Other Geekbench scores
Discussion in 'Hardware' started by Bloody_Pete, 14 Dec 2011.
  1. Pookeyhead
    30 Jan 2004
    I'm not sure. I seem to recall this batch I'm on not being that terrible at 5GHz... it was cooling that was my problem, not volts. However... the more I think about it, the more I just may wait for IB-E and spend cash on Kepler when it lands. Can't decide yet... then you've got the C2 stepping version released soon (if not already), so it may be worth seeing what feedback there is on those before I decide.
    You'll have to talk me through that one day, as I never got my head around using offset. Instead I use a static setting, and use LLC to ramp up and down. I'd love to be able to idle at such a low, cool voltage though. Fancy posting a BIOS screenie?
    Yeah, that stuff needs to cure a little... same here. I'm using AS5 and it dropped quite a bit after I'd "run it in".
    BTW... just updated the boards for you Simon, so feel free to basque in your own smugness... ya' ****!
  2. Guest-44432
    Guest-44432 Guest
    Yeah, I would, as this will leave me on the top spot for a while. hehe.:)
    Yeah, I will do that for you.:)
    Usually takes a couple of days to cure, as you say. :)
    LMAO, Oh I will. :p I'm sure you will have a come back!:)
  3. Guest-44432
    Guest-44432 Guest
    @Pookey - 5.2Ghz in 64Bit test and RAM was at 1600. Cheers Mate. :thumb:
  4. Pookeyhead
    30 Jan 2004
    I can take that back whenever I chose :) I'll leave it a few days... let you have enough time to enjoy it... before I snatch victory from your grasp and leave you with the bitter, smoldering feelings of defeat and disappointment. :D
    Thank you kindly ya' ****... I mean.. mate :)
    I think mine was 48 hours and then it bottomed out. Weird stuff AS5. I used to use Ceramique.. whilst not being as good, you could slap it on and know where you were with it, but 48 won't kill us I suppose.
    [EDIT]
    Boards fixed.
  5. Guest-44432
    Guest-44432 Guest
    OK OK you win....not:hip:
    LOL.:cooldude:
    Still, I would rather get some 24ct Diamond TIM on this...Knocks the Temps about 3C lower than AS5.
    Thank you. :)
    Here you go. Now, I played around with this for a while. I booted into windows at 5Ghz with 1.4V vcore. Then Restarted. Popped into the Bios and changed Manual Vcore to Offset mode. Then + and then 0.040. Saved & Exit. Then Loaded into windows. (Make sure you haven't got your powerplan in Control panel set to High Performance - set it to Balance. Also set your EPU in AI Suite to Auto). Give it about 30 seconds on the desktop, and then she should drop to idle. :)
    (Efficiency score in 64Bit, I need bumping up into 2ND). ;)
    Pookeyhead likes this.
  6. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Wow I feel left out of this D**k swinging contest, although I'm not sure that's the right phrase to use, anyway I shall have to get my 3960X installed when I finally finish my 7 day week on wednesday :D
  7. Pookeyhead
    30 Jan 2004
    You are in 2nd here. Have you cleared your cache and reloaded?
  8. Guest-44432
    Guest-44432 Guest
    Look forward to the competition. :)
    Still shows me in 5th place on the 64bit Efficiency board...Cache cleared etc. :)
  9. Pookeyhead
    30 Jan 2004
    I've deleted teh files off the FTP server, and re-uploaded them. Try now.
  10. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    Looks good to me :thumb:
  11. Guest-44432
    Guest-44432 Guest
    Yep, that fixed it. :)
    Have you tried using the offset mode yet? I found when using 4.7Ghz I only needed to apply 0.005v to the offset. That booted me into windows fully stable at 1.3v with Medium LLC.
  12. Pookeyhead
    30 Jan 2004
    Not yet no. Had too much other stuff to do tonight. I'll give you some feedback as soon as I've had the time to do it.
  13. cerbrus2
    cerbrus2 What's a Dremel?
    24 Sep 2011
  14. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I am happier now.
  15. Pookeyhead
    30 Jan 2004
    boards updated.
  16. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    heres the results from my Dell Vostro 13 laptop
    CPU @ 1.3
  17. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
  18. Stu @ MSD
    Stu @ MSD What's a Dremel?
    6 Feb 2012
    Indeed it was.
  19. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I'm coming for you .//Tundra. Upgrading to 1366 soon and I'm aiming for you :hehe:
  20. .//TuNdRa
    12 Feb 2011
    I'll still bitch about the crappy memory controller. I can't hit my target of 13K because of that damn thing.
