Modding DATAMASTER (a monster from the past)
Discussion in 'Modding' started by kim, 26 Oct 2019.
  1. Cheapskate
    13 May 2007
    Since we are bumped...
    That would be Kylevdm. :lol:
  2. kim
    kim hardware addict
    10 Jan 2016
    :eyebrow: I'm afraid I don't get you this time...:oldconfused: who's that ???
  3. Cheapskate
    13 May 2007
  4. kim
    kim hardware addict
    10 Jan 2016
    :duh: ohh, got it now, ok, it gives some slack :hehe: 'gotta crack my balls to complete before him :naughty:
  5. kim
    kim hardware addict
    10 Jan 2016
    :nono:...No this thread is not dead :grin:
    I reckon I failed doing an unleaking waterboard with inapropriate materials, and I finally realised that this project was not smartly thought, it wasn't suiting my desk-space, It was disproportionate, and I couldn’t wait anymore to use this hardware as it is needed to store and backup my tremendous amount of datas…… So I went back to aircoling and used it for a while with a temporary layout, witch finally became this new project, with the same purpose, almost the same hardware, less watercooling and displays but a more practicle and ergonomic design.
    So on the previous page, I mentioned about this old Mozart TX case someone offered me, and I found it really ugly…(sorry thermaltake)…
    I was about to through it away and I started to strip it down, picking up some screws or possibly useful parts, when I realised that what was left was pretty well thought, it was full aluminium, and could be the foundations of a new datamaster.
    I had to cut out a part of the fragile and unuseful front
    the back panel has got a removable backplate, very practicle, you can also see the new fan grills I want to use
    Started by cutting out previous fan grills
    There is one last to cut...:grin:
    Then I cut out an aluminium plate from this 1.5 mm one
    and placed 4 additional 1 meter alu profiles on the corners to match the correct height
    With one of the doors, I made another plate to replace the missing front one
    but bear in mind it will be invisible, hidden behind a grill..
    Cheapskate likes this.
  6. kim
    kim hardware addict
    10 Jan 2016
    Then I started to build the first floor, it will support a large part of the weight, so I made it as sturdier as possible
    It will strengthen the motherboard tray as well
    The 1200 watts PSU is not enough power for this configuration, so I added a secondary PSU, there is room for it under the Bequiet one...
    but I didn't buy one, I have so many old dusty "noname" ones here:happy:, I spotted out one matching my needs, with a lot of sata plugs
    It just need some cleaning, some paint and a new Bequiet fan
    The icy on the cake is that this old PSU was mounted on a case with this bracket
    So I used it to make the opening
    better :thumb:
    Then I worked on the back panel again to place more fans and grills because it looks a bit naked on this side
    et voila
    I didn't like those strange openings so I cut them out ...
    I made this instead, perhaps I will make it different later, but I prefer the look of it it without the openings
    Then with the second door, I cut this little plate
    it's going under the first tray to make it cleaner from below
    Then I placed 2 sliders
    and made kind of a drawer for the fan controllers
    The red arrow shows little feet to support the first floor
    I done this because I already tried with the fan controllers on the top of the case, it's definitely easier to link, but not satisfying me in terms of design... I prefer it down, so this drawer will only be used once to link the wires but it is compulsory... :hehe:
    Then I started to build the frame to hold the disk cages, with 4 legs out of a 1cm square alu profile, screwed on both sides, but resting themselves on the "L" profiles riveted on both sides too
    Then I made like a bridge witch is very strong and has the advantage to let the fan openings uncluttered by alu bars passing through ...
    Placement of the first cage
    Then I started to build a frame to center all the cages and hold them tight
    I use the fan's mounting screw holes to fix the frame so I won't be able to put 120 mm fans, I don't care, there will be enough room, may be for smaller ones...:idea:
    some pics with the PSUs
    The disk cages overlap fans but slightly and there is exactly 2 mm of clearance for the nut :grin: if that isn't luck :rock:
    the front part
    to be continued
    thanks for watching
    cheers everyone
    Dot_Kappa and Cheapskate like this.
  7. Cheapskate
    13 May 2007
    :clap: LIFE !
    You really should get this moved to the project logs. It's gotten really quiet in there lately.
    kim likes this.
  8. kim
    kim hardware addict
    10 Jan 2016
    Thank you Cheapskate...well, I had the same thought about the lack of activity on BT :grin:, certainly due to the present situation in the world :eyebrow:, but that's why I choose to unwind with modding :grin:
    As to move it to PL...let's wait until it's near completion...:lol:
  9. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    ...what about the desk-pc ?:naughty:
  10. kim
    kim hardware addict
    10 Jan 2016
    :blush: what can I say...:sad:...I am sorry, it's still in the basement but I can't find the motivation to work on it, actually, my life is busier than ever, and I am totally overwhelmed, between my personal life and my work, my house and the computers to fix or optimise for customers likewise some standards builds, sometimes :grin:, so i'm the guy who starts too many projects and put some of them aside, that's why I stash my logs here instead of PL :hehe:
    But my server is too imortant, I am using it almost every days, as I am writing this it is actually working in the state it was on last pics, and I am longing for my july holidays to finish it.
    As for my other projects, I still want to believe I will end them before it loses all interest, some are used differently waiting for some miracle to be finished...but for the desk, I fear it won't be this year :sigh:
