Garage workshop (garage conversion)
Discussion in 'Project Logs' started by legoman, 16 Jul 2020.
  1. Cheapskate
    13 May 2007
    Looking good. You want garage cleaning woes? :lol: I just broke up 14 sheets of old drywall that got humid and rubbery from years of storage. In order to get rid of it, I have to smash it into tiny bits, bag less than 20 pounds of it, and put it in a can. At this rate I'll have it removed by the end of the year. I still haven't found space for 7 ceiling fans that were 'gifted' to us, and there's a washer and dryer inbound.
    Currently rockin' 4 steam cleaners, a floor sander, power washer, and 5 vacuums. I can't give vacs away fast enough...
  2. jinq-sea
    15 Oct 2012
    Can't give vacs away fast enough? Man that sucks.
    Back OT - I like what you've done with the place, @legoman
    Cheapskate likes this.
  3. legoman
    legoman breaker of things
    28 Feb 2010
    I see what you did there ;)
    An thanks, planning a rather complex unit. Kind of a take on crossing an old school desk, the type with the hinged top and a folding bureau.
    So the top will be split into two sections, both of which have a hinge to fold back this will reveal tools an what not in a recess about 70mm deep.
    Below this on the left side will be a false cover with a push to open magnetic closure an behind that a pull out work tray. Found some rather beefy rollers rated to 40kg, reasons will become clear why shortly.
    Right side of the pull out tray will be a draw with more tools.
    Now, runners for the work tray are full extension so that means about 40cm. Reason they are so heavy duty. Well I'm going to have the option to mount either a wheel truing stand which isn't that heavy couple of kilos. Or my very old 15kg bench vise.
    Now both will be on bench hooks which I'll secure with some form of quick release, the vise if soley there for light work, if I need to bash something I have a 5" Vish mounted on a bench for that.
    Though said bench may end up being replaced at this rate.
  4. legoman
    28 Feb 2010
    Update time
    Finally had some OK weather, as in no high winds or driving rain, so actually got some work done!
    Mainly been focusing on one side of the workshop as you've seen. Still more going on there in the future but for now, I'm shifting focus to sort out some organisation.
    Now, I have already done a bit, I made a very stout unit for the tool chest
    Which is great, really tough thing.
    Beside it is now, this
    So simple bench unit with some racking and then a quick skin of coated hardboard to make it look nicer
    This is were it gets more tricky, so previous post I mentioned various extras, well first part has begun. Now I am using mainly scrap wood here, the top I'm not super pleased with the finish, not overly visible in the photos but more so in person (the tops are actually two side panels from an old chest of draws, which is also where the hardboard came from and the bottoms of the tray in the below photo.
    The racking I already had that was due to go on the wall, but I still have more if I want to. The only things i bought were the 2X3 timber, the screws (mainly 5X60mm with some 5X100mm as well) and the hinges, which I need more of, currently only one part of this whole thing hinges.
    Now, in terms of a proof of concept, perfect does what I need an I can make do for now. But I will change it out for something better quality, I'm learning still end of the day. Debating a finish to the frame, if the tops re done it'll be 12mm ply so I can do a coating then.
    Next build job is smaller an will go to the left of this. It will only be about 50cm in height nothing fancy going on there, well yet at least!
    I mentioned more in the future. Now the problem I have in there is space, a lack of. The racking panel I put up for the tools is good, it holds the tools in an easy to grab manner, same with the sanding station. But, since I built the sanding station, I've picked up another sander, so I have a detail and a random orbit, plus there's a half sheet somewhere too.
    So, currently debating whipping down all that's there and making something better, Currently I have a rack with all my large screws just on the back of my wood branch, its not any use there an gets in the way doing large work.
    Going to do some brainstorming but working round the concept of this.
    Also cramming in a saw till in so to compact the saw storage, currently have about six, but only space for four.
    As you can see, lots to work out here, The slide track they have done I think is just out of the wood, I would probably track it properly just for longevity.
    My only snag here is if I rebuild it to take in the existing rack and the sanding station, I would have to negotiate some cabling. not too had just have to ensure I space off the wall and notch out where needed
    Existing sandpaper I have a possible solution for that which should be a lot slimmer, but its not a super important thing currently
  5. Cheapskate
    13 May 2007
    That peg board covered cabinet would be SO full of yellow jackets here. :lol: I was never a fan of peg board since it fills up really fast. Blow molded cases accumulate the same way. I'd go for maximizing floor space and run a shelf all the way to the ceiling.
    Desk is looking great. :thumb:
    Ceiling: I had a relative that had a drop-down train set using pulleys, cable, and a locking crank. I can see your blow-molded case plague going up there.
  6. legoman
    28 Feb 2010
    Thanks more to do on the desk though.
