Cooling Fan Testing and Comparisons
Discussion in 'Hardware' started by LennyRhys, 22 Apr 2020.
  1. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    If you dump it into a google sheet then at least we can help with the analysis :)
    cobalt6700 and LennyRhys like this.
  2. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    So I got this in the post today - Delta BFB1212VH. It's absolutely mahoosive for a PC blower (120 x 32mm), and it really packs a punch, developing 33mmH2O max static pressure (according to the spec sheet - I'll have to measure it myself!). I plan to make a shroud for it so I can do some thermal tests and compare it with axial fans which develop a lot less pressure but significantly more airflow.
    This thing tops out at just under 40CFM. The only axial fans I have that get even close to 33mmH2O are >200CFM monsters.
    The_Crapman likes this.
  3. Bloody_Pete
    11 Aug 2008
    Whats its noise like?
  4. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    It's actually not bad, all things considered. I had it on the speed controller and it vibrates a fair bit when I slow it right down, but at max speed of 3100rpm there's a lot of air noise.
  5. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Here's the setup I used for the thermal test with the blower fan - super hi-tech stuff, as you can see. Moving a little air at very high pressure is gonna generate more noise than moving a lot of air at low pressure, it seems - this thing is LOUD.
    The average delta temp for this setup is 33.5°C. The main problem is that most of the cooler doesn't get the air from the blower (even with the shroud) so the temps could be a lot lower.
    Curiously, the behaviour of the blower fan is the opposite of axial fans when the output is blocked - the impeller speeds up rather than slows down. I'll need to get it on the chamber for some pressure testing, which I may do at the weekend as I'll need to make a proper jig to mount it securely to the box.
  6. The_Crapman
    5 Dec 2011
    Ek vardars are all white.
  7. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Now that is a proper set up. Love the use of the C-clamp.
    cobalt6700 and Bloody_Pete like this.
  8. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    C-clamp or G-Clamp? :p
    Nice work as usual @LennyRhys. That's a cool little snail! That's more what I'm used too. Looks like its forward curved and .. looks like 1/2 impeller with the back 1/2 and blades out of phase to the front blades.... ookay. There must be some tiny fan physics I'm not getting :lol:
    LennyRhys likes this.
  9. Mr_Mistoffelees
    26 Aug 2014
    In the UK that is a G-clamp, Canada may be different.
  10. Dr. Coin
    13 Sep 2013
    Canada and USA. I can see why a G. A quick google search of the two terms C-Clamp URL result .com mostly retail sites, G-Clamp returns mostly .co.uk, a few .com.au, and a few miscellaneous TLDs including a .com but included a UK reference elsewhere in the URL.
    I'd have said radial and out of phase, but it not clear from the picture. I tried checking data sheets but I did not see anything @LennyRhys can you confirm which it is?
  11. javaman
    javaman May irritate Eyes
    10 May 2009
    Fantastic work. Incredibly informative and useful.
    Kinda interested how the F12 perform compared to the P12 as they're about £1 cheaper per fan. Arctic seem to aim the P12 at heatsinks and radiators as it has higher static pressure while the F12 is advertised as a high airflow case fan.
  12. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Thanks javman! I'd imagine that there would be very little difference between these two fans, despite the P12 being branded a "high pressure" fan. All of the fans I tested on the heatsink were within 2C of each other, and in all likelihood it's less than that.
    @Dr. Coin and @cobalt6700 here's a better picture of the big blower with the top cover removed. The two halves of the impeller are indeed out of phase. Interestingly, no fancy aerofoil shape to the blades... just very slightly curved and very densely stacked.
  13. Dr. Coin
    13 Sep 2013
  14. cobalt6700
    17 Oct 2005
    @Dr. Coin They aren't always that keen ;)
    Interesting design though. I'll have to look up the out of phase blades (out of interest)
    @LennyRhys I'm not sure I've come across any centrifs with aerofoil shaped blades. They are interacting with the air in a different manner that that of an axial fan - as in they are designed more to conduct the air in a certain direction (outwards towards the 'snail') rather than accelerate the air over the faces of the blades.
  15. Vault-Tec
    30 Aug 2015
    Just to note dude. I haven't forgotten. Had a dig around today at my place and found some more.
    I will be back over with the others on Tuesday next. So I will ping you then for an addy to send to.
  16. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Thanks Vault - I haven't done much in the way of fan testing, still waiting on a fan arriving from Singapore (I ordered it at the end of March...). :wallbash:
  17. Vault-Tec
    30 Aug 2015
    Oh you'll have plenty to keep you busy soon lol.
    Hopefully I will get them out by the end of the week. I will PM you for addy when I land tomorrow.
  18. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Couple of small updates - I've been in touch with PChub[dot]com to request a refund for a fan I purchased at the end of March. 13 weeks since I placed my order, and no delivery... that's ridiculous by any standard, Singapore Post or not.
    I also managed to break the styrene tube on Magnahelic gauges so I'll have to repair that before I get them back in action again, but it's a small job and easy enough to do... I've just been busy doing other things. The good news is I have a big holiday coming up so I'll be able to do more tinkering again.
    Bloody_Pete likes this.
  19. Bloody_Pete
    11 Aug 2008
    Yessss more data!!!!
  20. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Did you see the Gamers Nexus video where they showed their fan testing setup? That's the sort of thing we're trying to build internally.
