Other Geekbench scores
Discussion in 'Hardware' started by Bloody_Pete, 14 Dec 2011.
  1. law99
    law99 Custom User Title
    24 Sep 2009
    Are you saying you have bought another chip just to get some higher clocks?
    Are you going to upgrade your memory? Or is there not much between you guys (YOu and Pookey that is)
  2. Guest-44432
    Guest-44432 Guest
    If you see my 32bit & 64bit score, on the previous page. You will notice that I have taken back the top spots with my 1600Mhz memory. I have no need to upgrade my ram yet, unless Pookeyhead comes back with a better OC and higher score.:D
  3. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    Upgrade your RAM and break 30K. You know you want to :naughty:
  4. KidMod-Southpaw
    28 Sep 2010
    You're all crazy!
    But you Simon, will now try and find a chip better than that! And get some better memory! :p
  5. Guest-44432
    Guest-44432 Guest
    Nah, I'm happy, till someone beats me, then I will.:D
  6. David
    7 Apr 2009
    Yeah, then he'll fill all the slots! :hehe:
  7. Guest-44432
    Guest-44432 Guest
    Haha.:D
  8. law99
    24 Sep 2009
    Fair enough. I suppose its nicer to have the CPU over the RAM. Plus, that's a lot of RAM!
  9. Guest-44432
    Guest-44432 Guest
    Yep, 4GB of that ram is a RAMDisk, for my internet cache. Saves thrashing my SSD's.:D
  10. Wozza365
    Wozza365 What's a Dremel?
    26 Jan 2012
    how do ya set up a RAMDisk? i was considering it for when i upgrade to 16GB
  11. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    interesting. if you use internet all the time can it damage ssd then?
  12. Guest-44432
    Guest-44432 Guest
    This is what you need. Obviously download the free version.:)
    Clicky
  13. Pookeyhead
    30 Jan 2004
    He he... welcome to Bit Tech Stu! ... prepare your wallet! :)
    I'm sure someone actually calculated how much money has been spent on hardware as a direct result of this thread, and it was quite frankly, embarrassing.:D
    @Simon... you're an arse... err... I mean congratulations! That the new super duper batch 3960X? I was holding off buying one until I saw how yours went.
  14. Wozza365
    26 Jan 2012
    how much do you think would be enough for internet cache? i dont want 4GB although might use that if i get 16GB, how do i choose internet cache or whatever
    can i put part of windows on here? increase boot speeds some more
  15. Pookeyhead
    30 Jan 2004
    I'll update the boards later... possibly tomorrow. Pretty tired tonight, and may get some SWTOR in before bed time :)
    @Simon... just noticed your IBT screengrab. standard for 5 loops? Set Max for 20 loops.. see how long it can go at that voltage. I can run IBT at this 4.7 with 1.28V all day long when on standard, as it only seems to use 4GB of RAM. Set on Max however, it uses all 16GB, and needs 1.36 to be stable.
  16. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Rofl. Gaming Compulsion, Pook?
  17. Pookeyhead
    30 Jan 2004
    I've always gamed.. I find SWTOR soothing actually... where as WoW made me want to kill things. Weird really as SWTOR is basically WoW with light sabers.
    Anyway.. yeah...
    Simon, I thought you had rads with the surface area of Mars?
  18. Pookeyhead
    30 Jan 2004
    Stu.. what was your clock speed? Geekbench doesn't report it properly. I'm assuming the same speed you posted in Facebook? If not, let me know and I'll amend it.
  19. Guest-44432
    Guest-44432 Guest
    Haha, you know you want too.:D
    Yeah, I will have a play with it in a bit. I have managed to use Offset mode + in the bios to allow the voltages to drop when Idling. CPU @ 5Ghz is 1.4V, and idles @ 1.2Ghz @ .8v. :)
    Yep, but it's cause I'm using Arctic Silver 5 TIM and It's only been applied a few hrs ago + my room temps were 27C, so my Idle temps are at 28-29C.
    Ran out of my 24ct Diamond TIM, so I will have to get some more. :)
  20. Guest-44432
    Guest-44432 Guest
    Well, with that RAMDisk, it will wipe clean every reboot. so it's down to how much surfing you do.
    Depending on what browser you are using, there are guides on Google for each one. :)