    Blow mould boxes I do hate. only ones I have are, mains drill, mains planer (never actually tried it), a heavy duty impact gun (1/2 450nm) and a case of drill bits.
    I am hoping once I make the last unit I can put three of them in there as I rarely need them an some other odds an ends, then I'll be able to use it for something else at some point.
    Once thats built an the bikes all stowed I can focus on the blue bench which is just a dumping ground currently.
    Idea is the top will be for the bench drill and grinder, with some storage for drill bits etc, underneath needs sorting its currently bike parts which need storing properly.
    On the pegboard, I'm not a fan either its not very good in terms of storage density, I'm considering the above mainly so I can get the bulk of my daily tools away and ideally some clamp storage, currently they just sit on the wood bench or on stand up on the floor.
    I'm going to have to work out what's wrong with with the red bench, none of the draws or cupboard appear to close properly they no longer line up, I'm not sure if its the uneven floor, or the bowed top, or both but something is really out, legs are all adjustable so long spanner an lots of cursing ahead. While it doesn't rock I think its just bowing to the shape of the floor currently.
    If it is ruined (hope not) then I'll have to grab some timber quick in case we stumble back into a lockdown. I have some timber for framing but would need more but its the top an shelving I'd need. If it is then I may just replace the blue unit at the same time and make a 2400LX600DX900H unit, which would prove interesting to say the least.
    Plus side I could go mental on the custom work, would possibly mean I could integrate the chop saw though an I could make use of the dead space under the wood bench :worried:
  7. Cheapskate
    13 May 2007
    Are the red cabinet drawers caster rails or metal angle rails? Some of the bearing casters for those can get out of track if you pull them completely out and don't get them together exactly right. Then again, if it has leveling feet, it might be case flex.
    Chop saws are best free-range. It's easier to prop up the end of a long stick you need to cut by using it on the floor too. :lol:
  8. legoman
    28 Feb 2010
    I can't remember to be honest, seen lots of reviews where people complain about them or just upgrade them.
    Had a mess around with it earlier it does seem better the floor is very out which wont help matters. Depending on what happens with the other end I may move it down there and make my own as mentioned, lots of clearing out etc though is needed.
    Chop saw could still be whipped off easily enough I can just chuck in some insert nuts an bolt it down. still all pie in the sky though got to sort the other side first an get the bikes up an away.
  9. legoman
    28 Feb 2010
    Little update no images more confirming of furniture shuffling, plus I get to build another unit which actually solves an issue for me.
    So, small change, moving the blue storage rack an swapping it for one of the brown ones, its a little higher but otherwise the same, benefit being it is a bit lower so can not only be closer to the garage door but also means the top shelf is usable for smaller items.
    Larger change though, the smaller blue work bench is moving to the end of the garage, solves a few issues and creates some nice storage.
    Once that goes I'll move the red bench down, an probably change the top at the same time, ill notch out the back to wrap around the centre brick support pillar.
    That will allow me to make a replacement but importantly I can leave the right side open so I can actually use the currently wasted space that is under the wood bench, you can kind of get to it but its not exactly easy.
    From the plan I have for the bench the space is something like 680X605 under there so a pretty decent amount of space under there so I can easily chunk up a shelf an store some of the larger less used tools which frees up some much needed space. May try some fun bits on the bench to make it more useful, I will need to draw up some designed closer to the time once I work out exactly the space available but it should be 900mm in length as that's what is there currently.
    One bit I'm not super happy with is the wall storage of the bikes, its quite messy with two on the main hook and another hanging from the wall by its wheels. bit of a squeeze but should be possible to refine it. Possibly using the space over the red unit if space allows to hang a bike wheels off, do also need dust covers for the bike sanding recently coated them all in a nice layer of sawdust which also highlighted a rather important need for proper dust extraction which is something I am looking into (mmm Festool).
    More soon hopefully
  10. Karrek
    Karrek Member
    7 Jun 2011
    This may be difficult to describe, but I'll try:
    For the bike, if you are comfortable lifting it over your head, you could store it horizontally by putting a small shelf (say 6-8" deep) on the wall that is long enough to support both wheels, and then install a typical garage bike hook at the same or slightly higher level to hold the frame. So when lifting the bike, you will put both wheels onto the shelf, then pull the bike slightly back to put the frame onto the hook. So basically the bike ends up horizontal above your head/workspace/wherever, parallel to the ceiling. Also, you can install a light onto the bottom of the shelf to provide light that is not blocked by the bike.
    legoman likes this.
  11. legoman
    28 Feb 2010
    Yeah that makes sense, I have plenty of those hooks so I can certainly have a look into it, I have a bare frame and a spare wheelset I can lob on to get a bike shape so to speak.
    Thanks for that always nice to have alternative ideas
