Distributed Bit-Tech Folding@Home Team (CLOSED: now superseded by joint CPC/bit-tech team)
Discussion in 'Software' started by Byron C, 2 Aug 2003.
Thread Status:
Not open for further replies.
  1. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    I'm starting to lose faith in FAH. It's a good cause but I'm pi**ed off with all the fan noise :D
  2. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    how big is an average wu?
  3. Amd_Lover2004
    Amd_Lover2004 What's a Dremel?
    3 Feb 2005
    Gave it a quick try but I cant be bothered with spending 2-3 hours on a sig, meh.
  4. alextwo
    alextwo <a href="http://forums.bit-tech.net/showpost.php?p
    29 May 2003
    took me no more than about 20 minutes to knock this sig up, it's not the prettiest but does the job. :thumb:
  5. D4VID
    D4VID What's a Dremel?
    17 Nov 2004
    Don't know that theres any such thing as a 'average' WU, they range from little 30 credit ones that'll complete in a few hours to monster 600 credit WUs that can take several days to complete. Mainly depends on the speed of the pc you're running it on though
  6. kenco_uk
    28 Nov 2003
    Aplogies beforehand, but just testing to see if sig is working now.
    bleh - can't get the thing to work. It's looking like it should work, as the sig.log file is showing it's created the sig, runnin mksig.pl does its thing with no errors (which is better than I was getting before), but it no worky. I followed the instructions, including changing the forums name.
    Ah, hang on a moment... just going to try something out, just got to find some thread I can reply to now :) Sig won't update with just an edit to a post.
    :sigh: I give up.
  7. uwannabigmak
    30 Dec 2004
    if theyve already done the wu, why do we have to do it again?
  8. Amd_Lover2004
    3 Feb 2005
    To make sure the calculations are correct, and so they can see if there are any inconsistancys in the folded protiens, Im just pulling this out of my A$$ here but its somewhere along those lines... Plus some other stuff aswell.
  9. D4VID
    17 Nov 2004
    straight from the Folding@Home FAQ:
  10. D4VID
    17 Nov 2004
    @ kenco: its possible that your sig is too long. If it is more than 500 characters (including all the vB code) then the mksig.pl will run just fine but the forum won't accept it. When I was doing mine, it had to shorten it several times before it would work. In fact, although the forum rules state the limit as 500 characters, I found that it would accept about 600, maybe it doesn't count spaces
    EDIT: seems like 500 characters exactly including everything now that I've experimented with it for a bit
  11. alextwo
    29 May 2003
    We've just moved into 300th place! Good going guys :thumb:
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    I don't think it counts VBcode.
  13. D4VID
    17 Nov 2004
    I'm not sure about that, because I used this sig_gen.pl as a basis for my sig. First time I tried, it had a colour gradient on the WU name with loads of color tags and it didn't work because it was too long but when I removed the colour gradient, it worked no problem. Will need to experiment some more to know for sure.
  14. Darv
    Darv Bling!!
    12 Aug 2002
    I think I've finally got this sig to work s I'm just checking. Fingers crossed :lol:
    /edit
    Apparently not :wallbash:
  15. Darv
    Darv Bling!!
    12 Aug 2002
    Sorry for the double post but I think I've actually got it working in some shape or form. :worried:
    /edit. Nope not got it yet. Can someone post their sig_gen files so i can have a look at their code and try and get mine to work.
  16. alextwo
    29 May 2003
    This is how my sig_gen.pl file looks:
    #!/usr/bin/perl -w
    use LWP::UserAgent;
    use LWP::Simple;
    use XML::Simple;
    #Stanford's stats
    $stfd_username="alextwo";
    $team_num=33346;
    $stfd_url="http://vspx27.stanford.edu/cgi-bin/main.py?qtype=userpage&username=$stfd_username&teamnum=$team_num";
    $ua = LWP::UserAgent->new();
    $page = $ua->get($stfd_url);
    open STFD_PAGE,">stfd.html";
    print STFD_PAGE $page->content;
    close STFD_PAGE;
    open STFD_PAGE, "stfd.html";
    while (<STFD_PAGE>){
    chop;
    if (/Total score/) {
    $_ = <STFD_PAGE>;
    s/<[^>]*>//g;
    s/[^\d]*//g;
    $stfd_total_score=$_;
    if (/Overall rank/) {
    $_ = <STFD_PAGE>;
    s/.*\d> //;
    s/([\d]* of [\d]*)[^\d]*/$1/;
    $stfd_overall_rank=$_;
    if (/> WU/) {
    $_ = <STFD_PAGE>;
    $_ = <STFD_PAGE>;
    s/[^\d]*//;
    s/([\d]*)//;
    $stfd_wu_total=$1;
    #my stats
    $eoc_id=107441;
    $url_oc = "http://folding.extremeoverclocking.com/xml/user_summary.php?s=&u=$eoc_id";
    #xml files that will be saved locally
    $file_oc = "oc.xml";
    #get pages off net and store them locally
    getstore($url_oc,$file_oc) if (time-(stat($file_oc))[9] > 60*60*2 );
    #Slurp in XML file
    my $ocstats = XMLin($file_oc);
    #User Variables that can be used
    $rnk = $ocstats->{user}->{Team_Rank};
    $r7d = $ocstats->{user}->{Change_Rank_7days};
    #makes the change in rank as a string
    #"-3 in 7 days", or "+57 in 7 days"
    if (!$r7d > 0) {
    $r7d = '-'.$r7d.' in 7 days';
    else {
    $r7d = '+'.$r7d.' in 7 days';
    print "{size=1}{B}Folding for Bit-tech:{/B}\n";
    print "Total score: $stfd_total_score | WU total: $stfd_wu_total\n";
    print "Team rank: $rnk ($r7d) | Overall rank: $stfd_overall_rank\n";
    print "{url=http://forums.bit-tech.net/showthread.php?t=37317{Join the Bit-Tech Folding Team!{/url}{/size}";
    But remember to change the {} for [] at the print lines and the EOCID
  17. Darv
    Darv Bling!!
    12 Aug 2002
    Cheers. Lets see if it works :cooldude:
  18. Amd_Lover2004
    3 Feb 2005
    Alextwo, could I sleal yours(changing the names of coarse), I am rather busy and cant afford the time to make myself one.
  19. c.cam108
    c.cam108 Minimodder
    14 Feb 2004
  20. kenco_uk
    28 Nov 2003
    Thanks dude, I'll give it another go sometime soon, might pilfer alextwo's code, if that's okay?
Thread Status:
