Briefcase PC
Discussion in 'Project Logs' started by Out50Stang, 26 Nov 2002.
  1. Out50Stang
    Out50Stang What's a Dremel?
    26 Nov 2002
    really? care to elaborate that? i really like that idea, but i don't fully understand it....pics?
  2. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Just like a sliding cover but to open it you push it inwards and slide it behind the rest of the casing. To close (it should have a small lip at 90 degrees) you pull it back across and it springs into the cutout for it and completely hides your fan. It would have to be square or rectangular though.
  3. Out50Stang
    26 Nov 2002
    to complicated, right now my idea is still alluminum mesh filters
  4. ouija
    10 Nov 2002
    Hmmm... I'd stealth them then. You know, fix the screws to the inside of the case.. have you seen the grills that come with cheiftec cases as standard now? They look like 80mm car speaker grills. Very nice, I don't know where you would get them in silver.
  5. Out50Stang
    26 Nov 2002
  6. ouija
    10 Nov 2002
    No the ones I've seen were circular and domed slightly
  7. Out50Stang
    26 Nov 2002
    i ordered 2 of these
    http://www.mcbworld.com/com/SystemCooler.jpg
    so i don't have to make some obvious fans holes right on top, should work well, i hope :)
    stay tuned
    please host images on your personal server
    cderalow
  8. ouija
    10 Nov 2002
    Ah, good plan. Apparently, they have pretty good airflow and aren't too loud.
  9. Out50Stang
    26 Nov 2002
    i got the fans in today, and i also got the cab;e for my video card which will extend the port to the outside of the case, all i need now is a gender changer for that......and do something with the hard drive
  10. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    HOW DAM NFREAKY IS THAT??!
    About 3 months ago I purchased a similar case and started to the exactly the same mod!! WEIRD!!!
    I never finished tho due to lack of time and work and other things.. like needing my server straight away.
  11. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    cool project and nice case, but why did you put the mobo on the right side rather then the left side of the briefcase?
  12. Hindaine
    Hindaine What's a Dremel?
    23 Oct 2001
    det, he wanted the ports to all be internal
    BTW, OD and I just finished doing the exact briefcase pc... shes supposed to be writing a worklog.... ill go whip her till she does it.
  13. Out50Stang
    26 Nov 2002
    it's on the right side, because all the breifcases i see have them on the right with the back of a normal case cut out and put in there, and i don't like that look since it doesn't look like a briefcase after you do that........so it's on the right so i can fit my PSU in there, and have room for the extra wires for all of the ports, which i am extending to the ouside of the case.....i want to keep it looking like a briefcase as much as i can......
  14. Out50Stang
    26 Nov 2002
    it's been while, but i have since addes my side exit fan and cleaned up all the wires with some plastic wrapping :)
  15. Altron
    Altron Minimodder
    12 Dec 2002
    I have the same breifcase! (Yep you've probably heard it a million times)
    The aluminum mesh filters are awesome, they look a lot like the texture of the breifcase.
