Concept PC H-1 Complete.
Discussion in 'Project Logs' started by Defyant Mods, 25 Jul 2005.
  1. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    wonderful :clap:
  2. nemesis80
    nemesis80 What's a Dremel?
    24 Aug 2004
    is it me, or does this mod reminds me of the combine suit in hl2? :hehe:
    anyway, looks damn sexy, keep it up :thumb: :thumb:
  3. angelorus2000
    angelorus2000 What's a Dremel?
    14 Nov 2003
    great work as always :rock: :rock: :rock: :rock: :rock:
    :clap: mod on :dremel:
  4. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Twas time to get some paint back onto the front of H-1's facia.
    Wanting to keep the orig platsic texture and look i opted to use........Car bumper paint! this stuff is very durable scratch resistant enuf and
    designed for covering plastic!!!!
    the can unfortunatly produces less then stellar finish :( large paint blotches and very uneven.... i deciced to rub the first attemp back
    and spaying the can paint into a small bottle i then transfered the paint into my air brush...
    with some carefull thinning..this produced the effect i was after!
    With the painting out of the raodi could now fit the tinted plex window for the top LCD screen.
    the plex is cut then bent to shape...the window will be glued into place.
    for the CDROM slot hole im using the proper felt from the original slot facia.
    To test the Matrix orbital LCD i had to being the unit inside, with the ATX button power and
    hdd lights an front grill installed its really starting to take shape.
  5. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Turning out more than nicely. Just as expected.
    Another great work by Defyant. Gratz man, you always succeed in making me go :jawdrop:.
  6. BiG Kahuna
    BiG Kahuna What's a Dremel?
    14 Aug 2004
    looks great! :clap: :thumb:
  7. MoOstick
    MoOstick What's a Dremel?
    28 Jul 2005
    Nice painting...
    Funny, looks a bit like a soldering mask... (is that the word?)
  8. Defyant Mods
    14 Sep 2004
    welders mask :)
    thanx guys...hoping to wrap this mod up in the next few updates...im vey keen to get on with HPR3
  9. keir
    keir S p i t F i r e
    5 Oct 2003
    whaooooooo!!!
    as soon as you get the plexi out it just make the differance, you've got ace skills man, trés good. :D
  10. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Very interesting project and nice finish too. It's heavy weight? Looks easily transportable.
  11. huren
    huren What's a Dremel?
    14 Aug 2004
    great work with the bumper black, im a car painter myself and hate the stuff ( i use k&h ).
  12. Kumo
    18 Oct 2004
    I've used Duplicolor Plastic paint (for bumpers mainly) in my last mods and its a good paint for modding.
  13. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Yup, he's done it again. Nice work defyant - the bumper paint was a great idea. Does it feel rubbery?
  14. Defyant Mods
    14 Sep 2004
    thanx guys :) the paint just gives a natural plastic finish.....i was thinking of clearing over..but then it would get shiny again :(
    the case is not hevy! but then its all small factor stuff installed.
    its is incredible rigid! the 4.5mm plex holds up very well and i'd happily trust the case laid on its side for a journey.
    A little idea i stole off HPR3-Mega... i wondered how this would look, once i sort getting the light even i think it will be nice to have this as an "interchangable" option like the side window idea.
    first off is cut and bend to shape some clear plex
    a test to see all fits well
    next is to give the plex a "fost" sanding
    a comparrison
    next will be to do the same thing with orange shadow and green plex.
  15. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    :jawdrop: niceee! looks good!
  16. Pelihirmu
    Pelihirmu What's a Dremel?
    2 Jan 2005
    Looks great on front, side, back.. all looks great! :D I thought you'll put a rad to the front hole, but you didn't :/
  17. Defyant Mods
    14 Sep 2004
    the RAD is in the top section!!!!!!!
  18. Kumo
    18 Oct 2004
    Both options for the front are good looking... Maybe blue/frost combo is more eyecandy, but it isn't necessarily (its correct?) a good thing to me.
  19. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    I like em both so i think you should make 2
  20. blue_lawnchair
    blue_lawnchair What's a Dremel?
    25 Mar 2005
    Great Job there, I your other cases they have giving me so many ideas for my first project. :thumb:
