Hardware First Look at USB 3 Performance
Discussion in 'Article Discussion' started by Lizard, 18 Dec 2009.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Page 2 of the article repeats the end of page one.
    Looking forward to mainstream adoption of USB3.
  3. motas
    motas What's a Dremel?
    7 Dec 2009
    I'll buy it when they make flash drives that are fast enough to need it.
  4. Claave
    Claave You Rebel scum
    29 Nov 2008
    Fixed - thanks.
  5. shanky887614
    shanky887614 What's a Dremel?
    13 May 2009
    ill wait till they bring out card readers that have this built in and more devices out there have usb 3.0
  6. Autti
    Autti What's a Dremel?
    29 Oct 2009
    I hope the next iphone uses USB3! Don't jinx it bit-tech.
    Interesting results though, 5x is certainly very nice for now, but i doubt we will see USB3's true colours shine until it is incorporated into chipsets, the same goes for SATA 6Gbps
  7. theevilelephant
    theevilelephant Minimodder
    5 Jan 2006
    Looks like it has potential :)
    Also "USB 2 can only deliver a maximum of 100mA"? Fairly sure its 500mA, we've seen several USB devices in our workshop that have a constant current draw of 400mA+.
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    All of the graphs say "Speed (MB/sec)". Only the graphs on the first page should.
  9. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    Why on earth does the Sharkoon card require additional molex power?
  10. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I wonder if there are any USB3.0 HDD enclosures available
  11. Paradigm Shifter
    10 May 2006
    So, from the sound of it, the Universal Serial Bus now has an even greater number of data lanes... wouldn't that make it the Universal Parallel Bus? :eyebrow:
    Overall, looks pretty promising.
  12. phuzz
    phuzz This is a title
    28 May 2004
  13. Baz
    Baz I work for Corsair
    13 Jan 2005
    Cheers, fixed
  14. [USRF]Obiwan
    9 Apr 2003
  15. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
  16. Baz
    13 Jan 2005
  17. Denithor
    Denithor What's a Dremel?
    4 Dec 2008
    Seems like more and more devices are using PCIe lanes for data transfer. With Intel's S1156 chips on P55 boards there is potential to cut into your GPU performance if too many lanes are dedicated to peripherals. Might make for an interesting article to see if this impact could be determined.
  18. wiak
    wiak What's a Dremel?
    9 Apr 2006
    Please test the Asus USB3/SATA 6Gbps board on a AMD 790FX chipset, why? well the 790FX has 42 dedicated PCIe 2.0 lanes to northbridge, so basicly its PCie 2.0 all the way, unlike many intel boards
    and it would also be nice to know how the Asus addon PCIe board perform on amd platform compared to the intel platform
    all the test about USB3 and SATA 6Gbps has been tested on Intel platforms!
  19. kenco_uk
    28 Nov 2003
    USB2 is 480mbps = 60MBps
    Source:http://www.everythingusb.com/usb2/faq.htm
    Maybe a similar happening with usb3? The fastest I've ever seen on usb2 is a gnats under 30MBps.
  20. rollo
    rollo Modder
    16 May 2008
    dout next iphone will use usb3. Apple hasnt exactly used firewire yet which has been out forever. Even up to recently usb1 was still the only true support for the ipod series.
Tags: Add Tags
