Hardware Crucial Ballistix MOD: Temperature-sensing DDR3
Discussion in 'Article Discussion' started by Sifter3000, 22 Jun 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Teh C
    Teh C Arg
    4 May 2007
    Who really cares about RAM temperature. Today a gaming rig will have 1600mhz RAM, and even at that speed have you ever heard a story about RAM overheating?
    Also what is with more companies putting gimmicky heatsinks on RAM that do nothing but interfere with CPU coolers.
  3. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Like Richard said,its useful for those who want to know more about their system while its running. It could be a useful tool for troubleshooting as well.
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    useful (to some), but I'd still prefer it on the small heatsink bearing modules.
    @Teh C: People can push their RAM beyond stability, and this could help to show what's causing the instability.
  5. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Meh, who really needs to know?
    wouldn't a infrared temp gun be cheaper and more useful?
  6. enikmaster
    enikmaster What's a Dremel?
    10 Jul 2009
    This is a welcome add-on. With so many memory kits out there, it's nice to see something different. And Crucial's memories aren't bad at all. could have lower voltages but still good rams...
  7. docodine
    docodine killed a guy once
    10 Feb 2007
    Who cares, it's not like they're charging a premium. I'd rather take this over a competing brand just for the sensor.
  8. Jipa
    5 Feb 2004
    IMO you just aren't going to accidentally overheat the rams anyway, and don't think anyone NEEDS this. That said, it's a nice little trick to stand from the crowd.
  9. RonanH
    RonanH mod-envious
    30 Mar 2010
    If you're using a dedicated non air cooler on your cpu it's possible that there could be very reduced airflow over your RAM (and your pwm) so this is a nice addition to make sure that your ram isn't overheating. What is a safe temperature for RAM anyhow, I presume something at around the 70C mark...
    To those that say it's useless... I remember when on die cpu temperature readings were either non existent, useless or not supported by the mobo. You were flying on a wing and a prayer if you wanted to OC, guessing what was causing the crashes. The same could be said for RAM. Once it's not a price premium and it will become available on all memory it can only be an added value thing.
  10. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    You may need this to see whether you can actually squeeze any more mhz from your RAM. No one ever mentions that the RAM modules can overclock further because of lower temperatures. They just assume the modules just cant overclock further. This will give people who like overclocking memory just as much as their CPU an indication whether temperature is a limiting factor.
  11. Guest-23315
    Guest-23315 Guest
    The only time ram cooling seemed important was back in the age of BH-5, CH-5 and TCCD, where those chips got flipping boiling, and you couldnt get through the BIOS unless you ghetto rigged an 80mm over the top of the chips.
  12. memeroot
    memeroot aged and experianced
    31 Oct 2009
    a nice to have if not that useful - it would make me choose one set of chips over another if there isnt much price difference
  13. Xir
    Xir Modder
    26 Apr 2006
    Well, there's a lot of people out there that have failures they cannot explain, this way you could at least exclude the ram-temps :D
    It's not needed, but nice to have and makes a lot more sense tham LED's on the rams...and people buy that. :naughty:
  14. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    At least there's a benchmark for boredom now. I'm using adobe creative suit, blender and playing music.
    *quick test---sticks hand in case, RAM = cool to touch*
  15. blighter
    blighter What's a Dremel?
    14 Jun 2009
    Agreed, and the more temperature monitoring you have, the more likely you'll get a possible heads-up if a case fan or something stops working. :worried:
  16. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    I think if it was included in programs like SpeedFan and CoreTemp it would be quite useful to get a overall picture of where the heat is in your machine.
  17. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    YAY!!! RAM TEMPS
    Fap Fap Fap Fap
  18. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    AWESOME... I want all RAM to follow this and have a temp sensor built in, anything and everything should have temp sensors ^_^ Great for those who love to OC.
  19. icewind
    icewind What's a Dremel?
    14 Apr 2004
    This would be quite easy to DIY. All memory modules need to have a serial presence detection IC (the small 8-pin-thingy sitting in a lone corner of the ram most of the time) that is coupled to the board's management bus, so the board can see what memory it gets. People have already used the proper bus-pins on their rams to mount extra LM75 or similar temperature sensors in their case, so why not just glue 'em to the ram itself? I guess that's about what Crucial did ^_^
  20. Pookeyhead
    30 Jan 2004
    Want to know if your RAM is overheating? Touch it. Do you have Corsair (or whatever brand you have) burned into your finger tip backwards? Yes? It's overheating. No? Game on!
Tags: Add Tags
