Cooling Fan Testing and Comparisons
Discussion in 'Hardware' started by LennyRhys, 22 Apr 2020.
  1. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    With 2mm of water you might want to consider a inclined u-tube manometer.
    Edit:
    If you are not familiar check out this page.
    cobalt6700 and LennyRhys like this.
  2. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Ah very cool - yes I did encounter some inclined manometers when scouring ebay and didn't give it much thought. Turns out the is the perfect solution to measuring fans with low static pressure, and I'll see what kind of results I get!
  3. adidan
    25 Mar 2009
    That's usually the first thing said by 9 out of 10 people who end up on Tattoo Fixers.
    The_Crapman likes this.
  4. The_Crapman
    5 Dec 2011
    There's a lot of canines in magaluf :worried:
  5. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Pitot tube theory is pretty simple TBH - you measure the static and velocity air pressure at the same time, subtract static from velocity to find your head pressure, which can then be used to find the velocity in m/s: V m/s @ 20 DegC = 4.05√(Velocity p - Static p) mmH2O. A set of velocity readings which are averaged, then multiplied by the area in m will give you a flow rate in m3/s.
    Just measuring in one place will almost certainly give you a duff reading, and you need at least a length 10 Diameters straight/free flowing upstream (can be reduced with flow straightener) and 5 Diameters downstream to get good readings. Measuring small flows in mmH2O can also be tricky, a 120mm G1238B running flat out is around 8.05m/s, 3.95mmH2O Δp, 0.116m3/s. At 1/2 the flow, you would be looking at 4.05m/s, 1mmH2O Δp, 0.0583m3/s. Pa would be a better unit, but as Dr.Coin said, you will need an incline manometer to measure in smaller units. I may have a couple of old ones hanging around if you wanted one :thumb:
    That's fair enough.
    Cool - basically your water has a specific gravity of 1 (or very close to that at 20 degC its 0.9982, at 4 degC its 1) up to you if you want to chill it to 4deg. I'd stick with room temp for easy to ref results. Unless you are either very high or very low in relation to sea level, atmospheric pressure will have little to no effect on your readings. If you were measuring in Pa with calibrated manometer, sure.
    I mean.... now that is what a call an axial fan! Wowzer that thing goes. I fear the googly eyes will not last long on that one.
    LennyRhys and Bloody_Pete like this.
  6. Mr_Mistoffelees
    26 Aug 2014
    So, would suit my dog when he gets over-excited.
  7. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    The massive child in me wants to put a piece of paper in it.
    LennyRhys and Dr. Coin like this.
  8. Goatee
    Goatee Multimodder
    19 Apr 2015
    I was thinking drop a grape in it, maybe a cheese string too would be cool.
    LennyRhys, liratheal and Dr. Coin like this.
  9. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    That's very kind of you - I'll see how I get on with the DIY jobbie at the moment and may consider upgrading to a more serious measurement later!
    Speaking of... I had a bash with inclining the u-gauge and the results are definitely a lot clearer as the water column moves a greater distance, however there are some issues with surface tension inside the tube and the water being a bit unpredictable. Tapping the tube a few times usually does the trick. but I've noticed that the water can sometimes "hug" the inside of the tube and simply go from being convex to concave on the intake side.
    Here's the setup that I tested this evening, using three fans: Gentle Typhoon (2,250rpm), Noctua NH-A12x25 (2,070rpm), and Delta AFB1212M (2,060rpm). All the speed measurements are made with a laser tachometer.
    Obviously these measurements are no longer mmH2O, but the comparative results are apples-to-apples and are very interesting indeed. The slowest fan of the bunch has (by far and above) the highest static pressure, but it's also the loudest.
    Noctua NH-A12x25: 2mm
    Gentle Typhoon: 2.6mm
    Delta AFB: 4.3mm
    I re-did each test and measured the tube at both points where the water level is, and I got the same results (unsurprisingly). I marked the measurements with tape and then measured the gap with my vernier calipers.
