Hardware First Look: Zotac Nvidia Ion Mini-ITX
Discussion in 'Article Discussion' started by Tim S, 2 May 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    YAY ion is here, however
    Zotacs top LGA 775 9400m top end motherboard is about £120-30 on average, coupled with a e5200 would make it a little more than there ion board, but give it alot more potential.
    This board is very interesting, but priced wrong. Built in PSU, love the idea, scared it will fry its self.
  3. coolius
    coolius What's a Dremel?
    29 Jul 2007
    I am glad to see manufacturers taking advantage of the Ion's potential. I've always loved the small dimensions of mini-itx boards, and now they finally have enough power to handle anything bar top-end gaming!
  4. Guest-16
    Guest-16 Guest
    I don't think it's priced that wrong after taking into account both are different markets and you get a (silent) power brick you know works with it: it's a hassle saver. The ion platform is lower power, media centric, much lower profile. The LGA775 board is more powerful, requiring a bigger case - I'd not leave that always on all day for example.
    I think people will be put off after seeing "Atom = cheap" but again, an Atom-Intel board is another market altogether again. It's good to have consumer choice that's all I'll say ;)
  5. Burnout21
    9 Sep 2005
    I do agree with the idea of not wanting to leave an LGA 775 machine on all day, and this is where the atom really shines.
    £160 ok thats with a power brick and built in PSU and wireless, so for £200 you could have an awsome HTPC system for DVD playback, or spend a little more and get a blue-ray drive.
    I just hope Zotac flood the market with this, as Evga 939 SLI mATX board was awesome but rare as F**K making it very expensive!
  6. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    throw in two more internal sata ports at a reasonable price, and i'll buy it.
  7. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Frankly, no expansion slots, PCI or PCIe, even a 1x, and only 3 internal SATA connectors are its bad points.
    No 4-disk NAS, and no adding a proper RAID or Video or Sound, or Capture card...
  8. amdavies
    amdavies What's a Dremel?
    11 Mar 2009
    Could you check the power draw at the wall on these please ?
    I have a mATX 740G + AMD 5200x2 (@ 2GHz) + 2GB Dimm + 160GB HDD running at about 40 watts.
    Thanks.
  9. Guest-16
    Guest-16 Guest
    Of course, when the review comes :)
    To the other about PCI slots etc: I agree, but this is only one of a few models from what I've been told, so we'll see :)
    Tbh if you wanted a full size RAID card you'll go for the LGA solution: I not sure an Atom will be able to handle the IO.
  10. bowman
    bowman Minimodder
    7 Apr 2008
    Hm. I leave my LGA1366 on all day, all night, weeks at a time.. I must be weird.
  11. Saivert
    Saivert Minimodder
    26 Mar 2005
    @bowman: I think he was referring to the cost of electricity. Any PC with adequate cooling can run 24/7 no problem. That's not the issue here. I keep my own "gaming" PC on 24/7 as well. If you can afford the electricity costs then fine go ahead.
    And when it comes to the pricing of this board I can only say that small form factor stuff always costs the same or more than it's bigger counterparts. It's the price of miniaturization. Also there is a much lower volume on this kind of hardware. And they still have to earn a buck. It's basic economy.
  12. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    Do you pay the bills?
    My housemates would murder me if my PC was on 24/7 :grr:
  13. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Hmm... still no need for any kind of HTPC but I'd still want one. ;)
  14. ZeroX
    ZeroX What's a Dremel?
    17 Sep 2003
    this board in a HFX micro would be a very nice combination!
  15. stonedsurd
    11 Mar 2009
    Is there any substantial difference between the 9400 and the 9300?
    I've had my eye on the Zotac 9300 LGA775 board for a while now.
    Great preview though! :thumb:
  16. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    that cubit case looks pretty- about as compact as it will go.. looks like a good combo
  17. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    Ok Bindi, you said there are other models to come, maybe one that will include a PCI or PCI-e slot in lieu of that Mini PIC-e?
    Personally, IMO, it needs the extra sata slots so it can handle an NAS. The Atom should be able to handle some IO on it, as long as your not doing anything intense.. Now will this set up handle gaming well? Obviously its not going to beat a E5200, Zotac ITX board and some nvidia gpu, but compared to its "brothers" it handles gaming and video a lot better?
  18. Burnout21
    9 Sep 2005
    I think the trick with this is rather than trying to turn it into a NAS considering most of us already have a NAS, just hook it up over a 1Gbit Lan and stream any media.
    Personally i would use a cheap laptop HDD or SSD for the OS, with a small amount of data like a background images folder. And then a laptop slim line or if price is a problem a nomal sized blue-ray drive for the local playback of media.
    then run utorrent to download locally and then once finished automatical move it to the NAS.
    Small tight machine for 24/7 use.
  19. stonedsurd
    11 Mar 2009
    ^Bingo.
    Although there's something reassuring about an E5200 paired with a 9300M. A decent soundcard and you'd have a system that would make for a great media center box :)
  20. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I know you guys dont want to "Fry" it but whats the point if you dont properly test it, so yes please put at least two 1tb type HDD and a Blu-ray drive to test with because its pretty obvious by its design that this is intended for HTPC environments even right down to the power brick so ya if you dont do such a test then well it will certainly be far from a review.
Tags: Add Tags
