Windows BF3 noob questions thread
Discussion in 'Gaming' started by YEHBABY, 5 Nov 2011.
  1. RevDarny
    RevDarny Minimodder
    27 Oct 2011
    So last night I may of hacked off many players by noob tubing like crazy just to unlock smoke. Alas I may of had a few, (not normal for a school night) and i've only killed 15 people with it.
  2. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
  3. Achilleas.k
    Achilleas.k Minimodder
    23 Oct 2009
    It doesn't "follow the bullet", it just keeps you scoped so you can see where it goes. In BC2, the default behaviour is to rearm the rifle as soon as you fire. Holding the fire button delays this. It is indeed the best kept secret in the game, as I just discovered it now while reading through the thread and confirming what it does exactly on the wiki.
    In BF3, the default behaviour is to stay scoped (when using bolt action rifles). You need to un-zoom for it to rearm. The straight-pull bolt allows you to rearm without going out of zoom.
  4. RevDarny
    RevDarny Minimodder
    27 Oct 2011
    With the mortar do you have to get so many kills before smoke is unlocked?
  5. wyx087
    wyx087 Multimodder
    15 Aug 2007
    no idea about that. sorry. try press 2 and mortar as close to you as possible. you should be able to see if it's smoke or explosive round.
    but here's a few tips i found helps greatly:
    1. press 1 and 2 to constantly switch between smoke and explosive rounds. allows a relatively constant stream of mortar and also helps your team with smoke screen.
    2. on Seine crossing, try aim for the wall of a building. it makes rocks fall on people's head. instant death, and much more spread than a single explosive round.
    3. play the choke points and see where people usually hide behind (eg, Alleyway on Bazaar), then mortar those points for some lucky multikills.
  6. RevDarny
    RevDarny Minimodder
    27 Oct 2011
    Thanks for the advice. I've been using the CPC/BT server to test things out when it's empty. I only ever use the mortar in Rush really as this helps to create a line when defending or attacking.
  7. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    It comes with smoke and explosive rounds. Just press 2 to select smoke. :thumb:
  8. Bede
    Bede Minimodder
    30 Sep 2007
    I 2nd this, the first thing I did when I unlocked the mortar was to put smoke rounds down on a rush objective. You don't need to get kills with it, unlike the M320. Wuyanxu is right about the M320, not giving players smoke as default is one of the worst mistakes DICE made with BF3.
  9. RevDarny
    RevDarny Minimodder
    27 Oct 2011
    That's true, smoke is so useful especially in rush.
  10. Sketchee
    Sketchee Suddenly, looters! Hundreds of 'em!
    23 Oct 2010
    If you look at the crosshair when using the mortar you'll notice it moves ever so slightly down when you press 2 to select smoke. Other than that I haven't noticed any other way to see what you're using... bit daft really.
  11. Tibby
    Tibby Back Once Again
    9 Oct 2005
    On a kinda-side note, can you imagine if DICE had a community controlled Defect Log, with the community voting up the most pressing problems with commenting enabled, and the lesser ones obviously hanging around the bottom of the list.
    Would most likely not work to everyone's favour, but would be interesting to see and DICE would still decide what gets changed.
  12. Bede
    Bede Minimodder
    30 Sep 2007
    http://getsatisfaction.com/battlefield3/login
    Edit:
    having bitched about smoke earlier in this thread I actually played a Metro server this afternoon where players were putting down smoke. Admittedly only one or two, but it makes a huge difference when you need cover to push up.
  13. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Wrong thread >.<
  14. Murphman357
    Murphman357 What's a Dremel?
    29 Apr 2012
    TEAM
    Im also very new to BF3 and enjoying it. Is there a place you can find new team players? :rock:
  15. Bede
    Bede Minimodder
    30 Sep 2007
  16. adzc1987
    adzc1987 Minimodder
    19 May 2011
    To answer a few question gone unanswered -
    Where is that chat - Press H, you can cycle between -Popup(default), Hidden and always
    Cooking Nades - press 5 to select the nade, hold down mouse1 to cook.
    or
    Press G to get out the nade, hold down mouse1 straight away. I think this does not cook the nade however and you will do a normal throw upon releasing (at work so cant check)
  17. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Sorry what exactly does cooking the nade do?
  18. Achilleas.k
    23 Oct 2009
    Starts "ticking down" in your hand so it explodes faster after you release it.
  19. Bede
    Bede Minimodder
    30 Sep 2007
    BF3 grenades can't be cooked.
  20. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I didn't think they could. They also don't get dropped when you die with one in your hand. The same as rockets go missing when you die firing one at enemy. I miss being able to kamikaze a group of people with a grenade in hand!
