Dualmaster
Discussion in 'Project Logs' started by coolmiester, 28 Jun 2005.
  1. ShinySwede
    ShinySwede What's a Dremel?
    6 May 2005
    thats exactly the bluecolor i want for my setup ...tell me paul is that for sale on coolercases ? great work again btw =)
  2. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    he could get one of those new 16gb laptop flash disks and take it apart putting the seperate blocks of flash memory behind his mobo tray ;)
    (thats what I'd be doing if I had the money!)
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Wow paul, looks simply amazing.
    Great job!
  4. PHILIP1193
    PHILIP1193 a Self Confessed HP Server Lover!!
    8 Dec 2004
    ahhh i see how te loop goes my problem is that i always though that pumps worked on the basis that teh top of teh pump is outlet and bottom is inlet, hwo wrong could i have been, looking good mate
    Phil
  5. vapb400
    vapb400 What's a Dremel?
    24 Feb 2005
    a good rule is the pump generally pulls from the resevoir.
  6. blue_fusion
    blue_fusion What's a Dremel?
    3 Aug 2004
    looks great man, keep up the good work, cant wait to see how this turns out.
  7. PrometheusCon
    PrometheusCon What's a Dremel?
    11 Oct 2004
    Hey that blue water looks great!
  8. obzelite
    obzelite What's a Dremel?
    9 Jun 2005
    holy crap, that looks sweet.
    hope the dvd drive is going to get some colour coding :)
    How much water is in that system btw?
  9. c.cam108
    c.cam108 Minimodder
    14 Feb 2004
    Has no one else noticed that there is a spare 5.25" bay between the optical drive and the rad? The hard drive will probibly go there. Even though there is a bit of motherboard in the way, it would still be possible to mount the drive there, if stand-off style mountings are used, instead of solid metal angled brackets (if you see what I mean).
    Looks good. I'd be a bit worried about using a pump that small on such a large loop, but then I know nothing about water cooling. The cuts you made on the HDD bays look very professional, as does the finish on the pump. Shame about the scratch on the rad!
    Good luck with this. I will be following it with keen interest!
    _C
  10. frodo
    frodo What's a Dremel?
    1 Nov 2003
    yes, we noticed it, but look The motherboard protrudes into that area, but im sure a HDD would fit there in some 5-1/2" carriers if he moved it forward enough
  11. c.cam108
    c.cam108 Minimodder
    14 Feb 2004
    As I said, he could use stand-off style mountings. You know, the ones used to mount the hard drive in acrylic cases.
    _C
  12. frodo
    1 Nov 2003
    yes, or the carriers that are shorter, but still full metal!
  13. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    when will he post and reveal the HD plan
  14. ch424
    ch424 Design Warrior
    26 May 2004
    On Friday at precisely 19:51.
  15. OneMadPoptart
    OneMadPoptart What's a Dremel?
    14 Oct 2003
    Have you considered investing in some Python hoseclamps (see Nexxo's Metaversa project for details) insted of those icky looking stock black ones?
    I'm you can polish them up and make em shiny too :D
    OMP
  16. KrakenGuy
    KrakenGuy What's a Dremel?
    1 Jul 2005
    Ooooooh, this is so sexy.
    Trust me, one pump with that mod is definately sufficient... Like, I just finished my pump mod, and holy crap the flow rate has picked up.
    Is it done yet? Or are you adding more cool articles of fun?
    Temps =D.
  17. Bilbo Fraggins
    Bilbo Fraggins What's a Dremel?
    1 Jul 2004
    ehhhhhh.. coooool!!! thats all i have to say. Wow sweet rig dude! :rock:
  18. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Great build! will be intresting to see the temps.. :thumb:
  19. Lost.Soul
    Lost.Soul What's a Dremel?
    26 Oct 2004
    will be interesting to see the power... :p
  20. M_D_K
    M_D_K Modder
    3 Apr 2002
    By the looks of the design i don't think pauls going for Low temps just reasonable ones that will get him by. Much like Nexxo's he's thought about whats kicking out and gone for wht is needed :), think the temps will be in the manufactures designed limitations :).
    Looking good paul and i thought you had no time on your hands lol, nic elooking case once again and i am beginning too see a patturn here lol.
    Good work keep it up :).
    [P.S. did you dig up any pics or rads laying around] :)
    morgan.
