Bits Build your own server
Discussion in 'Article Discussion' started by Da Dego, 5 Jun 2007.
  1. completemadness
    completemadness What's a Dremel?
    11 May 2007
    Code:
    mysqladmin –u root –pmypassword create torrentflux
  2. Glider
    Glider /dev/null
    2 Aug 2005
    I think you copy/pasted from the site... The bit website uses a different encoding/font or something, which makes it go haywire. Just type the command yourself and it should be ok (I hope)
  3. epfjr
    epfjr What's a Dremel?
    23 Oct 2007
    Great article - everything seems to be working except smartFTP I am receiving a "code 530 Login Incorrect". I am using the same login & password that I use for Samba - correct? I have no problem connecting with Samba or by typing the IP address into Internet Explorer.
    I have used the fixes posted here to correct the proftpd.conf issue and am successful and stop/restart of this file.
    I am very new to all this --- please help --- I am pulling my hair out.
    Thanks, epfjr
  4. spaggy
    spaggy What's a Dremel?
    20 Oct 2007
    Thanks a lot Glider, I never thought it'd be as easy as that. :)
    Listen to this though: when I'm in nano editing the config.php file in torrentflux_2.3/sql/html, I type my password exactly where it's supposed to be between the two "s like in your image.
    http://www.bit-tech.net/content_images/2007/06/build_your_own_server/torrentflux12.jpg
    I go ctrl+x, y, but when I try to end it with enter, the error: [ Error writing config.php: Permission denied ] appears. What sort of permission do I need for this to work?
  5. completemadness
    11 May 2007
    SmartFTP uses an FTP password, not the samba password, these are 2 seperate things
    (like SSH password, Samba Password, MySQL password, FTP Password, User Password, etc etc)
    you need to sudo the nano, sudo nano /path/to/file
    This is because the file is made by root, and you don't have permission to edit it
    Glider works from a root shell (sudo su) however this is generally strongly unrecommended (as it mainly negates the point of sudo)
  6. epfjr
    23 Oct 2007
    Thanks for the reply, but I am still confused...
  7. spaggy
    20 Oct 2007
    Thanks completemadness, it worked. I'm beginning to understand this now. :)
  8. DougEdey
    5 Jul 2005
    AFAIK: ProFTPd uses the standard one, which means the groups and users defined in Linux. smb uses it's own set of files.
  9. completemadness
    11 May 2007
    Ah OK, hes used ProFTP
    As DougEdey said, it uses standard UNIX accounts, samba makes its own accounts, as does SSH and other things
  10. Glider
    Glider /dev/null
    2 Aug 2005
    try, in a term
    Code:
    sudo /etc/init.d/proftpd restart
    No, I don't, this is probably because the user extracted the tar as root. I'm quite strict about using root myself, only when needed. And the sudo way of Ubuntu is about the worst way of doing administrative tasks
    ProFTPd does use pam and shadow, the Linux standard password backend, so does SSH indeed. Samba uses a separate one.
  11. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    Is it just me or does www.torrentflux.com not actually exist?
    Can anybody recommend a place to download the latest version?
  12. Glider
    Glider /dev/null
    2 Aug 2005
  13. WhiskeyAlpha
    5 May 2006
    Cheers Glider :thumb:.
    And kudos on the server guides, it's the reason I now have a working linux box without a smashed monitor or keyboard :)
  14. mikealex
    mikealex What's a Dremel?
    27 Oct 2007
    This is a great article! Thanks Glider!
  15. curiouscat
    curiouscat What's a Dremel?
    2 Nov 2007
    I recently upgraded to Gutsy Gibbon and now I cannot log in as root using Ultra VNC from another desktop. Logging in as root via SSH (using PuTTY) works just fine, but I'm not really a CLI kinda-girl =). I still like to see the pretty wallpapers I installed on my Xubuntu box. Anyone have a tip for this issue? Thanks lots!
  16. Glider
    Glider /dev/null
    2 Aug 2005
    Don't log in as root! log in as a user. X11VNC runs as a user (not as root!) for a reason.
    Try creating the SSH tunnel as non-priviledged user and connect to the VNC session.
    On a side note, by default you can't SSH in as root on a Ubuntu install, because root hasn't got a password set...
  17. curiouscat
    2 Nov 2007
    Thanks for prompt response, Glider. I'm such a noob that I was confusing myself, mostly...LOL. All is well now. And thanks for such a great guide. =)
  18. statmonkey
    statmonkey What's a Dremel?
    5 Nov 2007
    Great stuff but I seem to be missing some little detail somewhere. I have no problems with ftp, samba or putty but the VNC part is killing me.
    I get the proper response from the vncpasswd ~/.vnc/passwd
    When I type in: echo 5901 > ~.vnc/port
    I receive:
    -bash: /home/statmonkey/.vnc/port: Permission Denied
    When I attempt to connect using vnc it asks for the password I set and then tells me VNC authentication failed!
    I have tried reading through all of the comments to no avail, google, etc. Also have attempted as different users. sudo, without sudo, etc. but can neither get the first command to work nor get connected in VNC.
    I am not using an international keyboard so that isn't it. As I said everything else seems to work fine and went smoothly. Just not sure what I missed. Any ideas?
  19. Glider
    Glider /dev/null
    2 Aug 2005
    Can you post the output of
    Code:
     ls -al /home/statmonkey/.vnc
    I think you created the directory as root, without permissions to write in it for the user.
  20. statmonkey
    5 Nov 2007
    Hmm, that would mean I created the /.vnc directory with sudo instead of just a straight mkdir? Here is a screen shot. I know just enough to be completely dangerous. I thought I was going to be smart and pipe it into nano and then cut and paste. I got about halfway there before I realized I didn't know the commands, blah, blah. So I ended up having to rerun it several times before I could get a screen shot.
    [img=http://img408.imageshack.us/img408/4629/lsvncfc0.th.jpg]
Tags: Add Tags
