Other Geekbench scores
Discussion in 'Hardware' started by Bloody_Pete, 14 Dec 2011.
  1. law99
    law99 Custom User Title
    24 Sep 2009
    http://browse.geekbench.ca/geekbench2/559922
    New memory. 1600mhz of it. Still 8gig.
    4.7ghz clock... just enough to clear all those Phenoms... PHEW!!!
    Also, feel for you Tundra as the memory performance definitely makes a difference in this particular bench.
    I'll try harder later.
    Teelzebub likes this.
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Enough to clear the Phenoms, but not the lone, overheating FX series before you. :D
    I still rage at the controller. Piledriver isn't likely to be much better, either. It'll still be using the same socket, so the NB bottleneck will still be there, even if they do improve the Memory Controller.
  3. law99
    24 Sep 2009
    Wa! shh... ;)
    To be fair to ... What? Same chipsets again? Easy upgrade path only goes so far. Eventually you want moar!!
    But to be fair to those phenoms... 6 cores, lower clocks, hampered by memory.
  4. longweight
    7 May 2011
  5. Pookeyhead
    30 Jan 2004
    Boards Updated.
    KidMod-Southpaw and Teelzebub like this.
  6. Pookeyhead
    30 Jan 2004
    Works a treat. Using 0.015 +offset, and medium LLC and it gives me the exact same on load volts as my static settings. At idle, it's around 0.85V
    Idle:
    Being brutalised by IBT Max:
    Leaving it running to test stability, but as the Vcore is the same, and no other settings have been changed, I'm pretty certain it's fine.
  7. .//TuNdRa
    12 Feb 2011
    Exactly. I might be a bit peeved if AMD change sockets, but I'd accept it is needed in order to be able to open up for the next generation of processors that actually have a relatively good memory controller. They've been recycling the AM2/3/+ platform for, what, Eight years now?
  8. Guest-44432
    Guest-44432 Guest
    Excellent! I prefer it running low idle voltages, as opposed to running high voltages, even at idle speeds; = Longer life span for the chip.
    +Rep button for my awesomeness? Hint...hint :D
  9. Pookeyhead
    30 Jan 2004
    Consider it done. :)
  10. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    to correct mine, ram is 4.00 GB DDR3 SDRAM 533MHz
  11. Pookeyhead
    30 Jan 2004
    Nope.. that's the RAM clock speed, but it's double pumped... hence DDR... DOUBLE data rate = 1066.
  12. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    hey pooky was is my laptop score not on the board???
  13. Pookeyhead
    30 Jan 2004
    You're right... it's not. Will sort on next update, sorry.
    David likes this.
  14. fuus
    4 Dec 2010
    my bad! sorry Pook
  15. Guest-44432
    Guest-44432 Guest
    64bit-Chart is down, for me anyway. :)
  16. .//TuNdRa
    12 Feb 2011
    I can confirm it's dead, 404'd.
  17. Pookeyhead
    30 Jan 2004
    Should all be working now. My host was having some issues yesterday. Updated also.
    JBond and Teelzebub like this.
  18. .//TuNdRa
    12 Feb 2011
    Schweet.
  19. Guest-44432
    Guest-44432 Guest
    Yep, all up and working again. :)
  20. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    this was at 5.2
    i still dont understand why my results are lower than some people's when they have lower clocks/the same clocks as me. if anyone could shed some insight it would be appreciated
    http://browse.geekbench.ca/geekbench2/561297