    You can see from the picture below that the water is anything but level inside the tube, and I'm presuming this is surface tension / capillary behaviour? Water was at room temp, as suggested by cobalt6700!
    Dr. Coin likes this.
  10. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    I have three 10,000rpm 92mm fans and I may be willing to set one aside for such frivolity in the name of science. I'll add paper, grapes, and cheese strings to the list.
    cobalt6700 and Dr. Coin like this.
  11. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    and a carrot
  12. Goatee
    Goatee Multimodder
    19 Apr 2015
    and a Peperami
    The_Crapman and RedFlames like this.
  13. Mr_Mistoffelees
    26 Aug 2014
    Damn you and your keyboard with a number pad...
    The_Crapman and cobalt6700 like this.
  14. Mr_Mistoffelees
    26 Aug 2014
    Perhaps you could try a drip of washing-up liquid to reduce surface tension?
  15. Goatee
    Goatee Multimodder
    19 Apr 2015
    I'm loving this thread already.
    Other than feeding your fans with stuff from the fridge, are you taking user submissions to add to your test roster?
    I have a PC fan in mind (I actually have 6 in mind but I guess one would do) but they make your pride and joy look a bit weedy in the RPM department, so I wouldn't want you to have to upstage it. :D
    Model PF40561BX-000U-S99
    Size / Dimension Square - 40mm L x 40mm H
    Width 56.00mm
    Air Flow 31.7 CFM (0.888m³/min)
    Static Pressure 3.600 in H2O (896.8 Pa)
    Bearing Type Ball
    Fan Type Tubeaxial
    Features Auto Restart, PWM Control, Speed Sensor (Tach)
    Noise 67.9 dB(A)
    Power (Watts) 16.68W
    RPM 18,000 RPM (the front fan is 21,000)
  16. RedFlames
    23 Apr 2009
    If you're on Windows 10 [and not on an ancient version of same] - WinKey + . [or Winkey + ;], gives you an emoji/special character picker... not as quick as Alt codes, but better than nothing [also you're not haveing to remember the codes]
    liratheal likes this.
  17. Dr. Coin
    13 Sep 2013
    I didn't see the period at first and tied Win + :duh:
    I don't see symbols just emojies when I use period or semicolon. My fall back for key codes I don't remember is to bring up the Character Map program (sorry a bit of ancient dating to NT 4.0). Tip, click the Advance View box, and the very bottom use the search box to find the symbol of your choice.
  18. RedFlames
    23 Apr 2009
    This is what I see, Emoji, Kaomoji [stuff like '¯\_(ツ)_/¯' or '(╯°□°)╯︵ ┻━┻'] and then Symbols across the top, and categories across the bottom [unfortunately the search function doesn't really work that well with the symbols].
  19. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Could do - I'd be concerned about the possibility of making unwanted bubbles at the surface though. No harm in trying I guess!
    Absolutely - I was thinking of making it as comprehensive as possible and if there are fans that people want to suggest (or send to me) I'm happy to feature them. As a general rule of thumb, smaller fans can have higher rotational speeds because of lower air impedance, but their increased static pressure comes at the expense of vastly reduced airflow.
    I've got a "fun" fan on the way from China which has already been in transit for a couple of weeks... fingers crossed it'll get here soon. It'll be the jewel in my crown of 12v fans. ;)
  20. cobalt6700
    17 Oct 2005
    @LennyRhys I think surface tension is indeed the issue with your fluid hanging up. Most manometer fluids contain a 'wetting agent' to help prevent this. Also most incline manometers use a 'smooth' surface material, like glass/finished acrylic. I suspect using some acrylic/PETG hard line tubing would help you out a lot. Tubing diameter also plays a part due to droplet size. You may also find it easier to read off against a scale with a smaller tube.
    A very slight drop of fairy may help as suggested, your not 'blowing through' the manometer so bubbles shouldn't be an issue.
    If you were to build an incline with the smoother tube, you could use your original to calibrate the new one to provide yourself with a scale :thumb:
    Also +1 for shredding stuff :D
    LennyRhys likes this.
