Hardware Corsair Hydro H50 CPU Cooler Review
Discussion in 'Article Discussion' started by Lizard, 29 Jul 2009.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    I think this is a truely great peice of equipment and its on my list for sure.
    Im confused about the pulling air in through the rad thou, thats just not right, pulling hot air INTO your case?
  3. Guest-16
    Guest-16 Guest
    Yes, but you're drawing cool air in from the outside so the cooling potential is greater for the CPU alone, even if that does heat your case.
    Then again, with cases now having large exhausts in the roof it should efficiently exhaust straight out, but as we saw in the case of the Cosmos 1000 - don't use the H50 as your only intake.
  4. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    I want this, but wouldn't be able to fit to my exhaust fans (I have a PC A 05B). The tubes are just far far too short. Could have the rad hooked up to an intake fan but that just ends up keeping the inside of the case toasty.
  5. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    An interesting review, with a result that I never expected - corsair better watch out for the eu and the monopoly laws!!
    Is it possible for bit tech to start doing proper noise testing with a db meter, rather than just a subjective test.
  6. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    Drawing hot air in is okay providing you have additional means of removing the hot air, most decent cases these days have enough capacity to fit numerous extra fans if they don'y already have them. All it takes is a bit of forward planning with your airflow management and it will be fine.
    I'd have bought this if I didn't already have the Swiftech 220.
  7. rainbowbridge
    26 Apr 2009
    Oh yes I see, thanks for clearing that up.
    I thought this was most interesting vid review by a home user with a decent system.
    Corsair H50 & Scythe Kaze 4Ghz i7 920 Overclock ASUS P6T Antec 1200: ~
    Clicky
    Cliff Notes: The H50 is frecking Awesome and does not heat your case up.
    As a foot note I cant find it now but the H50 on a chart I saw brought the cpu temp down 25deg off the stock cooler of a e7500 or i7, and with a push pull config of fans, drops another 5 or so degs at max fan speed down to around 35/38 I think at a high oc, but the bottom line is this is a great product.
  8. Krikkit
    21 Jan 2003
    That looks like a pretty special bit of kit, I'll certainly take note of that badboy in future - it's so much better than all aircoolers, and very nearly better than my own WC kit! (Although I'll bet it isn't as quiet, this setup is eerily quiet.)
  9. capnPedro
    11 Apr 2007
    Wow, a owrking WC kit... I'll be damned!
    Compact too, and I love that mounting method!
  10. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    I think if Corsair suddenly announced bit-tech users got a fiver off they'd never be able to make enough of these to meet demand, we love a bargain, i'm considering buying one for the shiny factor... but its mainly my graphics card that does the noisy *considers some ill thought out mod*
  11. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    that's a great looking bit of kit! Now they just need to bring out a graphics card equivalent...
  12. Claave
    Claave You Rebel scum
    29 Nov 2008
    We've tried before, but there was too much background noise even if we took kit home and tested in it during the day. The only way to do it is build a professional quiet room (v expensive) and get some really sensitive equipment (v expensive). If we had that cash we'd probably spend it elsewhere tbh - more staff, more video equipment, etc. as that'd get us more significant returns and give you guys more variety and more interesting things to watch/read/do on the site.
    If anyone wins the lottery and wants to donate a quiet room and testing kit, please feel free though!
  13. antaresIII
    antaresIII tephigram
    25 Feb 2009
    Well, Corsair just managed to sell one piece. (I'm placing an order; apparently is a good review more efficient and cheaper that an expensive add campaign).
    Antares
  14. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Looks like a decent piece of kit and for a reasonable price. I would consider this for a spare pc but maybe not my main one.
  15. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Now that's a sleeper for sure, I'd almost given up on integrated WC kit's.
    The fact that this little ninja manages to almost outperform my full blow WC kit when it come to the CPU....sad!
    Excellant!
  16. rainbowbridge
    26 Apr 2009
    When it gets near silent I can hear the damage I have collected over the years of living in a loud city and the use of headphones.
    Ears drums are an amazing design only seconded by the eye and of course the brain.
    The science of sound proofing is actually really interesting I remember reading about it extensively for a project I was doing and unless you are going to go the whole way and put up 6 foot of material its really hard to block all noise, high end fq stuff is easy to block due to the wave length, but low end bass, you need a rediculas amount of thickness to stop it and egg cartons won't work, Im guessing that who ever started that myth saw an accositc camber and thought they were for sound proofing instead of sound wave propagation control?
    I think a way you could get maybe reasonably close to a sound proofed room would be to see if any of your famliy members or some one you know has one of those make shift underground ww2 bunkers that I know are still around, I have seen a few in some larger rich customer sites. Some people have kept them on for storage of wine, a good soild room under 2 or 3 feet of earth with a effort made on sound proofing the door with those foam sound proofing tiles with suspended lead lining sandwidtched in it, put that on both the front and reverse side of the door. you could acheave reasonable quite for under £200.
    What was that device in babylon five sound, in the bar when it brought alight down over a table and made it security sond proofed for conversation get one of those :)
  17. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    I wonder if the H50 will allow me to push my Q6700 to 3.8 GHz,? I'm currently getting an easy 3.4 GHz using a Kama Angle.
  18. rainbowbridge
    26 Apr 2009
  19. hexx
    hexx What's a Dremel?
    9 Dec 2008
    :) shame i bought few weeks ago noctua which was that time for £54, but yeah, it's on the list
  20. The boy 4rm oz
    10 Apr 2008
    Now this is an excellent piece of kit, very sturdy, performs very well (on Intel systems anyway) and allows you to attach any fan of your choice, this would be a perfect HTPC cooler or for a casual to everyday gamer.
    The 2 things I don't like about this unit though are the fact that is has 2 fan connectors, not a single designated one, this issue could be rectified with "Y" splitter though. The other thing I don't like is the finish on the base, a little bit too rough for me, lapping would definately get you a better result. I wonder when they will be released in Australia and how much they will be costing ...hmmmm.
Tags: Add Tags
