Blogs CPUs under the microscope - literally
Discussion in 'Article Discussion' started by Sifter3000, 30 Mar 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Very interesting but could some of those not have been done with just the macro mode on the camera without the need for a microscope ?
  3. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    Be nice if I had even the slightest idea what I was looking at. Some are obvious, but that is some serious zoom.
  4. wyx087
    wyx087 Multimodder
    15 Aug 2007
    very nice high quality photos, but to actually look at the gates, you got to take off the protective silicon cap, pretty much impossible, best to just get a custom one manufactured.
    BBC's Invisible World by Richard Hammond will be on tonight or tomorrow. it will feature our Southampton University's clean room and electronics under microscope. have a look, should be good, it's filed in the best university in the world :D
  5. Xir
    Xir Modder
    26 Apr 2006
    Naah, you back polish the silicon, it's not that hard. :D
    You can poilsh away the contact side as well, seeing every layer seperately, taking EDX materialsamples while you do it...
    Does the term "reverse Engineering" mean anything to you? :D
    For home use::dremel: then polish up and look into it sideways.
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    didn't knew that, always gone "forward engineering" way.
  7. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    look at the scratches on the tip of that pin.... that's some nice super ZOOM there :D
  8. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    Kewl, going to have a check at it
  9. Xir
    Xir Modder
    26 Apr 2006
    It's not as easy as it sounds.
    Sure you get the design and what it's made of, the real problem is how the material got where it is in the state it's in :D
  10. wyx087
    wyx087 Multimodder
    15 Aug 2007
    BBC's Invisible Worlds
    The start is where Richard goes to Uni. of Southampton New Mountbatten Building clean rooms, with (from what i can hear) Prof. Darren Bagnall, in Nano research group.
    it's a shame no electronics, just used the powerful microscope. guess everyone knows what electronics look like at gates level, so they didn't bother to show it.
  11. Sifter3000
    11 Jul 2006
    Nice, I'll check that out!
  12. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Ugh, good lord, please don't watch that series. Yes, there's some great shots and really interesting footage, but the explanations are a little on the "Daily Mail" side. I.e., dumbed down way beyond the BBCs usually low standards. Plus, it's really misleading and overhyped. Richard Hammond is really starting to get on my nerves now.
    The Wonders of the Solar System was a big win. Invisible Worlds was not.
    EDIT: Those photos are quite cool though :) :thumb:
Tags: Add Tags
