Hardware First Look: Zotac Nvidia Ion Mini-ITX
Discussion in 'Article Discussion' started by Tim S, 2 May 2009.
  1. deruberhanyok
    deruberhanyok What's a Dremel?
    4 May 2009
  2. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    It'll have to be 2 disk NAS, since there are only 3 SATA slots, and one of the is for booting (unless usb key boot)...
    Having an external drive as part of a RAID 5 would be pretty unsafe.....
  3. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    since no one thinks this is a good NAS board, what is then? One with 4+SATA slots at the same power outage? Is there an ION mini-ITX board that can do that? And run RAID?
  4. Guest-16
    Guest-16 Guest
  5. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    how about an actual NAS? lol
  6. logan'srun
    22 Apr 2008
    don't lol me! xD
    What if you don't want to buy a prebuilt NAS, I mean this is BITTECH where ple build everything under the stars, so why should we start buying pre-made, pre-built now? And BTW, thxs for the awesome answer Mr Obvious.
  7. HourBeforeDawn
    26 Oct 2006
    your kidding about Bit-Tech and the pre-built comment right lol they reviewed plenty of prebuilt hardware and setups before and besides your understanding of a NAS is a little misplaced, you dont need this type of hardware for a NAS, most self operating NAS systems used 512mb of ram and a via cpu that operates at 1ghz or less so end point you can take older hardware or older ITX boards downclock an older cpu and its voltage and well what do you know, now you have a NAS wow... lol taking hardware like whats being shown here and making it a NAS is not only foolish but an extreme waste of money.
  8. logan'srun
    22 Apr 2008
    Ah, now we're getting somewhere. So instead of all the misplaced 'lol's' and my admittedly lack of knowledge concerning NAS's systems - you could almost (that needs quotation marks, but I'll let you put them there) learn something from your slightly condescending post.
  9. HourBeforeDawn
    26 Oct 2006
    well as long as you learned something thats what counts, glad I could help :thumb:
  10. Guest-16
    Guest-16 Guest
    http://www.bit-tech.net/hardware/storage/2008/09/21/qnap-ts-409-pro-turbo-nas/1
    http://www.bit-tech.net/hardware/storage/2008/09/24/qnap-ts209-ii-turbo-nas/1
    http://www.bit-tech.net/hardware/storage/2009/02/01/icy-box-ib-nas4220-b-network-storage/1
    :blush:
  11. HourBeforeDawn
    26 Oct 2006
  12. Guest-16
    Guest-16 Guest
    But, damn expensive :(
    I really really want to do a feature on making your own NAS :(
  13. HourBeforeDawn
    26 Oct 2006
    ya but certainly worth every penny, however my pennies lucked out as I got both of them for free bust still excellent system, ya a how to would be nice, I took some old hardware in the past and built my own low powered nas system but since I got those two QNAP Systems I retired that old rig.
  14. logan'srun
    22 Apr 2008
    Please do! That would be a nice addition to the guides on the site!
  15. john2c
    john2c What's a Dremel?
    7 May 2009
    Can you check to see if it suffers from the same problem as Zotac 9300 motherboard: Non-powered USB ports. This prevents the computer from being able to be woken up by USB. This is a big deal for HTPC enthusiasts because it means the motherboard can't be powered on by a remote control.
  16. The boy 4rm oz
    10 Apr 2008
    Point of view have just released their own ION boards:
    http://www.techpowerup.com/93687/Point_of_View_Releases_its_First_NVIDIA_ION_Mainboards.html
    How about getting one of these to review? :D
    I really like the whole ION system. I am going to make a HTPC out of one as soon as I have the funds (or can get a sponsor). My only requirement is for the board to be Duel Core, have slots for 2 DDR2 dimms, have built in WiFi and a PCI-e slot for a better sound card.
    stonedsurd likes this.
  17. stonedsurd
    11 Mar 2009
    Shoot me a PM if/when you find one?
    I have the same requirements. :p I'm even willing to let up on the powered USB ports (I can make the extra effort to hit the switch)
    I promise I'll let you know if I have any luck, too :D
  18. The boy 4rm oz
    10 Apr 2008
    Well this Zotac board is almost exactly what I am looking for except it is missing the PCI-e slot and I would really prefer the board without the built in PSU, perhaps they will release another model which will be perfect.
    I will let you know if I find any, these boards anre just starting to roll in now.
  19. HourBeforeDawn
    26 Oct 2006
    umm the board you linked to does all that minus the built in Wifi, just get the Atom 330 model which is a dual core. and a USB based wifi and if it must be internal then get a usb header to usb adapter and plug it inside the system lol.
  20. amdavies
    amdavies What's a Dremel?
    11 Mar 2009
    People may be losing sight of what Ion was designed to do above and beyond a regular Intel Atom platform.
    Ion adds much better graphics capability to a low power x86 processor. Some codecs get a boost from nVidia's graphics technology allowing some to be played at 1080p and less intensive games may now be playable at a 720p-type resolution.
    Moving to a dual-core Atom adds some processing power for non-accelerated video, primarily flash at full screen 720p and will probably allow slight more intensive games to be played on a 720p output.
    These seemed to be designed as a HTPC front-end, running something along the lines of WMC, XBMC or MythTV and should be tested as such. It's also worth seeing how well, or not as the case may be, these run simpler main-stream games, on-line flash games and things that a family may use a computer plugged into the main TV for.
    Ion is way too over-powered for a NAS, you're burning power running the nVidia graphics when you don't need to. In fact, you could find that the Atom platform itself is over-power unless you solely want to run x86 compatible software.
    What I'd like to see for NAS and similar type applications is something like the Beagle Board:-
    http://en.wikipedia.org/wiki/BeagleBoard
    These are at least 3x the price they should be simply because of the economies of scale that Intel, nVidia and AMD enjoy.
    However, nVidia is bringing out it's own low-power chip soon (hopefully) and Tegra may well be the low power platform of choice if they position it correctly:-
    http://en.wikipedia.org/wiki/Nvidia_Tegra
    Both of the above use processors are based on ARM technology and so should run the Linux distributions that have been made available for this platform.
    LAGMonkey likes this.
Tags: Add Tags
