Graphics Erratic frame rate with a GTX570 [ UPDATE IN FIRST POST ]
Discussion in 'Hardware' started by knuck, 3 Apr 2011.
  1. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Is there any way of determining the actual states of the GPU in real time, other than the general "GPU utilisation"?
    Does any software monitor/report this?
  2. GoodBytes
    20 Jan 2007
    Every Geforce series since the Geforce 2 has these power mode.
  3. GoodBytes
    20 Jan 2007
    @knuck, I hate saying this as it will make your GPU go at full speed all the time, which mean a bit more noise and heat (but that could be fixed with my in development software though, which I can provide to you (rick solid, just not completed). But one thing at a time, let's just see if it's PowerMizer the problem.
    Use Nv GPU Pro (my tool, it's free), to disable Nvidia PowerMizer, to see if that helps solve your problem. I have PM'ed you the latest version of it, which works with all the drivers up to and including the 270 series. I have to release it, but I am busy with University (end of semester and everything).
    You can always enable it back with the same software, of course.
    If it is PowerMizer the problem, then check for on MSI web site for the latest GPU BIOS version (Nvidia web site only has drivers.. no BIOS update).
  4. murraynt
    murraynt Modder
    6 Jun 2009
    Evga precison can tell you you clocks in game along with V-Ram and lots more.
    Might be worth installing a playing a game for a bit and check if the clocks drop.
    Knuck, Did you disable your microphone input on your card along with your line in?
    I get a hissing when the aren't muted with my sound card.
  5. GoodBytes
    20 Jan 2007
    Wait what? you too! What the heck!
    I can leave everything at max volume and not muted, and I still hear a clean non-hissing sound, weather I put my Geforce 6600GT, my 8800GT, or my GTX 260. This is strange. Either Creative went cheap-ass on the later model (as I have the original X-Fi rev 2.0 (now with heatsink to avoid overheating!)), or a motherboard thing (as I see both of you having an ASUS board).
  6. murraynt
    murraynt Modder
    6 Jun 2009
    It's weird. Only when I have the Line in enabled though.
  7. knuck
    knuck Hate your face
    25 Jan 2002
    It's been working fine all day even though I didn't change anything. I ... I don't get it. Black ops runs like crap though
  8. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Exactly what card is it? Is it the overclocked MSI one with the GTX480 fan?
  9. knuck
    25 Jan 2002
    It's this card
    For the record, the hardware has been out of the case for 24 hours now and the performance haven't dropped once and I haven't heard any interference...
    *now waiting for new case to arrive
  10. murraynt
    murraynt Modder
    6 Jun 2009
    What case was it in? If it throttles or goes down to it's low power clock due to heat a restart would be required so maybe that's where your problem is.
  11. neil_b
    neil_b Minimodder
    20 Jun 2009
    Hissing in an otherwise clean audio channel can be a sign that there is RF interference and that can sometimes be caused by something as simple a grounding/earthing issue. This can also lead to overheating and other similar problems in audio and related cards.
  12. knuck
    25 Jan 2002
    there may have been a grounding issue in the old case (a chieftech dragon clone btw) but the videocard was definitely not overheating. It's not any cooler outside the case , nor is it hot at all
  13. neil_b
    neil_b Minimodder
    20 Jun 2009
    Much more likely that the audio card/circuitry will suffer heating problems from RF due to a grounding issue - you basically end up with electronics designed to amplify and control audio, trying to do the same with RF frequencies - it rarely has a happy outcome.... Earthing problems can be both quite subtle and also troublesome to nail.
  14. Deders
    Deders Modder
    14 Nov 2010
    Could be a moving part resonating with the case, vibrations can travel through wiring
  15. knuck
    25 Jan 2002
    nah the sound it made was in sync with the movement of my mouse or animations rendered on screen
    I'm still waiting for my case to arrive but, in the meantime, the pc has been performing fine for 48 hours now even though I did nothing :eyebrow:
    The northbridge is extremely hot however since there is no airflow at all outside of a case. I don't like it but it'll have to hold on a few more days
    Oh and I was surprised to find, when I plugged the 260 earlier this morning, that the 570 is actually louder than the 260. That sucks
  16. Deders
    Deders Modder
    14 Nov 2010
    I used to get the same thing with my mouse when I increased the USB polling rate to 1000 but it disappeared after a few hours, does sound like bad earthing.
    A discrete soundcard might help if it's coming from the speakers, try switching them off and seeing if that helps. I believe some of the Xonar range draw all their power from a floppy connector to eliminate any extra noise.
  17. knuck
    25 Jan 2002
    the sound problem first appeared in my earphones only (dedicated headphones output of my bravura x-fi) but, the last two days in the case, it was audible in my speakers as well. Interference makes sens because there was no weird sound when I used my receiver (all digital)
    anyways this problem is gone for now :thumb:
  18. knuck
    25 Jan 2002
    Fractal Design R3 XL is back order until next month. Damn !
    I need to find a temporary solution and buying another case is not an option. I want to be the only guy in a 1000km radius to own this case :D
  19. knuck
    25 Jan 2002
    After 3 weeks of superb performance, the problem is back and, obviously, it's during a LAN party. Everything was perfectly smooth last night but, at 4 am, I turned off my PC for the night (which I usually never do). When I turned it back on this morning I saw immediately that the problem was back. I now have about 35% performance of what I usually have. It also constantly says that the card is at 99% GPU usage and it doesn't get hotter than its usual idle temperature.
    I just updated to the 270.61 drivers and saw no improvements.
    What now ?
  20. GoodBytes
    20 Jan 2007
    RMA it and be done with it.
