pics and let you all know what i think of them.
  17. Vimesey
    Vimesey What's a Dremel?
    21 Jun 2008
    Noctua's, the only thing letting them down is teh price :(
  18. morris8809
    30 Dec 2006
    fans are in and installed and let me just say that for 6 dollars these things rock! They dont move as much air as the old ones but at 12v you cant tell that they are even running. :rock:
    only thing left to do now is to figure out why my ultra psus fan is running so loud, if not for it my pc would be really quiet.
  19. notatoad
    25 Jun 2004
    time for some :dremel:. rip that psu open and put a yate-loon in there.
  20. morris8809
    30 Dec 2006
    :dremel: is right you just read my mind.
