Dawn simulator Alarm clock??
Discussion in 'Serious' started by Picky88, 27 Oct 2012.
  1. Picky88
    Picky88 What's a Dremel?
    18 Apr 2010
    So this is pretty off topic but anyway. I find that if I wake up from an alarm I am grogey and just want to go back to sleep, I learn to turn my alarm off without really waking up for more than a few seconds. I am tired for a few hours at the beginning of every day and struggle to get going.
    If I leave my curtains open, and I wake naturally from the sun coming in, I feel eager to start the day and its so much easier to get up. For me personally the difference is huge!
    Ive been looking at dawn simulator alarm clocks as its now pitch black when I need to get up. They seem to vary in price from only £12 to about £150.
    Anybody care to recommend a good one? I do want a good quality one but I dont want to overspend...
    Thanks guys,
  2. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
  3. Nexxo
    23 Oct 2001
    Philips does several. It likes to churn out these types of lifestyle products on occasion. They're not bad, and actually look reasonably nice.
  4. Tynecider
    Tynecider Since ZX81
    23 Jun 2009
    No kidding here, Back in my bachelor days I once (for a week) used a modified line out from my alarm clock speaker, into the line in on my monster Technics amp and KEF speakers, Left on almost full volume before i went to sleep.
    It worked for two important reasons,
    A. It scares the **** out you, and out of bed.
    B. The speedy dash to get to the damn thing and turn it off before it wakes the whole block gets adrenaline flowing.
    Cold water on your balls also works wonders, it will wake you up.
    A good breakfast and a run also helps.
    That phillips clock looks good.
  5. Picky88
    18 Apr 2010
    I bought a philips HF3470, it didnt wake me up this morning as I had set the brightness to the minimum setting! The full brightness setting is pretty bright though so will see how it works tomorrow.
  6. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Looking forward to your review.
  7. Tynecider
    23 Jun 2009
  8. DXR_13KE
    14 Sep 2005
    I am curious.
  9. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Looking forward to future review I want one of these!
  10. Picky88
    18 Apr 2010
    Yeah Ive been meaning to get one for a while, but been put off as they are very expensive for what they are to be honest. But if Im not a zombie for half they day then its money VERY well spent. Be careful as some of them dont even have a replaceable bulb! I made sure I got one with a £6 replaceable bulb. I paid £80 for it, you can get them for as little as £12 or so on amazon but the reviews say they are no good basically!
  11. Picky88
    18 Apr 2010
    Well it came on this morning, I feel like I have already been up for an hour or so but Ive only just got up. and it was easy to climb out of bed and get on with things. Cant recommend it enough really.
  12. Nexxo
    23 Oct 2001
    Glad it works for you. I'm surprised that it comes with a bulb, given that Philips is a pioneer in LED lighting. Perhaps you can retrofit one.
  13. Picky88
    18 Apr 2010
    I think some newer ones are LED, but you would need several to make it bright enough, this has a 100W halogen car bulb inside.
  14. Nexxo
    23 Oct 2001
    Ah, OK; it's made to go BRIGHT then. :) Well, a car bulb is cheap and pretty generic at least.
  15. kenco_uk
    28 Nov 2003
    £6 for a car bulb? Sweet mother of goodness. I get mine from a unit just down from where I work, a place called Exhausts Unlimited. They do car bulbs for about 80p each - certainly under a quid each. It might be worth a quick scout around on yell.com or google maps to see if there's something similar around your way.
  16. Stickeh
    20 Jul 2003
    Out of interest Picky, which one did you get?
  17. kenco_uk
    28 Nov 2003
  18. Picky88
    18 Apr 2010
    yup. There is a more expensive one that comes with a usb socket so you can wake up to your own mp3 playlist.
  19. Stickeh
    20 Jul 2003
    Got damn it, I should learn to read better!
  20. kenco_uk
    28 Nov 2003
    I'm definitely intrigued. I always snooze for about half an hour before finally dragging my arse out of bed in the morning.
