Bits Build your own server: Part 2
Discussion in 'Article Discussion' started by Tim S, 24 Jul 2007.
  1. KillerOrca
    KillerOrca What's a Dremel?
    29 Apr 2008
    I would think two different boxes means that it is not box specific, but that is not my main concern as XFCE is too resource heavy to run on my box. I would like to get the ports forwarded correctly but the guide really doesn't apply for my router(Linksys) apparently so would appreciate any troubleshooting tips.
  2. Millusdk
    Millusdk What's a Dremel?
    27 Jan 2008
    Well what I mean is that i belive that the problem is due to some standard settings in the Xubuntu sofware. What linksys router do you have? I have a linksys router myself, so mabye I can help.
  3. KillerOrca
    29 Apr 2008
    I have a Linksys WRT54G version 6, with the latest firmware. I got port 2222 to forward, so if I link to http://probablyforever.serveblog.net:2222/ I can see some SSH and system information, forwarding 80 to 12345 isn't working though and I think it is because I am forwarding a range and not one to one. I can't find those settings though
  4. macky1911
    macky1911 What's a Dremel?
    30 Apr 2008
    finally got no-ip working but it is directing me to the apache-default "It works" screen any suggestions to fix this
  5. KillerOrca
    29 Apr 2008
    Port Forward with your router, the link in the guide will most likely have instructions, unless it is my router...
  6. macky1911
    30 Apr 2008
    i forwarded the ports and now i cannot connect to the server at all. If i leave off the :2222 then i get the it works screen. Checking from the server input localhost into the browser goes to the it works screen
  7. KillerOrca
    29 Apr 2008
    Alright, can you still SSH in?
    Which ports did you forward?
  8. macky1911
    30 Apr 2008
    Yes, I can still SSH in. Not sure why but localhost always returns "It works" , instead of index for localhost.
    I have a SMC 2804WBRv2 router and follwed the instructions to forward ports 2222 and 12345
  9. KillerOrca
    29 Apr 2008
    Well when you access from another machine it shouldn't be localhost it should be the ip address of the machine. Since you can SSH in you can still access the machine fine, the port forwarding just didn't work right. So undo what you did, visit portforward.com and find a guide.
  10. macky1911
    30 Apr 2008
    From a previous entry this appears to be my problem with port forward, my router looks like this
    http://www.portforward.com/english/...804WBRV2/Serious_Sam_The_Second_Encounter.htm
    I will think about upgrading the router soon, but I am still not sure why when accessing localhost from my network it takes me to the apache2-default screen
    http://images.bit-tech.net/content_images/2007/06/build_your_own_server/torrentflux04.jpg
  11. macky1911
    30 Apr 2008
    Are there any good guides for setting up azureus with the web plugin? I am a n00b so the more straight forward the better.
  12. Glider
    Glider /dev/null
    2 Aug 2005
    It shouldn't be harder then installing azureus (through Synaptic or apt) and enabling/configuring the webUI plugin?
  13. macky1911
    30 Apr 2008
    you would think so but Synaptic has an older version and updating through CLI is still a bit new to me.
    Both articles have been great, well written and easy to follow. In the future will there be a TFTP section?
  14. macky1911
    30 Apr 2008
    any suggestions on what I can do to resolvemy localhost not showing the index and showing "it works"?
  15. Glider
    Glider /dev/null
    2 Aug 2005
    Create a 'index.html' file with 'IT WORKS' as a content in /var/www/ :D
  16. macky1911
    30 Apr 2008
  17. Glider
    Glider /dev/null
    2 Aug 2005
    You connected to htpp://localhost/apache2-default...
    You should edit the vhost.
  18. macky1911
    30 Apr 2008
    I am new to linux so what do i need edit vhost to
  19. Ion Dune
    Ion Dune What's a Dremel?
    5 Oct 2008
    I've used this and the previous guide to set up a working server, but I have one hitch. I need to be able to transfer files to be used for the website (/var/www) from my PC (Windows XP), but I can't access this directory through samba and I don't have permission to it on WinSCP. I looked into using chmod or chown on the directory, but I didn't know what I was meddling with and didn't want to accidentally create a huge security hole. How can I make it so that I can access /var/www/ from SCP or Samba?
    Thanks.
  20. B_Dauterive
    B_Dauterive What's a Dremel?
    23 Dec 2008
    I have followed proftp script as follows. However when restarting I am getting the error which states :
    Fatal: Unknown configuration directive 'AccessGrantMsg' on line 78 of '/etc/proftpd/proftpd.conf'
    Below is a copy of my script.
    # /etc/proftpd/proftpd.conf -- This is a basic ProFTPD configuration file.
    # To really apply changes reload proftpd after modifications.
    ServerName "FTP Server"
    Serverident on "FTP"
    ServerType standalone
    DeferWelcome off
    TimesGMT off
    MultilineRFC2228 on
    DefaultServer on
    ShowSymlinks on
    TimeoutNoTransfer 600
    TimeoutStalled 600
    TimeoutIdle 1200
    DisplayLogin welcome.msg
    DisplayChdir .message true
    ListOptions "-l"
    DenyFilter \*.*/
    AllowForeignAddress on
    AllowRetrieveRestart on
    Port 21
    SocketBindTight on
    PassivePorts 11000 20000
    # to 30. If you need to allow more than 30 concurrent connections
    # at once, simply increase this value. Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd)
    MaxInstances 30
    # Set the user and group that the server normally runs at.
    User nobody
    Group nogroup
    # Umask 022 is a good standard umask to prevent new files and dirs
    # (second parm) from being group and world writable.
    Umask 022 022
    # Normally, we want files to be overwriteable.
    AllowOverwrite on
    # Speed up the server ,no DNS lookups , just plain ip's. Turn off when bein$
    UseReverseDNS off
    IdentLookups off
    DefaultRoot ~
    ExtendedLog /var/log/proftpd.all ALL
    DelayEngine off
    <Anonymous ~ftp>
    User ftp
    Group nogroup
    UserAlias anonymous ftp
    DirFakeUser on ftp
    DirFakeGroup on ftp
    requireValidShell off
    MaxClients 10
    AcessGrantMsg "This is no place to screw around in."
    MaxClientsPerHost 1
    <Directory>
    #DenyAll
    TransferRate RETR 50
    <Limit WRITE>
    DenyAll
    </Limit>
    <Directory>
    </Anonymous>
Tags: Add Tags
