Modding Cathode Throbber
Discussion in 'Article Discussion' started by macroman, 20 Apr 2002.
  1. macroman
    macroman The One
    3 Sep 2001
  2. MagicMikey
    MagicMikey What's a Dremel?
    31 Dec 2001
    Another great idea and great article....definately something orignal, nice!
  3. Jiffey
    Jiffey What's a Dremel?
    22 Sep 2001
    holy hell...not only is the effect nice, but the lights inside your case look a ton better than my one blue cathode looked (it shorts out whenever the cord is vibrated, causing whatever the power is connected to to restart...it screwed my harddrive twice causing reformats before I realized it was the inverter.) Is there any way I can fix my cathode inverter without too much knowledge? I think the tape just wore off so the connection becomes loose every once and a while. If it had its own molex connection to the psu it wouldn't be a problem.
  4. Fly
    Fly inter arma silent leges
    31 Aug 2001
    I have been bugging my mate at work for ages to build me a circuit similar to this one... now I must threaten him some more as they look really coooool... nice work Macro...
    Keep it coming!!!
  5. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    I've posted this in the thread you posted the link in (Fading and alternating cathodes), but I'll post this in the thread officialy dedicated to the subject.
    What inverter did you use with this cold cathode? The effect is somewhat like a lightsaber from Star Wars :)
  6. macroman
    macroman The One
    3 Sep 2001
    All the inverters used were those that came with the CCFLs. All the same type afaik.
  7. TheBigE
    TheBigE What's a Dremel?
    20 Apr 2002
    Forgive my stupidity but I am having a hard time visualizing where all of the power connectors are connected to the PCB. Would it be possible to get a picture of the back of the PCB. Great work by the way Macroman.
  8. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    How do I view the video clips?
    I have downloaded the latest Player but no joy :(
    Meblin
  9. Yo-DUH_87
    6 Mar 2002
    Was the pulse 3 pattern what you wanted from those settings, or was it just because that inverter was wierd?
  10. Yo-DUH_87
    6 Mar 2002
    A little solder should fix that, just make sure not to use so much that you cause a short.
  11. Lazy
    Lazy Meow?
    13 Nov 2001
    do you think that t the end of your articles you could say how much the whole mod would actually cost? As it would be a big help.
  12. macroman
    macroman The One
    3 Sep 2001
    I don't usually quote prices because they vary so much. Obviously checking the maplin website would give you a good idea.:idea:
    It should cost well under £5.
  13. macroman
    macroman The One
    3 Sep 2001
    I have updated the article with this information. ;)
  14. macroman
    macroman The One
    3 Sep 2001
    All done with careful control adjustment. ;)
  15. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    if i print out those foil pics, can i transfer that design onto copperboard and have acid eat away everything but the darkened area?
    i know it can be done using a laserjet printer, by ironing the toner onto copperboard, and then steaming the paper off, but all that will stick to the copperboard is the toner (or the black parts shown on the diagram) and those will be the conductive areas
    will this work?
  16. TheBigE
    20 Apr 2002
    Does anyone know of any parts distributors in the US that are even close to Maplin in their selection. I don't really want to hassle with getting the parts shipped from the UK but I can't find anyone who has the IC.
    edit: I found the IC at Jameco.com but the question still stands.
    edit2: Now I am having a hard time finding the pots and the capacitors, I found 47uF 25V but not 47uF 16V, I think the 25V will work but don't know for sure, anyone?
  17. Lazy
    Lazy Meow?
    13 Nov 2001
    but if you just said at the end of each article the mod will cost you about £5 then it tells me if i can afford it or if ti is something to wish for.
  18. Meblin
    5 Mar 2002
    When I have made etched boards in the past, I have used a permanent marker to draw the tracks. the Black lines will remain when etched. So, as long as the toner works in the same way, it will create the correct copper areas for the PCB.
    The method used in the artical uses an UV box to expose the foil. Then it is put in some chemicals and exposed agin and then more chemicals then wased (I think :))
    I think I'll use a stipboard myself :D
    And here are the costs at Mappers
    UH05F * 2 £0.31
    UH08J * 1 £0.16
    VH11M *1 £0.10
    UF26D * 1 £0.42
    QH56L * 2 £2.20
    M12K * 1 £0.07
    M100K * 1 £0.07
    M1K * 1 £0.07
    M47K * 5 £0.31
    Grand total: £3.71 +VAT
    Meblin
  19. macroman
    macroman The One
    3 Sep 2001
    I would suggest using an etch resist pen and rub down transfers to make the board. The layout is simple enough. You can try the toner idea to get a rough outline but go over the lines with the pen and transfers. I think the toner will wash off.
    Meblin - Thanks, I am glad to see someone can be bothered to look up prices for themselves ;)
  20. M1CUZ
    M1CUZ What's a Dremel?
    5 Mar 2002
    Can you connect more than one Cold Cathode invertor to each channel of the circuit, If so how many could you connect before the power transistors start getting a little strained?
Tags: Add Tags
