Build Advice Complete newbie taking the plunge building a gaming PC
Discussion in 'Hardware' started by mihajaru, 5 Aug 2010.
  1. mihajaru
    mihajaru What's a Dremel?
    5 Aug 2010
    I'm thinking of using Yoyotech.co.uk as the source for my components, I'm not really good at waiting and i prefer to see an item before i buy it *bad experiences in the past*
    So if anybody can help me? the prices are pretty much teh same from scan.co.uk ^_^
    SO far, i got to
    http://www.yoyotech.co.uk/item-detail.php?products_id=2731466 for the Mobo
    http://www.yoyotech.co.uk/item-detail.php?products_id=2654624 RAM
    http://www.yoyotech.co.uk/item-detail.php?products_id=1932496 for the CPU
    http://www.yoyotech.co.uk/item-detail.php?products_id=4368937 for the GPU
    http://www.yoyotech.co.uk/item-detail.php?products_id=4368585 PSU
    Are they good enough? are they compatible with each other?
    Thanks ^_^
    would be great if i can lower the price... cuz at the moment this 4 alone is more or less close to £500
  2. mihajaru
    5 Aug 2010
  3. hirezo
    hirezo Minimodder
    27 Jul 2009
    hmm i see your point...my gpu is good, but i will upgrade it when i get around to it. but definitely go for the more powerful card mihajaru if you can fit it into your budget. doc why do you suggest the gtx 460 over a 5870? just preference or performance reasons?
  4. hirezo
    hirezo Minimodder
    27 Jul 2009
    by the way mihajaru im from london as well. i think you should buy through scan or overclockers for the case, ive never tried yoyotech but the other 2 sites have a very fast delivery service and everything i have ever bought from them has been in perfect working condition too :)
  5. hirezo
    hirezo Minimodder
    27 Jul 2009
  6. carajp
    carajp What's a Dremel?
    26 Jan 2005
    I've used Yoyotech in the past - what stuck out was really excellent customer service.
    Caroline
  7. mihajaru
    5 Aug 2010
    Judi bought my parts, I ended up following the gamer enthusiast build hi hi, the missus will kill me, ill report here when my system is done. Thank you very much all!
  8. docodine
    docodine killed a guy once
    10 Feb 2007
    I never brought up the 5870, that card would take up most of his budget. The GTX 460 is faster than the 4870 by a decent margin, and the price is low enough to fit into his budget.
    There's no reason to defend your build. As I said earlier, it's not a bad build, but it's outdated and it makes no sense to buy it today.
    :lol:
  9. hirezo
    hirezo Minimodder
    27 Jul 2009
    no no, dont take it the wrong way, im not defending it, as i didnt take what you said as an insult. just curiousity to be honest. i didnt think the 460 would be cheaper than the 5870 though. thats a shocker for me!
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Yoyotech are ok, but they are usually alot more expensive than most other places.
  11. mihajaru
    5 Aug 2010
    woohoo! my system is running! took me a while to figure out i have to boot by the dvd drive =D anyhow, is there a way i can know if some part of the build is faulty?
    im installing windows at the moment...
  12. Bloody_Pete
    11 Aug 2008
    Thats usually the good sign :) If something is faulty it'll become unstable, so Blue Screens Of Doom will rear their unwanted heads.
  13. mihajaru
    5 Aug 2010
    so far so good, installed windows 7 and still no errors, fans are working perfectly well, but.. anybody have any idea why the fan on top of utgard xigmatek is really low? and i ahve a problem, everytime i attach my monitor to the connection behind the graphics card, my monitor turns itself off? monitor works when i have it on the normal socket though
  14. Bloody_Pete
    11 Aug 2008
    What do you mean by the connector behind the graphics card?
  15. mihajaru
    5 Aug 2010
    hehe sorry about the wrong terminology, i mean the sockets from the graphics card where you attach your monitor? ^+^
  16. Bloody_Pete
    11 Aug 2008
    I still don't understand what you mean. :S
  17. wormy
    wormy Minimodder
    16 Oct 2009
    If you mean that it turns off when you connect it to the socket on the graphics card itself, rather than the socket on the motherboard, it sounds like the graphics card isn't working - does the monitor say it's going to sleep or similar? That would be as it has no signal from the graphics card.
    If that's the case, go into device manager in Windows and see if you can find there to switch it to your card, rather than the motherboard video device.
  18. Bloody_Pete
    11 Aug 2008
    What I think he means is the second connector on the card itself, which by default is disabled, only the primary connector works with a single screen attached.
  19. mihajaru
    5 Aug 2010
    this is my problem ^_^, ill try it now
  20. Bloody_Pete
    11 Aug 2008
    Have yuo connected the power to the card, seated it in the right slot and made sure its enabled in the BIOs?
